Old September 22nd, 2011, 19:09   #1
WelderTeacher
Angry 05 Passat Trans code 0741
About a month ago I purchased a used 2005 Passat with 106,000 miles. Within 200 miles I had the fault code 0741 come up twice. The dealer took it to local VW/Audi Tech and had him check the codes and service the tranny. Well here we are a few weeks later and the code has appeared again. The dealership is reluctant to deal with me on this and is suggesting it be serviced again, am I looking at a new trans or a torque converter?
WelderTeacher is offline   Reply With Quote
Old September 22nd, 2011, 20:51   #2
s4phillips
s4phillips's Avatar
Location: Live in d/FW, TX. Transplanted from the Pacific Northwet
If it hasn't been driven a lot with a bad torque converter, you probably just need a new torque converter.
Perform scheduled maintenance; drive more, worry less; balance shaft module; drive more, worry less; torque converter; drive more, worry less...
2005 Passat Wagon TDI w/gear driven buzz reducer and lubricant circulator
2002 Beetle TDI
2003 DL1000K3
s4phillips is offline   Reply With Quote
Old September 22nd, 2011, 22:09   #3
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Wow, another one...this is getting all too common.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old September 23rd, 2011, 01:00   #4
afarfalla
afarfalla's Avatar
I believe your TC is toast, a few other things you may want to consider...have these been changed or performed...BS module, alt pulley, glo plug mod, brake light switch, timing belt, water pump, tensioners, what oil was used at oil changes (505.1)?, how is the cam...what did I miss? Did you check this site before you bought it? If you didn't it could get expensive
afarfalla is offline   Reply With Quote
Old September 23rd, 2011, 06:01   #5
hevster1
TDI(s): 98 NB
Fuel Economy: 40-42
Converters are available from your dealer or Erickson in CT. Honestly it is hit or miss with Erickson. However the price is 1/2 of what you would spend on OEM. You will also need to drop the pan again and replace the fluid and filter (this is a precaution). Honestly, you will probably eventually need a whole unit anyway.
NJ's best shop performing Quality Repairs on TDI's, Toyota, Lexus, Scion and other European and Asian cars as well as Motorcycles & ATV's. Written warranty, reasonable prices. ASE L-1 & A-9 Master re-certified. NEW LOCATION: Montague NJ. Hunter Wheel Alignment. Snap-on Tire Service.I don't need to have specials, my prices are better already!
www.mmautocycle.com
hevster1 is offline   Reply With Quote
Old September 23rd, 2011, 06:03   #6
aja8888
aja8888's Avatar
Motor mounts, plenum chamber re-seal, sunroof drain fix, ground cable by turbo hose tie off, etc.
Old October 6th, 2011, 11:52   #7
MacVWTDI
MacVWTDI's Avatar
My wife's B5 with 180K is throwing the 0741 code also.
It just recently started actually showing symptoms of TC failure though I think.
Doesn't always lock up in reverse - revs and then jumps into reverse hard;
Rough downshifting at times.
She stopped at a light this morning and went to go again and it balked completely.
Am I looking at a full tranny rebuild?
* 2005 Passat TDI Wagon - 185K and still tickin' *
* 1997 Ford F350 w/ 7.3L PS *
MacVWTDI is offline   Reply With Quote
Old October 7th, 2011, 01:34   #8
thundershorts
could be a trans failure, but low fluid will show same symptoms. however unless trans is topped up immediately, damage will occur. Drum and clutch D will affect reverse as you describe.
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Auto Trans 05 Jetta MKIV GPC Code 50K Miles cinergyswedge Private TDI Items for Sale/Wanted 1 April 15th, 2011 14:13
FS: Auto transmission 04 05 VW Passat 2.0 TDI GMR code andytdiland Private TDI Items for Sale/Wanted 1 September 15th, 2010 07:18
Multi-Funct Trans Range (TR) Switch 05 Passat TDI For Sale $125 OBO! lctalley Private TDI Items for Sale/Wanted 1 January 22nd, 2010 06:43
96 1z glx code 0741-27-10 brake pedal monitoring ninedee_golf_tdi OBD Scanners 10 November 13th, 2009 09:57
05 passat engine and trans afarfalla Private TDI Items for Sale/Wanted 9 October 30th, 2009 19:15
Page generated in 0.12651 seconds with 10 queries
[Output: 87.20 Kb. compressed to 75.05 Kb. by saving 12.15 Kb. (13.93%)]
