Old September 30th, 2011, 03:29   #1
muresan_c_dan
Default 1996 A6 (C4) AAT, what ECU?
Hy guys, it's a nice thing you've got going on here!
I did use the Search tool, but I didn't really find anything, so here it goes:
Do you know what ECU is in the 1996 C4 with the AAT (85kw) engine? Could it, by any chance be the same as the AEL? (slightly detuned)...
If not, what would be an easy and reliable way of remapping the old style ECU?
Thing is, it I'd like to work out 150-170hp out of it, not pushing it because of the auto gearbox. I have to work on the injectors, so new (bigger) nozzles are not a problem, the turbo is on its way out, so in goes a hybrid (or perhaps a VNT, which I hear would spool smoother, and therefore be gentler on the g-box). ..and some other little bits...
Thank you, cheers
muresan_c_dan is offline   Reply With Quote
Old September 30th, 2011, 05:46   #2
saab9turbo
Fuel Economy: 5l/100km
Lift up the passenger side carpet and Check the number on the ecu cover, and post that, i belive that it's the same as the 2.5 aat audi 100 ecu coupled with the ecu for the gearbox.
But be carefull with the carpet, it tears pretty easy. I have the same car and auto box, and nozles give a good raise in overtaking
saab9turbo is offline   Reply With Quote
Old September 30th, 2011, 06:59   #3
muresan_c_dan
The sticker isn't looking so good, but it says:
Bosch 0 281 001 128
Audi 4a0 907 401
Other sticker isn't readable!
I guess the way around this would be to open the case, rip (carefully) the chip out, remap it, throw it (carefully) back in there.... and hope for the best. Wright?
Guess you can tell I'm new at this .
Thank you!
Old September 30th, 2011, 14:26   #4
saab9turbo
Rip the ecu out, or get one in a scrapyard and send it to someone that can tune it that is cheaper than risking terminal dammage to the ecu
WTB: Third Row Seats for B4V and/or Audi C4 A6 Avant Green Waters Private TDI Items for Sale/Wanted 10 December 28th, 2010 12:24
Audi A6 C4 TDI 2.5 104Kw 5cyl. boji55 TDI Power Enhancements 1 August 20th, 2008 08:29
94 and 95 A6 AAT K line problems twm OBD Scanners 2 April 2nd, 2007 00:52
AAT code Audi A6 2.5 TDi motor upgrades Ghia Other VW Group TD(I)s 1 March 2nd, 2006 17:29
Audi A6 2.5TDi (AAT code) 1996 5 Cyl Diagnostic wiring.. Ghia TDI Conversions 5 November 20th, 2005 18:41
Page generated in 0.14484 seconds with 10 queries
[Output: 61.44 Kb. compressed to 55.10 Kb. by saving 6.33 Kb. (10.31%)]
