Old October 21st, 2011, 12:13   #1
weekendwrencher
TDI(s): 2000 Jetta
Default Rough Idle
Car seems to idle rough sometimes. Especially when I am at a stop sign or stop light and depressing the brake. I let off the the brake and the idle seems to smooth out a little. Any suggestions or ideas of what's going on?
Thanks in advance for any feedback.
weekendwrencher is offline   Reply With Quote
Old October 21st, 2011, 12:39   #2
jettawreck
jettawreck's Avatar
Automatic or manual??
2004 Cadillac SLS (wife's)
Old October 21st, 2011, 13:25   #3
weekendwrencher
TDI(s): 2000 Jetta
2000 Jetta TDI Manual. Thanks
Old October 21st, 2011, 14:04   #4
jettawreck
jettawreck's Avatar
VW TDIs if you have some throttle and apply the brake the ECU backs off the fueling, but I doubt that you have both brake pedal and throttle at a stop with the manual. That's why I asked.
May be an injector issue. How many miles on the current nozzles and bodies if they're not original? Perhaps if you find someone near you that has VCDS they can log the injector balance at idle for you.
Old October 23rd, 2011, 13:18   #5
DougInFL
Fuel Economy: '01 Jetta Greasecar was 3,271 miles with only 12.5 gallons of diesel used
Mine was running rough at idle the last few days. Been here in northern GA (very cold days) ....Looking forward to Florida in days to come.
The idle on mine smooths out when I get to a steady 1,000 rpm.
I'm thinking it's just a sensor that's not used to the cold weather. Also, my GP light is now flashing. Brake lights are working properly and so is the cruise control.
Any thoughts?
Thanks in advance.
DougInFL is offline   Reply With Quote
Old October 23rd, 2011, 19:03   #6
tyrone shoelaces
Guest
Possibly bad glow plugs/glow plug wiring harness
Old October 24th, 2011, 07:04   #7
jettawreck
jettawreck's Avatar
I doubt he is seeing temps when the GPs even activate (sub 45F aprox) in California, unless he's in high altitude area.
Old October 25th, 2011, 20:04   #8
TomJD
TomJD's Avatar
Fuel Economy: 43 worst - 49 avg - 59 best
Is it when you are slowing down and depressing the brake or when you are actually stopped? If it is when you are slowing down, do some research on here about Slow Down Shudder or SDS.
TomJD is offline   Reply With Quote
Old October 28th, 2011, 20:21   #9
weekendwrencher
TDI(s): 2000 Jetta
thanks for all of your input. I ended up taking off the intake and egr and cleaned them. also replaced vacuum hoses. everything behaving well now. thanks for you input. invaluable.
06 BRM stalls at idle and rough idle krystlelite81 VW MKV-A5 Golf/Jettas 14 June 15th, 2011 16:50
extreamly need help! rough idle at idle lol tdi/audi VW MKIV-A4 TDIs (VE and PD) 1 February 10th, 2011 18:02
Wierd idle...cam wear or rough idle? F250_JR VW MKV-A5 Golf/Jettas 6 December 24th, 2009 19:14
Rough Idle or engine loping at idle. HELP! tdikb TDI 101 1 January 15th, 2008 20:50
Rough Idle BriGuy375 VW MKIV-A4 TDIs (VE and PD) 1 March 6th, 2001 14:07
Page generated in 0.14315 seconds with 10 queries
[Output: 90.89 Kb. compressed to 77.93 Kb. by saving 12.95 Kb. (14.25%)]
