Old September 25th, 2011, 19:47   #1
GrampaPete
Question Do I have to buy VW windshield wipers?
I bought a couple of Bosch Icon blades but they are for the J hook type arms. I am surprised and confused that these blades don't seem to be correct. What choices do I have for the wiper arms that are on my car?
Thank you,
Pete
GrampaPete is offline   Reply With Quote
Old September 25th, 2011, 19:58   #2
leicaman
leicaman's Avatar
Fuel Economy: Much better than the average car... :o)
Did you look up blades from www.worldimpex? You could also shoot idparts.com an email and they may be able to point you in the right direction. They helped me when I needed new trunk struts and saved me a TON of cash. Or you could get a decent discount at motorville and use their new online system of ordering parts to be shipped right to your house. Their web is www.vdubparts.us
2015 Golf SE TDI with DSG, 50k.
2005 Passat GLS TDI - RIP, 208k miles. Many good memories and friends made with this car.
leicaman is online now   Reply With Quote
Old September 26th, 2011, 05:08   #3
thundershorts
the oem blades are quite good
"You can't argue with a fool..."
thundershorts is online now   Reply With Quote
Old September 26th, 2011, 05:41   #4
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
The Icons should have come with an adapter to work with your arms. Mine did.
-tom
autos: 15 Volvo V60, 08 MB E320 Bluetec
Find your VW part numbers here.
Why I recommend fuel additive.
tditom is offline   Reply With Quote
Old September 26th, 2011, 05:54   #5
Alchemy
Alchemy's Avatar
Fuel Economy: N/A
Goodyear is now making something similar to the Bosh Icon, and the rubber insert is easily replaced which keeps cost down. I bought ours at Costco, but other places may have them as well. At Costco they were $8 each.
The replacement rubber parts can be bought through Impex. http://www.worldimpex.com/item_detail.html?sku=178825
Past as of 12/9/2016 - 2012 Jetta Sportwagen TDI - Platinum Gray, Black, DSG, Panoramic Roof
Past: 2005 Passat GLS TDI Wagon - Silverstone w/ Anthracite Leather - Unchained
Past: 2000 Jetta GLS TDI 5 Speed - Galactic Blue w/ Tan Leather
Alchemy is offline   Reply With Quote
Old September 26th, 2011, 10:38   #6
rydogg
TDI(s): Passat
I've been using Rainex replacements that fit my Passat with no problems. They retail for ~$25ea but you can usually find a sale once or twice a year that bring them to ~$10ea price range. I will usually stock up then. Start with Amazon.com and check locally too.
Unchained!!
rydogg is offline   Reply With Quote
Old September 26th, 2011, 10:50   #7
ruking
Fuel Economy: 62/50/44mpg, normal commute range 48-52 mpg:09 Jetta TDI, 47/43/39, normal commute range 39 -43 mpg: 12 Touareg TDI, 39/31/29 mpg:
While the later models use a different design, I have to agree on a 2003 set of oem windshield wipers. After 170,000 miles and/or 8 years, they just keep on keeping on. My ("new") replacement oem set is going on 7.5 years old, still in the packaging.
ruking is offline   Reply With Quote
Old September 26th, 2011, 19:58   #8
owr084
I got tired of prying my OEM wipers apart to remove the blade and replace it. I went with the Goodyear ones at Costco and they work fine.
RBB
2005 VW Passat GLS TDI (Chipped, BSM delete, and Manual ), 2007 VW Eos 2.0T, 2015 Toyota Sienna XLE, 2017 VW Jetta SEL 1.8T
owr084 is offline   Reply With Quote
Old October 3rd, 2011, 18:46   #9
Fishninja
I have replaced mine once in 200k with geuine vw wipers from the stealership for 22 bucks each and there still wipin good, so with that kinda service ill keep on payin the stealership for wipers.
Fishninja is offline   Reply With Quote
Old October 14th, 2011, 22:20   #10
CoasterMoose
CoasterMoose's Avatar
NAPA sells what I would call OEM quality wiper blades for under $20 each. On the B5.5 wagon, they are incredibly simple to replace. Not sure what the references to prying wipers apart is all about....
Moose
____________________
Former Owner of a wonderful 2005 Passat TDI Wagon - Unchained on Leap Day 2012
CoasterMoose is offline   Reply With Quote
Old October 15th, 2011, 07:42   #11
Alchemy
Alchemy's Avatar
Fuel Economy: N/A
Regarding the 'prying the wipers apart'...
You can replace just the rubber wiper piece on Bosch Icon blades, but there is a tab that holds the rubber securely in place. You must pry that tab up first before sliding the old one out and installing the new one. Takes a few minutes, but I forget about that darn tab every time and realize it after struggling for a few minutes.
The Goodyear ones are very similar in construction to the Icons but do not have the tab.
Steve
Old October 17th, 2011, 08:01   #12
butcher
Fuel Economy: GREAT!!
I change my wipers once a year, I hate streaks. So I changed the wiper arms to a 2000 model passat, easy to change and cheap from the local vw parts guy($10 for both) now I don't have to worry where to buy wipers.
The older Passat arms are generic fittings so any wipers work on them.
2006 Jetta TDI - DSG "new engine, new turbo, new flywheel at 75 k!"
2005 Passat Wagon GLS TDI - "Chainless!"
2009 R320 Bluetec
butcher is offline   Reply With Quote
windshield wipers Chet57 VW MKV-A5 Golf/Jettas 5 July 31st, 2011 12:27
Windshield wipers liz11150 VW MKV-A5 Golf/Jettas 18 February 24th, 2011 07:35
Windshield wipers Intech Upgrades (non TDI Engine related) 26 December 3rd, 2009 19:35
Windshield Wipers farfrumsanity VW MKV-A5 Golf/Jettas 1 December 15th, 2005 18:53
Windshield Wipers DerDieselmann TDI 101 15 February 15th, 2003 17:52
Page generated in 0.12651 seconds with 10 queries
[Output: 107.34 Kb. compressed to 90.02 Kb. by saving 17.32 Kb. (16.13%)]
