Old September 30th, 2011, 02:47   #1
redline808
TDI(s): Jetta
Default 2002 injection pump leaking diesel?
i just noticed a diesel fuel leak on my injection pump, it seems to be coming from the bottom section of the injection pump, i only say that because i didn't notice any wetness coming from the top half. but i did not bother to check the back side of the injection pump? car runs fine. any thoughts. i drew an arrow pointing at the fuel drip forming.
thanks.
redline808 is offline   Reply With Quote
Old September 30th, 2011, 03:02   #2
Strykeviper
Fuel Economy: '01 33-39; '00 40-53
Dry off the pump and then start the car and look for where the leak is coming from. Check the two upper seals and the o-ring at the pump head, these are common places for fuel to leak. If it comes from the top, it is easy to change those gaskets but you will need a special bit to remove the security screw. If it comes from the o-ring at the front, contact a guru or do a lot of research before attempting to change the seal. Otherwise you may have to replace the injection pump if you mess up with that seal. Don't ask how I know
'15 Passat TDI SEL 36k
'00 Jetta TDI, 226k, Atlas skid plate, 3 Pedal Mod, DG short shifter
'01 Jetta TDI, 188k, Atlas skid plate, 3 Pedal Mod
Strykeviper is offline   Reply With Quote
Old September 30th, 2011, 10:58   #3
horsieclatter
what he said^^^^^
horsieclatter is offline   Reply With Quote
Old September 30th, 2011, 23:37   #4
Redneck Truck
Gone, but not forgotten
Redneck Truck's Avatar
I'd check hose and line fittings too.
- Still parting a 2002 4-door reflex silver Golf TDI 5-speed.
- Still parting most of 2001 Audi TT 225 6-speed engine bay.
Please help me clear out my garage. PM me.
Redneck Truck is offline   Reply With Quote
Old October 1st, 2011, 04:49   #5
MrSafety
Newbie at Heart
Fuel Economy: ~35 mpg "as was" when purchased TDI
In finding such leaks, I find it useful to first spray the entire pump with a water soluable degreaser ["Simple Green"],
then wash off with water... and finally dry it off with compressed air or a strong leaf blower!
After the above your chances of seeing the source of the leak are much better when you start up to look again!.
Also a blue paper towel that is typically used in shops is good to "dab" wherever you suspect a leak...
as these towels turn dark when wetted!
It's probably a good idea to invest in a gasket/seal kit for your IP.
These run about $25.00!
Remember, the smaller-the-leak, the harder-it-is-to-find!
Regards,
Sam
Son's 2002 Jetta TDI 01M / My '81 Rabbit "Caddy" project / My '80 240D MB...
Other Projects
: Safe Intake Cleanout / IP-QA Craniotomy /
Working on way for DIYers to more fully FLUSH 01M trans as well as check/"top-off" the O1M Fluid Level.
Perform diesel purge without ingesting troublesome air !
Last edited by MrSafety; October 1st, 2011 at 04:52. Reason: [edit] in Bright Blue!
MrSafety is offline   Reply With Quote
Old October 2nd, 2011, 09:50   #6
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
Classic pump head seal leak (probably in addition to other leaks). I can see it puddled up in the accessory bracket bolt reccess.
Check out the link in my signature.
runonbeer is offline   Reply With Quote
Old October 2nd, 2011, 10:04   #7
runonbeer
I would personally avoid using simple green on the aluminum injection pump and all other surrounding aluminum components.
I use permatex earth soap with fantastic results.
Old October 2nd, 2011, 12:14   #8
TDI_bubble
Since the majority of the main case looks dry, its most likely the head seal oring where the cast aluminum/steel are at. Very common, I would replace the top seals while your at it, and reset the IQ/timing in one shot. If you have vagcom that is.
TDI_bubble is offline   Reply With Quote
Old October 2nd, 2011, 12:17   #9
MrSafety
Newbie at Heart
I use permatex...
Is Simple Green corrosive to aluminum?
Sam
Other Projects
Old October 2nd, 2011, 17:58   #10
TDI_bubble
http://www.simplegreen.com/solutions...query=aluminum
For regular things, sure. It takes corrosion off, but that corrosion is aluminum's corrosion.
Old October 2nd, 2011, 20:15   #11
MrSafety
Newbie at Heart
Thanks for information on the citric-based Simple Green solvent... and it makes good precautionary sense where it says:
" Therefore, contact times for unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow -
never for more than 10 minutes."
We have found in general that it was never necessary to let Simple Green soak very long...
and of course it makes sense that one should take special caution on thin aluminum plate on the skin of aircraft
where you probably do not want to take off the natural protective layer of corrosion that forms on aluminum !
Regards,
Sam Ross
Other Projects
Old April 23rd, 2012, 01:42   #12
redline808
TDI(s): Jetta
just an update, i have not replaced the seals in my ip yet. i have been slacking, mostly because it stopped leaking the day after i started driving on svo. now in diesel or svo, perfectly dry. i really should change the seals, my thoughts now are the seals have swelled up because of the svo and might be breaking down and being fed into my injectors?
Old April 23rd, 2012, 15:59   #13
MrSafety
Newbie at Heart
Default ... What is SVO...
What is "SVO"... some kind of alternative fuel?
Sam
Other Projects
Old March 6th, 2014, 10:35   #14
Dieselnoob
Default Bump
Will the pump head leaking be to the extreme that it can cause the pump to loose its prime, causing a no start? I ask because I believe this is what's happening with mine. I'll be getting the new seal kit next week, but wanted to know if I'm headed in the right direction.
Dieselnoob is offline   Reply With Quote
Old March 6th, 2014, 10:47   #15
Ski in NC
Fuel Economy: 48-52 typical
Yep, if fuel leaks out while running, air can leak in while shut down. But leak would have to be pretty bad for that to happen. Suspect filter therm tee or shaft seal first.
My pump was leaking similar to OP's. It was hard to determine exactly the leak location, but there was wetness under the top cover/QA. I got the seal kit and decided to just do the two top seals first, as they are easier. That cured the leak. Head seal is apparently still holding.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Injection Pump Leaking sfla2002tdi TDI 101 6 September 3rd, 2011 04:20
Leaking injection pump Ivanp VW MKIV-A4 TDIs (VE and PD) 12 March 22nd, 2009 17:10
'96 jetta diesel leaking Injection Pump kevin mott TDI 101 3 March 23rd, 2008 17:43
Leaking 96 Diesel Injection Pump.(Jetta TD)Please help ! wandaz TDI 101 2 August 20th, 2006 05:34
Leaking 96 Diesel Injection Pump.Please help ! wandaz Other VW Group TD(I)s 0 August 19th, 2006 21:38
Page generated in 0.17639 seconds with 10 queries
[Output: 127.33 Kb. compressed to 106.44 Kb. by saving 20.88 Kb. (16.40%)]
