Old October 1st, 2011, 13:29   #1
webtdi
TDI(s): 2006 Jetta
Default 2006 Jetta EGR valve?
​Hi guys, my 2006 Jetta is throwing the following code I have cleared it and it comes back instantly. Did some searching and from what I can tell I most likely have to replace the EGR valve. can some one confirm this for me.
I did also get the following 001027 - EGR Valve (N18): Malfunction but hasn't come back yet after clearing it once tho I haven't been driving the car.
Saturday,01,October,2011,14:04:13:15545 VCDS Version: Release 10.6.5 (x64)
Address 01: Engine Labels: 038-906-016-BEW.lbl
Control Module Part Number: 03G 906 016 AB HW: 028 101 223 8
Component and/or Version: R4 1,9L EDC G000SG 7550
Software Coding: 0050071
Work Shop Code: WSC 00066 000 00000
VCID: 63CE5D54DBCE
1 Fault Found:
001031 - EGR Potentiometer (G212): Signal too Low
P0407 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 104897 km
Time Indication: 0
Date: 2000.00.00
Time: 13:50:59
Freeze Frame:
RPM: 840 /min
Speed: 0.0 km/h
Load: 0.0 %
Lambda: -8.0 %
Mass Air / Rev.: 365.0 mg/str
Mass Air / Rev.: 130.0 mg/str
Bin. Bits: 00000000
Readiness: 1 1 0 0 1
webtdi is offline   Reply With Quote
Old October 1st, 2011, 15:47   #2
dieselfueler
dieselfueler's Avatar
have replaced several, my local dealership say they have replace plenty of them looks like another problem part in the BRMs
'04 PDWagon, RC3, VNT17,PD150 inj's,FO6S2 cam = 3rd gear wheel spin
356,000 miles
Respect, protect, and maintain complex systems - whether natural or of German design, to benefit from their full potential.
dieselfueler is offline   Reply With Quote
Old October 2nd, 2011, 12:26   #3
DidJettarun
DidJettarun's Avatar
Dieselfueler is correct....spend the money on a tune to delete the EGR and block off instead of replacing the EGR
2005.5 Jetta, package 2, RC 1+, DG Bypass Oil Filter,Metalnerd Magnetic Oil Plug
2003 Jetta GLS, Cat Fuel Filter
"When the people fear the Government that is tyranny; when the people fear the camshaft it's a PD
DidJettarun is offline   Reply With Quote
Old October 10th, 2011, 04:03   #4
codylent
I just blocked mine off and you would not believe the power & fuel economy difference!! I did mine because of a problem I was having but am going to do it to my wife's car also just to prevent a problem. I wish I would've done it years ago! I got a blockoff plate from dieselgeek.
codylent is offline   Reply With Quote
Old October 10th, 2011, 11:33   #5
MyAvocation
MyAvocation's Avatar
I'm not convinced it's a bad EGR... at least not yet. Last month I had this code and driveability issues outlined here:
P0403 - 000 - - - Intermittent
And these codes are set when disconnecting the EGR (which corrects driveability):
P0407 - 000
If it's a bad ground, non-EGR codes will also get set. If not, then trace the wiring harness back to the fuse box and look for chaffing.
MyAvocation is offline   Reply With Quote
Old October 14th, 2011, 10:49   #6
webtdi
TDI(s): 2006 Jetta
I finally got the EGR off last night. it's not all that dirty, deffinatly not plugged. I will trace the wire back to the box and look at the connection when I get home.
Originally the light came on the day after I had changed all of my filters. it was raining/snowing and cold I had just driven 2.5 hours (the return section of my trip) back into the city and stepped on the peddle to go it had no power. CEL came on.
At the next light stepped on it and it went. the CEL did go away for a while then came back. it drove ok for awhile then sitting at a light it started to sputter died then would not start. after about 5 tries it started. drove it back home (less than a block) left it for a couple of days. It then ran fine for a couple of weeks.
it started sputtering again that's when I parked it till I got the codes read.
Old October 14th, 2011, 19:49   #7
MyAvocation
If it dies at idle, then it could be a bad EGR. In the meantime, just disconnect the electrical connector on it. It will set a code, but the driveability issues should cease. The exception being if the valve stuck open and flooding the intake with exhaust.
Old October 17th, 2011, 21:38   #8
webtdi
TDI(s): 2006 Jetta
ok I've replaced the EGR valve with a new one. decided it was probably better to replace then to block it off as I live where it gets -40C regularly..
as soon as I cleared the fault code it returns. I have noticed that it idles alot smoother now.. tried to clear the code with and without the engine running same thing. it returns right away.
