Old September 30th, 2011, 12:12   #1
marshalldanielp
marshalldanielp's Avatar
Fuel Economy: 39.13 on first tank
Default New wheel bearing play?
Got the new bearing in. Then put the hub on. Prior to replacing axle bolt and control arm the hub seemed to have quite a bit of play, it wobbled. Axle nut and control arm replaced hub was tight and noise went away. Is this play normal?
Thanks,
Dan
marshalldanielp is offline   Reply With Quote
Old September 30th, 2011, 12:17   #2
Seatman
Seatman's Avatar
Fuel Economy: No idea
Yes totally, there's two bearings in the one shell and when you crank up the centre bolt it clamps the centres together which tightens the whole thing up.
Seatman is online now   Reply With Quote
Old September 30th, 2011, 18:29   #3
Powder Hound
Powder Hound's Avatar
Yeah, the axle nut clamps the bearing together with the CV joint on the inside and the nut on the outside. That's why the manual says not to put weight on the axle without the axle nut being properly tightened - if the bearing was loose and had the full weight of the car on it, it might peen the races in untoward places and ruin the bearing.
Old September 30th, 2011, 19:21   #4
marshalldanielp
Thanks guys. Appreciate it I was a little nervous. It was on my bil car and it was late last night so we just put it back together and it tighend up. Started mine tonight and those bearings are a pita. I got the driver side out and the new bearing in, cut the race off the hub. I think they are the original bearings, 212k and they are trashed. Back to work on it tomorrow. Thanks again.
Old September 30th, 2011, 19:27   #5
Seatman
Seatman's Avatar
The bearings are ok but easier to deal with if you have some welders gauntlets and a really big hammer lol Best to press them in though even a big vice can do it if nothing else.
Old September 30th, 2011, 22:39   #6
chewyboy
TDI(s): '00 NB TDI
Actually be careful with the whole "they should have some play" theory. Like i dummy i went with timkin a while back thinking they were still made in the us. They were not. Pressed them in, put them on the car torqued them down and grabbed the tire at 12/6. it had about 3/4" of play. Went over everything i did it was pressed in correctly. Removed the hub put it on the arbor press and put the full force of it down on the bearing as it should either blow it out or lock it up tight. neither happened, it was still flopping around horribly. Finally pulled the 2 out i did, took them back got replacements, refunds were no go, and since i was not going to do that again i took the timkins i got and decided to try something out with the new ones. I had a shaft i could put in the bearing while i pressed it in. again back to the press, pressed along the outer race when goning in the hub, pressed on the inner race when going into the outer hub. the new ones were just as bad, and i will never buy timkins again. pressed them out when i got the fag's, pressed the fags in and have not had any trouble since.
cliffs: sometimes you do get bad bearings and they flop around after being pressed in.
chewyboy is offline   Reply With Quote
Should the throwout bearing have play? dalchri TDI 101 1 August 21st, 2009 14:09
Wheel bearing play question-wrong hub? Long post-sorry. Pharmboy TDI 101 0 April 7th, 2008 10:24
Wheel bearing noise without wheel play? MrEd TDI 101 11 March 25th, 2008 12:05
Rear wheel bearing: Play can't be adjusted tornadored7 TDI 101 0 August 11th, 2007 16:33
Problem with Wheel Bearing Play Or??? Beowulf VW MKIII-A3/B4 TDIs 19 April 10th, 2004 00:11
Page generated in 0.12374 seconds with 10 queries
[Output: 74.69 Kb. compressed to 65.52 Kb. by saving 9.17 Kb. (12.28%)]
