Old October 3rd, 2011, 19:58   #1
bloke
bloke's Avatar
Fuel Economy: who cares thats not what owning a diesel is really about!
Default Remote start for 2011 TDI
sorry if there's already a thread for this somewhere i checked and nothing showed up
I want to fit a remote starter to the wife's TDi since she leaves for work early enough everything is frozen up and also works nights on and off and i thought it would be nice if she could leave work and climb into a nice warm car in the morning!
anybody got the inside line on if its even possible with the TDi?
she has a 2011 sportwagen with a DSG
dont make me larf!
bloke is offline   Reply With Quote
Old October 4th, 2011, 01:54   #2
Ol'Rattler
Ol'Rattler's Avatar
TDI(s): 2006 Jetta
It is possible but not recommended. Diesel engines are very efficient and produce very little heat when idling. They don't heat up much until you start driving.
That is why the A5s and A6s have an auxiliary electric heater and heated seats that will give you some heat within about 3 blocks of leaving your driveway.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old October 4th, 2011, 02:31   #3
scooperhsd
Fuel Economy: 39/36/33
This might sound a bit harsh but really - Atlanta Georga and you want a remote start ?
Not necessary - these cars don't really heat up until you start driving them anyway.
If you have a good battery (with a new car, you better) and proper oil (a 5w30-40 Diesel rated oil, like the ones listed in your owner's manual), and following the proper start procedure (turn on ignition wait until glow plug pigtail goes out, engage starter) - you should not have any problems at all starting in the coldest possible weather Atlanta will ever see. Heck - doing the above, I've had no problems starting when at 13 F, and you can see we have a number of Canadian and Alaskan members (and northern CONUS) - where it gets REALLY COLD - and they don't have issues...
Tell your wife she should be wearing a winter coat until the car starts producing heat anyway...
2000 Red NB TDI, 4 speed Automatic, 278,695 miles
Now 5 speed manual and onto 500,000 miles + !
scooperhsd is offline   Reply With Quote
Old October 4th, 2011, 05:48   #4
MonsterTDI09
MonsterTDI09's Avatar
The car does have electric heat, just crank up the heat and reticulate the air.The heated seats help to.
2010 Jetta sedan TDI DSG Platinum gray metallic.Build date (5/10) Mods ----EV skid plate
"German engineers do things because they can,not because they should"
MonsterTDI09 is offline   Reply With Quote
Old October 4th, 2011, 06:24   #5
WVU TDI
WVU TDI's Avatar
Fuel Economy: mid 40s.
Yup. You would seriously have to idle it for-freakin-ever to get any noticeable warmth from the car.
Also, Atlanta and she's worried about the car being cold? lol
2010 4dr Golf TDI, 6M
2013 Passat TDI SE, 6M -- turbo failed at 9500 miles.
WVU TDI is offline   Reply With Quote
Old October 4th, 2011, 07:29   #6
bloke
bloke's Avatar
she isn't worried about it and I dont care how much colder it gets where anydody chooses to live iced up windows are iced up windows and running the car for ten mins before you get in it cleans that problem up I know since thats how I get ice off the windows that way usually!
it was a simple question really
dont make me larf!
Old October 4th, 2011, 07:41   #7
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
Actually, since the car has an electric heater, it would be beneficial to use a remote start. The electric heater will immediately start producing heat and the additional electrical load will warm the engine up faster. Starting the engine 5 minutes before you leave will likely defrost the windows and get the seat heater nice and warm.
Trusted TDI Mechanics Map || VCDS Locator || TDIClub Chat
Intercooler Icing MAP - SURVEY || DC/MD/VA - Impex GTG
Advancing the homosexual agenda, one post at a time!
Old October 4th, 2011, 07:50   #8
bloke
bloke's Avatar
Yep that what we did last winter and the car is toasties by the time you get in it. I just wanted to avoid the going out to get it started part although that way you can turn the seats on. We wont be able to do that with the remote start I know but clearing the ice isn't soothing "wearing a winter coat" will help with lol
dont make me larf!
Old October 4th, 2011, 09:15   #9
Good Ol' Boy
VeeDubTDI's Avatar
The seats are a button now instead of the old dial? Didn't realize that. With the dials, you could just pre-select what temperature you wanted when you parked the car at night.
Old October 4th, 2011, 15:28   #10
MonsterTDI09
A frost heater would help with your problem.
Old October 17th, 2011, 11:19   #11
mcfisticuffs
TDI(s): 2006 Jetta
Would any of these responses be affected by a Canadian winter? Aka -20 Celsius or lower?
mcfisticuffs is offline   Reply With Quote
Old October 17th, 2011, 12:46   #12
4whlr
TDI(s): 2011 Wagen
Default Georgia
If I lived in Georgia I would want a remote start for A/C more than heat.
4whlr is offline   Reply With Quote
Old October 17th, 2011, 15:26   #13
MonsterTDI09
No, Just plug in the block heater and go .
Is there a remote start system for a TDI codylent TDI 101 9 September 22nd, 2008 13:43
Remote start on a TDI? NC01NBtdi TDI 101 17 November 27th, 2007 08:15
TDI Remote Start?? MichManTDI VW B5 Passat TDIs 6 September 12th, 2005 07:36
TDI and Command/Remote start Karjar TDI 101 13 September 6th, 2004 03:07
Remote start on a TDi??? Caractere VW MKIV-A4 TDIs (VE and PD) 9 November 21st, 2003 06:24
Page generated in 0.13116 seconds with 10 queries
[Output: 119.69 Kb. compressed to 100.40 Kb. by saving 19.30 Kb. (16.12%)]
