Old September 14th, 2011, 17:18   #1
brett.knutson
Default AC Compressor won't engage
Hopefully someone can help me out... Due to a military deployment, my '02 Jetta TDI sat for several months without being driven. When I returned, it started right up (after a jump start) and ran perfectly fine, except no AC.
The console button illuminates, the cabin fan blows, and the radiator fans both operate, but the compressor doesn't engage.
I ran battery voltage to the compressor and the clutch does click.
I tested the coolant temp sensor and the fans will run properly (both low and high speeds).
The high pressure switch connector has 12 vdc at pins 1 and 3.
After all those tests, could it still be the Fan Control Module? Or, is there another test I can try, without having any pressure gauges?
Should I try to add a can of R-134?
Any assistance or recommended gurus in the Northern VA area would be greatly appreciated...
brett.knutson is offline   Reply With Quote
Old September 14th, 2011, 17:26   #2
chromeBuddha
chromeBuddha's Avatar
Fuel Economy: 47 mpg @ 75 mph
You can bridge the pins on the high pressure switch and see if the compressor clutch clicks in...
With the compressor not running, you ambient pressure should be around 100 PSI. If you check this and the pressure is next to nothing, you may have a leak and your coolant may have leaked out. Your electrical testing seems like it has covered most of the bases.
2002 Golf TDI, 5-speed, 2-door
White w/ Tan interior (get the Scotchguard!!!)
47 mpg @ 75 mph
"El Bonbon" - The Marshmallow
chromeBuddha is offline   Reply With Quote
Old September 14th, 2011, 17:28   #3
brett.knutson
I don't have pressure gauges... Which pins on the HPS do I bridge?
Old September 15th, 2011, 07:40   #4
KLXD
Don't these systems have a low pressure switch to keep the compressor from running with no refrigerant in the system?
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old September 15th, 2011, 07:45   #5
gquenstedt
NO NO NO!
This is not a 1987 Chevy we're talking about.
Usually if the fans come on when you turn on the a/c, then the FCM is getting the go ahead from everything that it needs to turn on the a/c, but is just not sending power to the clutch coil. I would replace the FCM with one from a reputable vendor. NOT ebay.
Check out my website: www.gqlaw.us
gquenstedt is offline   Reply With Quote
Old September 15th, 2011, 10:18   #6
chromeBuddha
Originally Posted by gquenstedt View Post
NO NO NO!
The bridging of these pins to test the high pressure switch is in the Bentley manual. I will get the section and page # if that will put you at ease.
Brett,
I believe it would be pin 1 to 2, meant to confirm in the manual last night but was whipped. Will check it tonight.
In re-reading, I meant the pins on the connector, not the switch. Bridging anything on the switch with it disconnected wouldn't accomplish much...
47 mpg @ 75 mph
Old September 15th, 2011, 11:54   #7
Herm TDI
Herm TDI's Avatar
most likely...the A/C clutch coil is dead.
Malone Tuning Service.
HermTDI@Yahoo.com
Herm TDI is offline   Reply With Quote
Old September 15th, 2011, 13:52   #8
DanG144
The bridging of the pins is for models before May of '99, which had a dual hi lo pressure switch on the high side, and four pins.
Do not try to bridge a 3 pin high pressure sensor used after May of '99. At best you will blow the fuse.
Old September 15th, 2011, 15:12   #9
brett.knutson
I don't think I am getting voltage to the compressor coil at all... It will definitely click when I apply 12v directly from the battery but nothing when I have the car running w/ ac 'on'.
Sooo, how confident are you guys it is the FCM? How much would one be, and where is a good place to get one? I would like to get this resolved tonight if possible.
Old September 15th, 2011, 15:22   #10
gquenstedt
If the coil is good as you suspect, and when you turn the ac on and off the radiator fans turn on and off, then your pressure sensor is good and the only thing it can be is the FCM. You can always get one at the dealer if you're in a hurry but you'll pay a lot. Www.autohausaz.com www.boraparts.com or www.idparts.com are all good
Old September 15th, 2011, 16:22   #11
brett.knutson
The fans seem to always run on low speed, but if I jumper at the coolant sensor they will go to high speed... How can I test the pressure sensor?
Old September 15th, 2011, 18:05   #12
brett.knutson
I just pulled the FCM off, it looks fine. No corrosion, nothing melted, all connections clean and dry. Is there a way to test it?
Old September 15th, 2011, 18:23   #13
gquenstedt
1. Turn the ignition to on, but do not start the engine.
2. Turn the a/c on. Do the radiator fans come on low speed?
3. Turn the a/c off. Do the radiator fans turn off?
If so, that means that the FCM is getting all the right signals to power up the clutch, but it is just not sending it power because it is broken. You can not tell by looking at it.
Old September 15th, 2011, 19:19   #14
brett.knutson
the fans come on even with the a/c off, and stay on for awhile even after the key is turned off. SOunds
I just bought one from boraparts for $56... wish me luck.
Old September 16th, 2011, 03:41   #15
DanG144
If the fans are coming on with the AC off, and staying on with the key off, check your fuses for your system.
You have lost one of the power signals. Bad fuse or bad wire.
Fuse 15, I think.
I did not post this earlier, because some of your wording seemed to suggest you had already found it, but have you done the troubleshooting
http://forums.tdiclub.com/showthread.php?t=242699 found in post #1 of this thread?
A/C compressor clutch doesn't engage snakeye VW MKIV-A4 TDIs (VE and PD) 4 April 16th, 2011 09:08
Mechanic friend replaced AC Compressor clutch wont engage Abishop TDI 101 18 June 28th, 2010 13:20
01 NB AC clutch won't engage DeezlBug TDI 101 1 February 10th, 2009 20:32
AC won't always engage rparnel1 VW B5 Passat TDIs 3 June 9th, 2008 07:53
A/C compressor won't engage highhilltdi VW MKIV-A4 TDIs (VE and PD) 5 June 16th, 2006 07:38
Page generated in 0.14557 seconds with 10 queries
[Output: 125.22 Kb. compressed to 104.27 Kb. by saving 20.95 Kb. (16.73%)]
