Old October 24th, 2011, 08:54   #1
cr4zy3lgato
cr4zy3lgato's Avatar
TDI(s): Jetta 2000
Fuel Economy: 40 MPG
Default ALH Silicone Hose Kit
Sorry if it as been already covered, but i've searched for silicone radiator hoses for ALH engine and can't find anything...
I'm a little surprised that with all the hoses in the engine bay no one replaced the rubber yet, my Jetta is slowly leaking rad fluid (i have to fill from min to max every two or three weeks) so i want to replace all plastic fittings and did'nt really wanted to put the old hoses back...
while we're at it, isn't there performance thermostats that open faster?
.:KERMATDI Tuned
cr4zy3lgato is offline   Reply With Quote
Old October 24th, 2011, 10:22   #2
Lex4TDI4Life
Lex4TDI4Life's Avatar
A few observations:
1. Do you know for sure that your coolant leak is due to a degraded hose? Water pumps and thermostats are the most likely leak points from what I have seen.
2. If your hoses really are degrading, that would be a likely sign of a fuel leak. Diesel degrades rubber.
3. Most folks around here are looking for a thermostat that opens later to enhance mpg. Are you spiking your coolant temp that quickly?
2001 Golf TDI 5 spd
RC2, Bosch T4-764 injectors, OMI, SBC Stg 2 Clutch, Koni FSDs, TT LCA Bushings, The Mystery Bar, Dieselgeek Panzer Plate, Elephant Hose, DG Race Pipe, Autometer Cobalt Boost Gauge, Boostvalve,Fumoto Valve, Mufflerectomy, Scangauge II
Lex4TDI4Life is offline   Reply With Quote
Old October 24th, 2011, 11:38   #3
tyrone shoelaces
Guest
well if you read what he posted he never actually said that the hoses were suspect of leaking just that he would like to replace them, due to preventative maintinence i'm assuming, while he had everything apart. I've also looked for silicone hoses either coolant or air and have not found any kit availabe for either, but the only thing i found that you could do is buy sections/pieces and make your own kit as they sell 30, 45, 90 deg elbows and striaght pieces of all sizes.
Silicone Hose and Viton hose part numbers paramedick VW MKIII-A3/B4 TDIs 89 March 31st, 2018 19:59
McMaster-Carr black silicone vacuum hose kit Eudaemonic Private TDI Items for Sale/Wanted 4 May 26th, 2011 10:55
Silicone Intake Hose? LurkerMike TDI Power Enhancements 8 February 25th, 2008 12:04
Silicone Hose F2 Ed TDI Power Enhancements 8 November 22nd, 2006 10:07
Feeler FS: NB,G/J ALH Silicone Vacuum hose kits Growler Vendor & GroupBuy items for sale 50 November 5th, 2004 11:37
Page generated in 0.11155 seconds with 10 queries
[Output: 57.81 Kb. compressed to 52.45 Kb. by saving 5.35 Kb. (9.26%)]
