Old October 12th, 2011, 16:36   #1
fruitcakesa
Fuel Economy: 40's
Default Mixing Dot 4 with Dot 3 brake fluid
I was bleeding the brakes and ran out of the Blue dot 4 so I finished up with dot 3. Are they compatible or should I flush and refill with only one?
2004 Jetta TDI wagon 5 speed 278k+ VNT 17 Kerma tune. new heater core
fruitcakesa is offline   Reply With Quote
Old October 12th, 2011, 16:46   #2
loganbmx4gt
loganbmx4gt's Avatar
big no no. dot 4
loganbmx4gt is offline   Reply With Quote
Old October 12th, 2011, 16:47   #3
tomc585
The difference between the fluids is the temp rating. You shouldn't mix or use opened container brake fluids (unless its known to be free of contaminates) that havn't been stored properly. The blue dot 4 is a higher temp, purple is a synthetic grade 4, the dot 3 is not.
Flush and fill with one or the other of at least the grade the car requires .
2009 TDI JSW w/DSG 16" rims
VAG Com & Bentley Service Manual
tomc585 is offline   Reply With Quote
Old October 12th, 2011, 17:23   #4
KLXD
Never heard of synthetic DOT 4. I thought all DOT 4 were glycol based, same as DOT 3 and chemically, completely compatible with it.
I can't believe two incompatible fluids could carry the same DOT specification. Or are you saying the purple and blue DOT 4's are compatible? If so they are compatible with DOT 3.
What is "synthetic" brake fluid. I thought it was a Valvoline marketing gimmick unless you are talking about DOT 5 silicone.
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old October 12th, 2011, 17:29   #5
jcrews
jcrews's Avatar
TDI(s): 2003 Golf
DOT4 and DOT3 are both polyethylene glycol based, which is a synthetic polymer. There's no such thing as a mineral based automotive brake fluid. It'd be similarly redundant to market water as inorganic.
DOT4 increases the boiling point over DOT3 by adding borate esters. That's it. If the bulk of the fluid had performance characteristics sufficiently beyond the minimum required by FMVSS, adding a small amount of DOT3 is nothing to sweat about. Obviously the highest boiling point possible is desirable for safety reasons, but you'd have to be driving like a crazy person to get into trouble.
DOT4 is cheap to produce, so fluids with DOT3 maximum performance don't make much sense. Some manufacturers have resorted to just packing DOT4 into bottles marked DOT3/DOT4 so the target market will not ask questions.
What is important, however, and was mentioned before, is care in handling PEG based brake fluids (everything but the silicone DOT5). Always use new bottles, because the oil immediately starts absorbing moisture, hence the requirement to change it every year or two to maintain the boiling point.
jcrews is offline   Reply With Quote
Old October 12th, 2011, 17:33   #6
sisyphus
sisyphus's Avatar
Thank you for that clear, concise response. I love hearing such answers based on real knowlege and not just parroted whatever from "the net."
sisyphus is offline   Reply With Quote
Old October 12th, 2011, 17:50   #7
compu_85
Gadget Guy
compu_85's Avatar
I think some DOT3 fluids resist water better than DOT4 fluids.
On a car that hasn't had its brake fluid flushed in a while I like to start out with DOT3, leave it in for a week, then re-flush with DOT4 to get all the crap out.
-J
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old October 12th, 2011, 19:42   #8
fruitcakesa
Fuel Economy: 40's
Thanks for the clear info .
Old October 12th, 2011, 20:12   #9
Corsair
Corsair's Avatar
Fuel Economy: 52/48/??
agree with responses #4 and #5- DOT3 and DOT4 brake fluids are yes compatible to mix together. But do not mix either with DOT5.
[EDIT after reading response #10- agree 100%. DOT3 and DOT4 are not equivalent (as explained above), but they are compatible to mix. So, if DOT3 was introduced into a system containing DOT4, no need for concern about gelling or chemical reactions etc. but the overall boiling point of the system will be reduced by the DOT3 accordingly.]
imho- OP didn't shoot himself in the foot by mixing a bit of DOT3 with the majority of DOT4 in his car. However.... if it was an old bottle of DOT3 that had been previously opened and capped, but sat on the shelf for a long time... that might have been a foot wound, not because the DOT3 is incompatible, but rather because the DOT3 might be loaded with moisture.
Best Regards.... Corsair....
2002 Jetta GLS TDI 5-spd 325Kmi, 2014 JSW TDI 6M
2006 Audi A4 Quattro Avant 2.0T 6M
2004 Jetta GL wagon 2.0L (gas) 5-spd (sold)
[also had 03 TDI GLS 5spd wagon bought new, sorely missed]
Corsair is offline   Reply With Quote
Old October 12th, 2011, 20:14   #10
Sbeghan
Annnddd just to beat the dead horse. All brake fluids are synthetic and come in two flavors, PEG and silicone. Dot 3 & 4 are completely compatible but you should assume a performance in between them when you mix them.
Sbeghan is offline   Reply With Quote
Old October 12th, 2011, 20:31   #11
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
Get a water percentage tester and let that be the deciding device on changing the fluid.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old October 20th, 2011, 15:13   #12
Doug Huffman
Location: Washington Island, on the other side of Death's Door, Wisconsin
Fuel Economy: 50+(Jetta)
PEG, isn't that AstroGlyde? Oh yeah, and GoLightly?
Brake fluid is PEG monobutyl ether or monoethyl ether, not suitable for use as a personal lubricant. It might work as an laxative.
Jetta Wagon TDI 2K3 Silver has gone to a new home, replaced by Behemoth 2012 BMW X5 35diesel. Jason T. Daniels Is my 55 mpg guru.
Doug Huffman is offline   Reply With Quote
Old October 20th, 2011, 17:36   #13
AndyBees
AndyBees's Avatar
Great thread!
I guess my old '83 Vanagon could use a brake fluid flush!
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old October 20th, 2011, 19:23   #14
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
-J
I agree. When we got our 04, the brake fluid was pretty nasty(probably original).When I sucked out the old fluid, there was still black goop stuck to the sides of the tank. That was only a few years too since we got it in 2010.
It says to change it every 2 years in the manual and I can see why. I probably should just flush it once a year for a few bucks in costs in fluid. A rock hard brake peddle is nice too!
turbocharged798 is offline   Reply With Quote
Old October 21st, 2011, 05:05   #15
PDJetta
PDJetta's Avatar
If DoT 4 absorbs water more readily, perhaps that is why the 2-year replacement is required by VW. All the American cars manufacturers seem to specify specify DoT 3 and have no fluid change requirement.
--Nate
DOT 4 Brake Fluid SheeB VW MKIV-A4 TDIs (VE and PD) 2 December 29th, 2010 13:53
DOT 3 Brake Fluid vwdsmguy VW MKIV-A4 TDIs (VE and PD) 4 January 24th, 2005 15:27
What Dot??? to use for brake fluid foxstoy VW MKIV-A4 TDIs (VE and PD) 5 May 4th, 2004 22:53
Brake Fluid DOT 5 LanduytG VW MKIV-A4 TDIs (VE and PD) 5 October 21st, 2002 00:33
BRAKE FLUID - USE DOT 4 ONLY SkyPup VW MKIV-A4 TDIs (VE and PD) 32 March 9th, 2002 00:23
Page generated in 0.15401 seconds with 10 queries
[Output: 130.90 Kb. compressed to 108.96 Kb. by saving 21.94 Kb. (16.76%)]
