Old October 1st, 2011, 14:46   #1
rhett1948
Fuel Economy: 53/49/45
Default 2003 Jetta Monsoon Stereo
A while back, the FM radio started getting intermittent, progressively worse. Assuming it was the antenna base, I replaced it. The original looked brand new, no corrosion anywhere. No change in radio reception. It finally quit altogether. CD player works fine, which tells me it's an antenna issue.
I then bought tools to remove the radio, figuring there was likely a bad antenna connection at the back of the radio. Today I removed the radio and everything in back looks fine. I removed and replaced the plugs and antenna jack. Still no AM or FM radio.
I'm wondering if it could be an internal component in the radio, or if I'm missing something simple. Any help will be appreciated. If I knew someone with a Monsoon I could swap mine with, I could narrow the problem, but no such luck.
2003 Jetta TDI GLS, Silver, 5 speed, ProVent, Cat fuel filter, 181,000 miles
rhett1948 is offline   Reply With Quote
Old October 2nd, 2011, 04:57   #2
RockvaleTN-TDI
Fuel Economy: 35 combined over 90K miles
I have a Monsoon radio and amp from my '02 Jetta for sale. It is missing a few knobs.
RockvaleTN-TDI is offline   Reply With Quote
Old October 2nd, 2011, 10:00   #3
Corsair
Corsair's Avatar
Fuel Economy: 52/48/??
I'd recommend one more check if it's easy to do- before installing a new radio, is it possible to remove (again) the existing radio and connect the antenna to a known good radio, and test that radio before putting everything back together ? That would concretely establish whether the issue is with the radio or the antenna- pinched cable somewhere etc. Good luck !
Best Regards.... Corsair....
2002 Jetta GLS TDI 5-spd 325Kmi, 2014 JSW TDI 6M
2006 Audi A4 Quattro Avant 2.0T 6M
2004 Jetta GL wagon 2.0L (gas) 5-spd (sold)
[also had 03 TDI GLS 5spd wagon bought new, sorely missed]
Corsair is offline   Reply With Quote
2003 Jetta Tdi Without Monsoon would like to add Monsoon wai-ho.lo TDI 101 0 May 5th, 2010 09:55
Stereo-spkr wiring for Monsoon/non-Monsoon? m9431 VW MKIV-A4 TDIs (VE and PD) 1 October 26th, 2007 15:20
2004 Jetta TDI/DD Monsoon stereo CD changer trouble scanchattanooga VW MKIV-A4 TDIs (VE and PD) 3 June 19th, 2006 10:52
Monsoon stereo fit 98 Jetta? jsillars Upgrades (non TDI Engine related) 2 March 8th, 2006 20:40
Double Din Monsoon Stereo from 2003 GTI - CHEAP ceboyd Private TDI Items for Sale/Wanted 6 January 21st, 2004 08:41
Page generated in 0.12284 seconds with 10 queries
[Output: 58.03 Kb. compressed to 52.69 Kb. by saving 5.34 Kb. (9.20%)]
