Old September 29th, 2011, 16:19   #1
AV8RLEO
Fuel Economy: 45.8 - 48.8 when bringing it home!
Default Computerized Timing Adjustment...
Sorry, didn't have time to search the forums right now. Will probly try from home computer later...
At any rate... my uncles auto shop happens to have a Snap On Solus Pro scan tool. We have the VW connectors and "personality key." I was able to get into everything and look around and even got to the VAG section for timing adjustment but cannot seem to make any changes...
Has anyone else had these same issues and is it because I don't have the "official VAG-COM" software?
I'll try to get a screen shot of what I see and see if y'all have any suggestions...
Thanks!
___________________
2003 Volkswagen Jetta TDI - 251K
2003 Chevy Silverado HD Duramax - 173K
AV8RLEO is offline   Reply With Quote
Old September 29th, 2011, 16:48   #2
Seatman
Seatman's Avatar
Fuel Economy: No idea
You don't change it digitally, you move the pulley on the pump back or forth to alter the timing.
http://forums.tdiclub.com/showthread.php?t=240450
Seatman is offline   Reply With Quote
Old September 29th, 2011, 17:38   #3
chromeBuddha
chromeBuddha's Avatar
Fuel Economy: 47 mpg @ 75 mph
Check the A4 timing belt change procedure, page 110, with the change that you bump the handle of the wrench toward the front of the car (which I think of as clockwise) to advance the timing...
http://pics2.tdiclub.com/pdf/a4timingbelt.pdf
2002 Golf TDI, 5-speed, 2-door
White w/ Tan interior (get the Scotchguard!!!)
47 mpg @ 75 mph
"El Bonbon" - The Marshmallow
chromeBuddha is offline   Reply With Quote
Old September 30th, 2011, 05:18   #4
Corsair
Corsair's Avatar
Fuel Economy: 52/48/??
^^ x2. With that engine, the VCDS is used to look at the dynamic timing, to see where it is, not to alter it. The alteration is made by loosening the 3 bolts that hold the injection pump sprocket to the hub. Essentially the sprocket (and all the rest of the engine) remains still while you put a wrench on the big bolt (nut?) on the center hub and turn it (and the 3 bolts rotate along with it because they thread into the hub). Then tighten the 3 bolts. Viewed as I described it there, rotating the hub clockwise advances the injection timing. (That is, if you have a wrench on the center bolt / nut of the hub, wrench sticking up out of the engine bay, pull the wrench forward to advance the timing.) One note: That is a super sensitive adjustment. Rotating the hub JUST A HAIR makes a big change on the VCDS graph.
Best Regards.... Corsair....
2002 Jetta GLS TDI 5-spd 325Kmi, 2014 JSW TDI 6M
2006 Audi A4 Quattro Avant 2.0T 6M
2004 Jetta GL wagon 2.0L (gas) 5-spd (sold)
[also had 03 TDI GLS 5spd wagon bought new, sorely missed]
Corsair is offline   Reply With Quote
Old October 3rd, 2011, 08:28   #5
AV8RLEO
Thanks guys... feeling a little on the foolish side now, but hopefully I can figure it out from here!
This is the timing readout I took a picture of...
https://picasaweb.google.com/1000870...eat=directlink
Thanks again!
___________________
Help with timing adjustment pbraunton Ontario 6 April 15th, 2011 09:02
timing adjustment? abrier1 TDI 101 5 November 19th, 2007 08:31
does my timing need adjustment? basskleff TDI 101 4 April 24th, 2007 12:26
Timing belt timing adjustment question 011852 VW MKIV-A4 TDIs (VE and PD) 4 October 1st, 2005 11:30
making a computerized diagnostic system for TDI Fred_Delamarre VW MKIV-A4 TDIs (VE and PD) 5 January 27th, 2000 05:02
Page generated in 0.13178 seconds with 10 queries
[Output: 69.91 Kb. compressed to 61.85 Kb. by saving 8.06 Kb. (11.53%)]
