Old October 2nd, 2011, 15:32   #1
2hellWITHhybrids
Default Alternator Harness?
While changing the fans in my golf, under the battery tray I found a connector completely erroded through. The connector runs over to the alternator. Does anyone know what part number this may and anywhere other than a dealer that I can purchase it? Any info would be greatly appreciated!
2hellWITHhybrids is offline   Reply With Quote
Old October 3rd, 2011, 06:37   #2
MrSafety
Newbie at Heart
Fuel Economy: ~35 mpg "as was" when purchased TDI
OK, we know it comes from the Alternator (aka "GEN") as do a total of 4 wires/conductors (according to eBahn's 66/2 wiring Diag.)
Q1 - Can you tell what color insulation is on this wire:
....... Brown? (assumed IF it runs to ground/chassis/frame)
....... Brown/Red?
....... Blue?
....... Black?
Q2 - Where does it go:
...... ground/chassis/frame?
...... strip fuse panel on battery?
...... elsewhere?
I can let you peek at the " 66/2 " diagram... " Gen/Starter "
Regards,
Sam
Son's 2002 Jetta TDI 01M / My '81 Rabbit "Caddy" project / My '80 240D MB...
Other Projects
: Safe Intake Cleanout / IP-QA Craniotomy /
Working on way for DIYers to more fully FLUSH 01M trans as well as check/"top-off" the O1M Fluid Level.
Perform diesel purge without ingesting troublesome air !
MrSafety is offline   Reply With Quote
Old October 3rd, 2011, 13:23   #3
JB05
Fuel Economy: 43/41/40
Is there a part number on the connector or is it too far erroded?
JB05 is offline   Reply With Quote
WTB: Alternator-A/C Wiring Harness Conan Private TDI Items for Sale/Wanted 2 June 22nd, 2011 19:11
How I repaired my alternator harness Eudaemonic TDI 101 2 October 7th, 2010 12:04
How to remove the B4 engine wiring harness connector? Glow plug harness content 914rrr VW MKIII-A3/B4 TDIs 11 March 4th, 2010 14:50
Engine Wiring Harness Question...Swap a Mk3 Harness for a B4? G60ING VW MKIII-A3/B4 TDIs 2 August 10th, 2007 09:18
Wiring Harness swap 99.5 VW Jetta to 04 harness thejestertdi Upgrades (non TDI Engine related) 0 September 19th, 2005 23:40
Page generated in 0.15097 seconds with 10 queries
[Output: 58.18 Kb. compressed to 52.96 Kb. by saving 5.22 Kb. (8.97%)]