Old October 20th, 2011, 10:14   #9
blksmok
my '06 tdi has a loud hiss coming from under the car. I chased it to what I believe is a EGR actuator valve. I already have a tune in it from kerma so can someone point me to the "how to" to block off the egr?
blksmok is offline   Reply With Quote
Old October 21st, 2011, 13:30   #10
bombero
bombero's Avatar
The earth and our future generations thank you.
2006 Jetta TDI/graphite blue/dsg
My other diesel is a fire engine.
bombero is offline   Reply With Quote
Old October 25th, 2011, 15:02   #11
webtdi
TDI(s): 2006 Jetta
I've also pulled the airbox and looked at the one ground point. (looked ok.) thinking I'm going to pull the battery box and look at the connection there.
any other ideas why the code wont clear?
Old September 4th, 2014, 09:20   #12
released81101
TDI(s): 06 jetta
Default what does this mean
What is a tune? how do you delete the EGR?
released81101 is offline   Reply With Quote
Old September 4th, 2014, 14:45   #13
1998993C2S
1998993C2S's Avatar
Fuel Economy: 36 mpg..38, 44.5, 36, 37, 38
A "tune" is where the engines operating parameters stored in its ECU are modified from those of the manufacturer. Kermatdi is one and Malone is another of the popular TDI tuning paradigms. A local shop in your area will use either of the two and will "tune" your MY06 Jetta's 1.9 diesel. Cost varies but USD $300 or so is customary.
Our MY06 Jetta received a KermaTDI tune years ago when near new, at 10K miles or so. The tune level chosen was 1+ which is ever-so-slightly more aggressive than the stock VW tune. About 35-45ft lbs more torque, and a slight HP increase without a fuel use penalty.
Fast forward 8 years and 140,000 miles ..... the TDI charges on ...... A nice, fully optioned, under the radar, quality sedan.
Go for it ..
http://www.malonetuning.com
http://www.kermatdi.com
Cheers, MS
8/'06 Production .. Pkg2 .. Leather .. Navi .. Digital Sound w/Sirius XM .. DSG ..
... KERMA TUNE 1++ ... FSD dampers ... GTI alloy's 17"s ... Pilot Sport A/S 3 ... RoW OEM LED's ... R.Roll screen ... Dynaudio DSP active amplifier w/Dynaudio Spkr upgrade ... Under-the-radar aesthetic ... A long legged highway sleeper
1998993C2S is offline   Reply With Quote
Old February 9th, 2015, 22:43   #14
hoyce32
TDI(s): Golf
Default TDI Golf running weird
My Golf TDI does not want to get up to speed that fast, just really slow starting off. Then when on highway it sometimes will do 70 mph but will slow down to 60 mph with pedal to the floor. Does anyone know what's wrong? Is it EGR or something else?
hoyce32 is offline   Reply With Quote
Old February 12th, 2015, 09:29   #15
Lee_Taylor
Lee_Taylor's Avatar
Its considered bad form to tag a new question into an existing thread. Ideally you want to create a new thread as you are more likely to get a response. With that said at a guess I would say your MAF is faulty. You could try unplugging it and see if the engine runs any better. Or depending on how close to Madison WI you are you might want to get an expert to look at it JasonTDI a forum member has a shop in Madison. http://forums.tdiclub.com/member.php?u=7479
you can't make a machine idiot proof, the idiots are just too powerful......Oilhammer
Lee_Taylor is offline   Reply With Quote
Cleaning a 2006 EGR Valve VA Jetta TDI 101 8 July 13th, 2017 08:25
2006 - Hissing sound, blown EGR cooler valve, help? Diesel lifer VW MKV-A5 Golf/Jettas 70 June 30th, 2014 19:48
Wanted: EGR valve for 2000 Jetta wnytdi Private TDI Items for Sale/Wanted 0 April 5th, 2009 17:07
2003 Jetta EGR Valve ndamico Private TDI Items for Sale/Wanted 2 September 25th, 2008 09:52
EGR Valve 2006 gunships VW MKV-A5 Golf/Jettas 7 June 1st, 2006 12:03
Page generated in 0.19009 seconds with 10 queries
[Output: 125.49 Kb. compressed to 104.59 Kb. by saving 20.91 Kb. (16.66%)]
