Old September 17th, 2011, 08:09   #1
Default How much $$$ to change glow plugs and harness 2002 Jetta?
Just want to know ball park $$ parts and labor to change out 4 glow plugs with new and a new harness on a 2002 Jetta.
1. Dealer
2. Guru
96 Passat TDI wagon ~145k SOLD!
92 Ecodiesel 205k
dieseljunkie is offline   Reply With Quote
Old September 17th, 2011, 08:38   #2
If everything is at it was, you're better off doing it yourself, the 02 has the 4 wire harness, which (if they cut off the plug) is gonna be annoying to fix, if not it's a plug and play deal. For glow plugs you're probably better off going to a local Auto parts store, they generally carry em for around 15 dollars a piece, the glow plug harness usually costs around 65$
Dealer, I would assume they charge around 200$ total, and as for guru I have no idea.
Good luck!
VAG-COM owner
2001 GL, Stage 2 Clutch, Lightweight Flywheel, Dieselgeek Racepipe, Titan 764's (.234) Ceramic brake pads, 11mm Injection pump IN! 10/30/2011, Bilstein TC Sports front & back!
kenmaira is offline   Reply With Quote
Old September 17th, 2011, 12:17   #3
Fuel Economy: 43/41/40
#2 will determine if you need new parts or not.
JB05 is offline   Reply With Quote
Old September 17th, 2011, 12:59   #4
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
Glow plugs are what I was Googling when I discovered these forums. Dealer wanted $500 to do the job on the Golf, and that was 2004. Found the how-to here, and did it myself for around $135.00.
-George Bernard Shaw
Old September 17th, 2011, 13:03   #5
Fuel Economy: 5.3 l/100 km (at 115 km/h)
We've heard of dealerships charging as much as $800 for this...
4 Bosch / Beru ALH glow plugs from one of the online suppliers here: ~$45 - $50
4-wire ALH harness: ~$60 - $65
Should take between less than an hour (if you splice the harness) to about 90 - 120 minutes (if you run the wire back to the connector near the brake booster)... unless one of the glow plugs breaks or has stripped threads...
Pereat mundus, fiat musica!
ymz is offline   Reply With Quote
Old September 17th, 2011, 18:06   #6
Curious Chris
Fuel Economy: 47/42/38
On my 2002 Golf (should be the same as your Jetta) I installed the glow plug harness and then use cable cover over the 4 wires and routed it over to the plug in under the curved plastic cover by the master cylinder. The original wire is wrapped up with a number of other wires and I have seen a post where a member unwrapped the whole works but my method was fast and it worked.
Harness: http://www.idparts.com/catalog/produ...roducts_id=606
glow plugs http://www.idparts.com/catalog/produ...oducts_id=1077
Wavetrac LSD, Bosch 230'a with RC4.5, Whitbread 2.5" downpipe, PD lift pump, South Bend Stage 2 Endurance Clutch, steel skid plate, Wingnut inspired EGR mod, MyCruiseAgent no drill EGT, MoGolf skidplate mod
Curious Chris is offline   Reply With Quote
Old September 17th, 2011, 20:05   #7
I have done this job myself on my 2002 jetta TDI automatic. The cost came as follows: 4 Bosch glow plugs thru ebay $52, harness about same. If you were near me, I could have done for $50 for labor (my cost for tea, lunch, cleaning, rags, etc.) if you provide the glow plugs and harness and left the car for two days. But to be honest, replacing the harness is an easy work so I would encourage you to do yourself if you have time. Remove the battery and battery plate, remove air box, open the harness plastic cover. Starting from the glow plug side, carefully unwind the plastic insulation (tape). Use heat gun to "slightly melt" the insulation glue and unwrap it over a pencil. Once you reach the harness connection on the firewall, remove the old one and replace with the new one. Have harness wires (four) follow the curvatures of the other wires in the bundle. After that reuse the insulation that you unwound. The work is time consuming though but worth doing rather that cutting here and there that should not take more that 20 minutes but will not look good or professional. I was getting the check engine lite with the code for faulty glow plug. Only after replacing both my problem got solved.
One think to need in mind: Not to ruin the threads of glow plugs. Also be carful to remove the glow plugs if they have never been removed before. So use WD-40 so that it seems inside. Use right size socket and keep its axis in line with the axis of glow plug. Once the glow plugs are out, replace by hand tightining till it reaches the bottom of threads. That tighted it a little more.
Dodoma is offline   Reply With Quote
Old September 18th, 2011, 18:40   #8
msiert's Avatar
Fuel Economy: Record 703 miles
Just as easy as changing out spark plugs in an older car.
Don't even need to check which one is bad. Just take them all out and replace the ones that has black soot on them the good ones will have clean tips.
Just got done replacing a bad one last weeK......I feel theres no need to replace all of them if only one or two are bad.
msiert is offline   Reply With Quote
Old September 18th, 2011, 18:54   #9
Easy job. Really.
I'd buy from any of the vendors here. My car took BERU and I just replaced the harness the second time. I put doelectric grease on the harness and glow plugs. I bought special high temp anti-seize for them too.
Got the heat shrink gizmo's to put over the connections.
davebugs is offline   Reply With Quote
Old September 20th, 2011, 19:53   #10
I just did this earlier [save the gp harness]. The plugs are a cheap [if aftermarket shop] and easy [just don't strip them] job you can do in 20 min.
2002MK4 is offline   Reply With Quote
'02 Jetta TDI - P0672 CEL - Glow Plugs and Harness already replaced! TheElite0ne TDI 101 3 January 18th, 2011 12:36
2002 Jetta TDI Glow Plug Harness for sale bostondeezel Private TDI Items for Sale/Wanted 1 October 12th, 2009 15:54
WTB: Glow plugs and glow plug wiring harness (01 Jetta) TDI_NC Private TDI Items for Sale/Wanted 2 January 5th, 2006 08:02
Glow plug CEL with new glow plugs and harness dslemaire VW MKIII-A3/B4 TDIs 6 November 9th, 2004 15:24
'98 Jetta, testing glow plugs, harness, etc. davemc VW MKIII-A3/B4 TDIs 12 January 29th, 2004 20:35
Page generated in 0.13113 seconds with 10 queries
[Output: 96.43 Kb. compressed to 81.69 Kb. by saving 14.74 Kb. (15.28%)]
