Old October 4th, 2011, 10:06   #1
ROD-TDI
Fuel Economy: 51.7 MPG 2003, 2015 TDI 48.4 MPG.
Default Typical Labor Cost for Shock Installation?
What is the typical labor cost to install Bilstein HDs at all four corners, on a 2002 5-speed TDI? I am providing the shocks to the shop/dealer, but my initial job quotes are all over the place. $175/shock to $350/shock. What is a reasonable labor cost, for what is invloved?
Thanks,
STP
ROD-TDI is offline   Reply With Quote
Old October 4th, 2011, 11:13   #2
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
Well, are you only doing the shocks and nothing else (you should do all the rubber moving parts). The rears are easy to do and could be done for less then $100 in labor total. The fronts are a little harder and require 2 special tools to do and a spring compressor. Maybe around $125 a front. But then again I did it myself so I don't know what others charge.
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car 1.9aaz, 5 spd, 1981 Caddy VW truck diesel, 2004 Golf-2 inch lift, -fixing, 2005 Golf-2 inch lift - totaled twice and fixed twice, 2005 Jetta Wagon - 2 inch lift
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old October 4th, 2011, 12:54   #3
20IndigoBlue02
20IndigoBlue02's Avatar
I would estimate
Front = 1 hr per side
Rear = 1/2 hr per side
Alignment = 1 hr
Labor rates is dependant on region.
Also you should include is additional parts:
Front:
  • Strut Mount
  • Strut Bearing
  • Spindle Stretch Bolt & Nylok Nut
  • Axle bolt (if they have to remove the axle to drop the passenger side, maybe the driver side, depending on the stop)...
Rear
  • Shock mount
  • Shock stretch bolt
...and forgot to mention... you won't be reusing the front strut bumpstop. The Bilstein HD shaft is too large & has internal bumpstops
2016 Tiguan SE 4Motion
20IndigoBlue02 is offline   Reply With Quote
Old October 4th, 2011, 19:25   #4
Birdman
Fuel Economy: 55 summer 50 winter
My shop here charges 80 a shock and all they do is front end and shock work.
2003 Jetta 216 injectors, race pipe, OMI, 2.5 cat back pipe, Sachs power clutch,Lightweight fly wheel,Rocketchip 3.0,Dieselgeek race pipe,Borla SS exhaust,Dieselgeek Intercooler pipes,Pierburg MAF,EU cluster with LED Boost gauge,,
Ventectomy,Alientech window,Old Navy ccv filter,Catch can,Dieselgeek short shifter,ATE power slot rotors,Porterfield pads,Shine suspension,Shine rear sway bar,TT pedals & foot rest,Cat fuel filter 2 micron,Alum skid plate,Euro headlights and switch,5 Brake light mod.
Birdman is offline   Reply With Quote
Old October 5th, 2011, 03:54   #5
ROD-TDI
Originally Posted by 20IndigoBlue02 View Post
I would estimate
Alignment = 1 hr
Front:
  • Strut Mount
  • Strut Bearing
Rear
  • Shock mount
Thank you all and thanks also '20IndigoBlue02' for listing the additional parts that should be replaced... which are probably not always addressed or are overlooked at some shops.
STP
Old October 5th, 2011, 04:01   #6
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Alldata book times:
Front struts: 2.7hr
Rear shocks: 1.2hr
This does NOT include alignment time.
Personally, I find the front to be a wee bit low (but we almost always are also doing control arm bushings, too). And the rear too much.
We charge 3.0 for all the front, and .7 for the rear, plus alignment. Which ends up being a bit less than book time total.
Then, maybe 50% of the time, I end up having to replace the tie rod assemblies because they are siezed.
oilhammer
www.cardocautomotive.com
Old October 5th, 2011, 04:43   #7
ROD-TDI
Originally Posted by oilhammer View Post
Snip... (but we almost always are also doing control arm bushings, too).
What are the observable effects of worn control arm bushings? Steering wheel vibration during light braking above 50 mph, such as experienced on a BMW E28 with its known upper control arm bushing wear issues? What does the Golf suspension exhibit that would indicate control arm bushing wear? Or, is it primarily an inspection task to determine if replacement is needed?
STP
Old October 5th, 2011, 04:56   #8
oilhammer
oilhammer's Avatar
Well, a quick peak will reveal their condition, but when they are let go to the point that they are completely broken into 2 pieces, the car will wander a bit, clunks on braking and acceleration, etc.
