Old October 1st, 2011, 16:30   #1
need4speed
need4speed's Avatar
Default **stuck**; inner-right CV joint boot swap. . .
A while ago, I noticed that my CV joint boot was torn. It is very close to the apex-side, (so the spinning of the axle does not pull grease out of the tear). . . but I realize that a torn boot needs to be replaced.
So, I have a replacement boot, and my shop manual, and I'm unbolting the old CV joint - and god what a horrible messy job - I can't get this inner CV joint to come off the boot. How do I get it to come off? I'm looking at the replacement boot, and it's just got this metal cuff that fits around the joint collar, so. . . I'm thinking, once I get the 6 bolts off, I should be able to just pop the joint out, slide the boot off the axle, and put the new boot in there, load it up with the grease, and bolt it back on. Isn't that how it works?
2003 Jetta 4dr TDI.
G60/VR6 flywheel/clutch. VNT 17 retrofit.
Never. Trust. Dealers.
need4speed is offline   Reply With Quote
Old October 1st, 2011, 17:09   #2
PDJetta
PDJetta's Avatar
Are you trying to remove the inner CV joint with the drive axle (outter CV joint) still bolted through the wheel bearing hub, with just the 6 inner bolts removed so the axle drops down? If so, I have never heard of doing it that way. I think the axle needs to be completely removed from the car and put in a shop vice. There is a "C" clip that holds the innner joint on the axle and it must be spread a little to slip out of its groove and off the end of the axle. Then the inner CV joint should slide off. The inner boot retainer ring will just come off the inner joint with a good tap of a mallet or drift.
--Nate
Old October 1st, 2011, 19:47   #3
need4speed
need4speed's Avatar
Yes, I am trying to remove the inner CV joint with the drive axle still bolted through the wheel-bearing hub. Only the 6 inner bolts are removed. I can't get the axle to drop "down", of course, there's no clearance.
I *did* unbolt my exhaust from the turbo, to gain enough clearance to work at the circlip, and I was able to get that sucker off. Unfortunately, now I've damaged the cardboard gasket, so now I'm kind of committed to using the new one.
The shop manual says to "drift off" the CV joint.
Do I'm not sure about how the wheel comes off - will I need that special clamp tool? Any new single-use parts? I didn't plan this out well, I suppose. I'd rather just keep the axle in the car if I can.
2003 Jetta 4dr TDI.
Old October 1st, 2011, 19:55   #4
the*rogue
the*rogue's Avatar
The OUTERS need to be hit to remove. (NOT FUN) They are circliped.
The inners have a snap ring that allows them to be removed. You have to remove the outer metal grease shield to access the the snap ring. (screw driver/ very light tapping) Don't know if this can be done on the vehicle.
You may need to loosen the swaybar and/or ball joint in order remove/access the inner cv joint.
Be careful not to pull to hard on the outer joint. I've had them come apart on me. Then you have to repack/boot both sides..
Andy
the*rogue is offline   Reply With Quote
Old November 28th, 2011, 18:45   #5
thechocolateman
I'm doing the same thing right now. I'm guessing you got yours figured out already, but for the benefit of anyone who finds this thread and has the same problem - the metal flange on the boot is sealed to the CV joint with sticky gasket stuff - you have to pry the boot off then scrape that crap off the joint and clean it up.
I, too, tried to replace my boot with the shaft on the vehicle... didn't work, there simply isn't enough clearance to disassemble the joint and clean it, not to mention it REALLY sucks trying to work under there. I went to a local parts store and rented a FWD hub puller to push my CV shaft out of my hub, and the rest was easy.
thechocolateman is offline   Reply With Quote
Old November 28th, 2011, 18:48   #6
alphaseinor
You need to remove the axle, don't try to do it on the car.
alphaseinor is offline   Reply With Quote
Old November 28th, 2011, 18:57   #7
lbirunner
Yes, when I replaced my axle I had to really hit the old one hard several times to get it to pop out of the hub.
I replaced the whole axle because I know what a pain it is to just replace the boot, WOW! don't ever want to do that again.
And the price of axles is real low, I think I paid $60 bucks for a refurb axle at NAPA.
The only problem is they want your old axle otherwise you have to pay the core charge. Can't remember what that was. I kept my old axle and paid the core charge. But still better that replacing the boot (inner and outer).
lbirunner is offline   Reply With Quote
Old November 28th, 2011, 19:24   #8
craig01b
craig01b's Avatar
TDI(s): None
Removing an axel it hard...?? Big brass hammer, a puller...trying to renew the cv joint under the car is not something I would ever try...and I have replaced clutches/engines/rear axel bushings/ gas tanks....taking it apart is hard because it has been stuck together, reinstall after working the part is the easy/fun part....good luck, working on any machine is difficult...it's the satisfaction after the reinstall that counts
All retired, bought a Subaru.... all wheel drive, and a little bigger than the high line. Time will tell!
craig01b is offline   Reply With Quote
Old November 28th, 2011, 19:55   #9
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Those cheap, unbalanced, crappy built Chinese axles from NAPA and others are not good for TDI's. Better off rebuilding your VW shafts or sending them to Raxles for rebuilding.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old November 29th, 2011, 07:29   #10
lbirunner
Right, that's why I kept the old one, in case the crappy one doesn't work out. No problems yet, ~30k miles.
Old January 11th, 2012, 19:30   #11
madrean
madrean's Avatar
TDI(s): 02 Golf
Fuel Economy: upper 40s now that wife is driving...
Where the heck do you get a new clamp to snug up the boot to the axle? The idparts inner cv boot replacement kit does not come with one. I'm assuming the old one is destroyed when removing it?
All the cv boot clamps I have found at autozone, etc are too wide.
madrean is offline   Reply With Quote
Old January 11th, 2012, 19:42   #12
madrean
madrean's Avatar
TDI(s): 02 Golf
Never mind... I came across a post that says there is no clamp on the passenger side (A4). Coulda sworn I saw one when I was scoping it out!
What's the scoop with the weep hole?
Old January 12th, 2012, 07:47   #13
Powder Hound
Powder Hound's Avatar
Originally Posted by madrean View Post
...What's the scoop with the weep hole?
Allows excess grease to squirt out and make a mess if you believe that the supplied grease with the new boot is insufficient and you pack the boot with much more than you really need in there.
Old January 12th, 2012, 15:32   #14
madrean
madrean's Avatar
TDI(s): 02 Golf
Hehe got it!
Passat 2005 CV joint boot failure jurgen01 Passat TDI Picture Gallery 7 October 17th, 2009 14:52
CV Joint boot replacement 2006 Jetta jettalisle VW MKIV-A4 TDIs (VE and PD) 1 October 26th, 2008 18:08
Inner CV Joint boot repair jokila TDI 101 11 November 23rd, 2007 21:33
Need solution for bands around CV joint boot Clatterman VW MKIV-A4 TDIs (VE and PD) 4 March 8th, 2005 11:51
CV joint boot clamp crimp tool ??? dieselmania VW MKIV-A4 TDIs (VE and PD) 2 January 6th, 2003 10:43
Page generated in 0.14514 seconds with 10 queries
[Output: 122.34 Kb. compressed to 101.88 Kb. by saving 20.46 Kb. (16.73%)]
