Old September 25th, 2011, 14:35   #1
Iflyasa
TDI(s): 06 Jetta TDI
Default Removing headlamp assembly
I can't really find anything on the search link. I have an 06 Jetta TDI, and I am going to replace both headlamps completely. Is there a link for this? I have read where the bumper has to be removed to get to the bottom screw of the headlamp. Other than that, I am going in blind. Any help would be appreciated.
Thanks!!
Iflyasa is offline   Reply With Quote
Old September 25th, 2011, 15:28   #2
2004STARWARSTDI
2004STARWARSTDI's Avatar
Default Headlight assembly removal
Switch off electrics & remove key
unlock & detach headlight assembly electrical connector
remove front bumper cover>
remove front radiator grill
remove lower sound absorber(skid plate) under engine
remove upper & lower bumper cover mounting bolts
unscrew bolts from inside front fender
disconnect harness connector for outside air temp sensor(mounted behind lower left bumper cover grille) Disconnect harness connectors from behind bumper
With a helper, pull bumper cover parallel out of fender mounts
remove headlight mounting screws
Really need a Bentley to see picture of where all the screws are located.
Yes you have to remove bumper cover to access that bottom screw to headlight assembly.
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2014
A4 Limp Mode,A4 fan troubleshooting
Glow plugs 101 Ver. 2.0
Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Old September 25th, 2011, 15:45   #3
Stool Sample
youtube link
Stool Sample is offline   Reply With Quote
Old September 25th, 2011, 20:19   #4
bhutchins
bhutchins's Avatar
Fuel Economy: best 47
you could follow most of the dynabeam install http://dynabeam.hella-online.com/EN/...tage_jetta.pdf
Sold : 234 WHP / 404 WTQ (550 N-M)
bhutchins is offline   Reply With Quote
Headlamp assembly, 2002 Jetta TDI sedan Wntrmoon TDI 101 3 August 7th, 2011 12:40
Removing front head light assembly ExtremeMachine476 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 4 December 21st, 2010 20:37
Fallen Headlamp Assembly passat77445 TDI 101 0 December 28th, 2009 11:25
Removing turn signal switch assembly? Zero10 VW MKIV-A4 TDIs (VE and PD) 9 December 22nd, 2008 12:58
HEADLAMP ASSEMBLY FOR 96 PASSAT colaska Private TDI Items for Sale/Wanted 0 February 14th, 2001 11:43
Page generated in 0.10738 seconds with 10 queries
[Output: 63.49 Kb. compressed to 56.87 Kb. by saving 6.62 Kb. (10.42%)]