In the time it took to read the above sentence, you could probably inspect them. Check them at every service. They are usually shot before the shocks are.
oilhammer
Old October 9th, 2011, 11:45   #9
supton
supton's Avatar
Fuel Economy: 53/46/33
Are these control arm bushings the lower control arm bushings? Not trying to hijack; but I've long had this "clunk" on accel/decel that I assumed was the door shifting around (sounded like that area). But I had the TT bushings installed, err, I guess it was 100k/3 years ago.
'04 Jetta Wagen 5spd GLS, 314kmiles, Koni Red's, SBC stage 2 clutch, VNT17, RC2 sold
'11 Camry base 6spd manual, 95k, wife's
'10 Tundra double cab, 4.6L, 95k, mine
supton is offline   Reply With Quote
Old October 10th, 2011, 04:09   #10
oilhammer
oilhammer's Avatar
There are no "upper" control arms, therefore it is quite silly to call the control arms on a Mac strut car "lower" control arms. They are just "control arms". And actually, Volkswagen calls them a "track control arm".
It would be like saying "one of my front headlights is out, but both my rear tail lights are good".
oilhammer
Old October 10th, 2011, 18:53   #11
supton
supton's Avatar
Touché... ouch!
Old October 10th, 2011, 19:46   #12
andreigbs
Fuel Economy: 35-38 avg.
Supton: i'd wager the front control arm bushings are probably fine, whereas if the rears are the TT ones and at 100K miles, I'd check them at least. Any cracks and I'd be replacing them.
Clunking on braking can also be a slightly loose outer tie rod bolt(s) since I found out firsthand that they sometimes break or the top bracket plate breaks from too much torquing on the same corner (like going up a steep inclined driveway from the same side every time...)
Caliper holding brackets torqued down? Could be another source of clunking...
2014 GLK250 BT // 65xxx miles // 37 MPG - current
2014 Golf TDI // 45xxx miles // 38 MPG - buyback'ed!
2004 Bora TDI // 146xxx miles // 42 MPG - sold!
1997 Jetta TDI // 317xxx miles // 44 MPG - sold!
1986 Golf NA Diesel // 188xxx miles // 52 MPG - totalled
andreigbs is offline   Reply With Quote
Old October 11th, 2011, 05:09   #13
supton
supton's Avatar
I thought the solid TT bushings were supposed to last much longer than that? Eh, my Koni's have 100k on them, I'm guessing another 50k and they will be up for replacement; at that time I'll just have the bushings et all done over/replaced. [I did notice, while looking for a potential exhaust leak, that it looked like the sub-frame to body bushings were rather cracked.]
Old October 11th, 2011, 06:20   #14
andreigbs
Pardon my tiredness in the above post; outer tie rod actually was supposed to be ball joint. Has 3 bolts holding it with a bracket/top plate to keep everything in place. I've seen that top plate break, seen bolts come loose too. That can be a source of front end clunk. You'll also notice it on brisk acceleration as well as braking.
Old October 19th, 2011, 09:18   #15
ROD-TDI
UPDATE -
Bilstein HD's (from Tire Rack) and all new associated mounting hardware (from IDParts) installed by a local shop (that we've worked with for the past 20+ years) plus alignment, came to $397.57 total labor. Great to have Bilstein HD's controlling things, major improvement in handling, of course, compared to the tired original shocks with 107k miles on them. Thanks to all for your earlier inputs. Much appreciated.
STP
MKIII Front Wheel Bearing Labor Cost dadsdiesel VW MKIII-A3/B4 TDIs 7 February 3rd, 2010 09:51
Q7 3.0 TDI Timing Chain Parts Cost and Labor Units to R/R VLS_GUY Audi SUVs (Q7 & Q5) 20 January 25th, 2010 14:57
typical/expected cost of diesel option??? tlhfirelion TDI 101 19 December 12th, 2007 19:08
Labor Cost for PD Timing Belt Replacement AFlowers VW MKIV-A4 TDIs (VE and PD) 6 August 15th, 2006 07:40
cost 4 hd clutch with labor before chip & injector anoblefox TDI Power Enhancements 0 June 4th, 2004 14:49
Page generated in 0.16595 seconds with 10 queries
[Output: 131.56 Kb. compressed to 110.03 Kb. by saving 21.53 Kb. (16.36%)]
