Old October 17th, 2011, 16:44   #1
MY1STVW
Default Leaking Diesel Fuel from bottom of fuel filter housing
Does anyone know why I'm leaking diesel fuel from the bottom of my fuel filter. I remove my belly pan and noticed fuel on the pan. Removed the top engine cover and felt the bottom of the fuel filter and it was wet. Is this the drain port on the bottom leaking??
2004 Passat GLS Wagon TDI Reflex Silver, Gray Leather w/wood, Cold Weather, ESP, 6-Disk CD Changer, Stainless Steel Glow Plug Recall, Balance Shaft Module Upgrade "Chain-less at last thank you Oilhammer for saving another Passat TDI"
MY1STVW is offline   Reply With Quote
Old October 17th, 2011, 16:53   #2
DickSilver
The drain port loosens by unscrewing it, so try tightening. It has normal right-hand threads, but it is the devil to get at when the filter is in the car. Don't get murderous while twisting it: it is just nylon or some other plastic.
If it still drips, buy a new filter & install. There is a how-to thread if you need it.
It is useless getting angry at your car: don't let nuthin' whup you that can't talk....
B5.5V TDI, chainless, Rocketchip 2, No EGR, 170K
2012 Golf 2.5, 4 door
DickSilver is offline   Reply With Quote
Old October 17th, 2011, 17:51   #3
MY1STVW
Okay I found the leak with your help DickSilver. The center dimple in the white plastic cap on the bottom of the fuel filter housing is cracked. I tighten the white plastic cap just a bit with my fingers and had someone key on the ignition to energize the fuel pump and found the leak in the cap itself. Does this white cap come with a new filter or do I have to order a new cap?
Old October 17th, 2011, 18:16   #4
owr084
The "white cap" is the drain valve to remove water from the filter. To be honest, I have never needed to use it. A new filter has a new drain valve.
RBB
2005 VW Passat GLS TDI (Chipped, BSM delete, and Manual ), 2007 VW Eos 2.0T, 2015 Toyota Sienna XLE, 2017 VW Jetta SEL 1.8T
owr084 is offline   Reply With Quote
Old October 18th, 2011, 07:40   #5
abctdi
abctdi's Avatar
New filter every 20k miles...
05 Passat GLS 2.0 PD, UnChained & Steel GPs by VW, 15" steelies, New TB/WP, motor mounts, alt pulley, trans filter, cv boots, TSB #P9/66C8, clear bra & tint, both raxles. Now only driven 1-2 times per week. 123k miles (sold)
DD is a 2012 Kia Optima SX turbo with 274 hp and 269lb-ft@1,750-4,500rpm
abctdi is offline   Reply With Quote
Old October 18th, 2011, 07:52   #6
Honeydew
This past weekend a local member told me about his recent experience with the same issue. He surmised he had previously tightened the drain to much because he took the drain off and found the sealing o-ring split. Since the filter was relatively new he replaced the o-ring which fixed the leaking drain.
Honeydew is offline   Reply With Quote
Old October 18th, 2011, 18:32   #7
auntulna
This just happened to me too, last week. Dripping from the bottom even though the valve was tight. It was a Mehl, replaced it with a Hengst. Go Hengst!
auntulna is offline   Reply With Quote
Old October 19th, 2011, 18:51   #8
DickSilver
I would be just as happy if there was an optional filter with NO drain valve. There is almost no water in our fuel anymore anyway. Changing the fuel filter every 40K (20K seems anal-retentive to me) has always been good enough; never opened any drain valve.
Old October 19th, 2011, 20:33   #9
abctdi
abctdi's Avatar
Why not double the maintenance period on every part then?
Old October 23rd, 2011, 09:51   #10
Alchemy
Alchemy's Avatar
Fuel Economy: N/A
Dirt is the issue.
I have had three instances where a dirty fuel filter has caused a stumbling problem, once it was so bad the car went into limp mode. Each time, changing the filter made the issue go away (Confirmed on the old filters each time that there was no water in the filter). I drive 25k miles per year and replace the filter every November before the cold weather hits and I always keep one on the shelf in case.
Past as of 12/9/2016 - 2012 Jetta Sportwagen TDI - Platinum Gray, Black, DSG, Panoramic Roof
Past: 2005 Passat GLS TDI Wagon - Silverstone w/ Anthracite Leather - Unchained
Past: 2000 Jetta GLS TDI 5 Speed - Galactic Blue w/ Tan Leather
Alchemy is offline   Reply With Quote
Old October 23rd, 2011, 10:05   #11
Ski in NC
Fuel Economy: 48-52 typical
White drain valve has normal metric threads. Get a bolt that fits and an oring and replace it.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
drain fuel filter bottom, vs. just replace it verylongdrive TDI 101 1 September 22nd, 2011 04:45
Leaking fuel filter O-rings, did I get the wrong fuel filter? dalchri TDI 101 14 March 26th, 2008 13:47
help! - oil leaking bottom of oil filter housing wnytdi VW MKIV-A4 TDIs (VE and PD) 9 May 12th, 2005 16:30
Leaking Diesel Fuel from Top of Filter VelvetFoot VW MKIV-A4 TDIs (VE and PD) 4 March 4th, 2002 05:47
fuel filter bottom leaking 3kidsnadezl VW MKIV-A4 TDIs (VE and PD) 3 December 16th, 2001 18:33
Page generated in 0.15879 seconds with 10 queries
[Output: 101.26 Kb. compressed to 85.44 Kb. by saving 15.83 Kb. (15.63%)]
