CoolAirVw
Was driving a customers 06 jetta DSG and the trans quit moving entirely. I had a feeling it was the flywheel, and when I pulled the trans out I found....
Splines where the input shaft ride were completely stripped.
Here's the trans input shaft splines.. a little "roughed up" but ok.
Here's the splines on the new flywheel.
This was an expensive repair but better than a new trans! (which of course wouldn't have fixed it)
Edit: 5-5-16 guy called me from texas today and said his quit moving so I was thinking of how this could be confirmed. I think if someone watched the measuring blocks they could see the input shaft spinning or not spinning. If the flywheel splines are stripped then the input shaft speed sensor probably would show zero. So at idle the input speed sensor should basically match engine RPM. Never confirmed this but I will on the next DSG I drive.
