Old September 25th, 2011, 17:07   #1
jd9996
Default check automatic transmission fluid
I have a 2001 Jetta and I have searched the forum and I can not find how you check the automatic transmission fluid level. Do you check it running or not running? Thanks, David
jd9996 is offline   Reply With Quote
Old September 25th, 2011, 17:10   #2
davebugs
I know htere is a procedure because I've followed it.
I think it requires a lift and vag-com to do properly. And a gizmo I concocted to all fluid.
Gotta be at a certain temp, car running, etc.
davebugs is offline   Reply With Quote
Old September 25th, 2011, 18:31   #3
FL/COtdi
FL/COtdi's Avatar
IMO automatic fluid should be changed every 40,000 miles, because the transmission will need that frequency to survive. This thread below should tell you most everything you need to get started:
http://forums.tdiclub.com/showthread.php?p=288052
You can also go to advanced search options and look for posts by CoolAirVw. He know most everything about your automatic;-)
Mal2egr, DG skid/side skirts/oil filter, Nick ff, froheat, Koni FSD, Shine springs/rsb, fsb delete, 11mm, BPP 764, wavetrac 3.19/.917/.658, sbc2daily, 108mm, 256k miles, 3" fat cat
FL/COtdi is offline   Reply With Quote
Old September 26th, 2011, 04:54   #4
davebugs
I service mine every 40-50k. My second tranny just exploded. This was a VW reman that lasted 155k (original on elasted 60k). Both had differential failures.
I've never had any valve body issues - perhaps it is due to the maintenance.
And in this tranny I did service the diff at about 100k.
Old July 17th, 2014, 19:29   #5
JOHN1226
TDI(s): 2005
Default 1997 jetta 2.0 w/automatic trans
How to check trans fluid. With engine running or not in park ?
JOHN1226 is offline   Reply With Quote
Old July 18th, 2014, 05:02   #6
Tdijarhead
Here you go coolairvw's website with step by step instructions and best of all pictures.
http://www.kansascitytdi.com/01m%20faq.htm
Tdijarhead is offline   Reply With Quote
Transmission Fluid Change - Automatic vs Manual Transmission tca32123 TDI 101 11 May 20th, 2014 18:32
Considering Royal Purple Automatic Transmission Fluid in the 01M Transmission... rezmarian VW MKIV-A4 TDIs (VE and PD) 5 July 28th, 2011 08:12
automatic transmission fluid don1 VW MKIV-A4 TDIs (VE and PD) 1 March 16th, 2011 09:33
Automatic Transmission Fluid Changes Kier Fuels & Lubricants 15 March 31st, 2006 08:09
How do you check the automatic transmission fluid tango_28 VW MKIV-A4 TDIs (VE and PD) 1 August 18th, 2004 15:27
Page generated in 0.11592 seconds with 10 queries
[Output: 73.75 Kb. compressed to 64.76 Kb. by saving 9.00 Kb. (12.20%)]
