Old September 13th, 2011, 11:05   #1
danielcram
TDI(s): 2003 jetta
Default 22 micron napa gold oil filters???
hi everyone i am new here and i just bought a 2003 jetta tdi, i was picking up oil and filters and it was recomended that i go with a napa gold p/n 7210 oil filter they apparently have a higher micron rating then the stock filter, napa gold is a 22 micron rating. Has anybody ever used these or does anybody know what the stock vw filters micron rating is? thanks. any pros and cons
danielcram is offline   Reply With Quote
Old September 13th, 2011, 11:11   #2
Lightflyer1
Lightflyer1's Avatar
Most recommend OEM filters. They can be had from the dealer or our vendors here. Check the group buy forums for some of the vendors.
2015 Beetle TDI.
Old September 13th, 2011, 11:50   #3
jettawreck
jettawreck's Avatar
Used lots of the NAPA Gold oil filters in the '00/'01/'03 TDIs. Never knew (or worried) about the micron rating(s). They're good filters, no issues. They have the baffle inside and are labeled "top" on one end. Most of them are made in Poland as were some/most of the Mann oil filters I've had.
2004 Cadillac SLS (wife's)
jettawreck is online now   Reply With Quote
Old September 13th, 2011, 12:41   #4
danielcram
TDI(s): 2003 jetta
Default napa gold 22micron
thanks for the advice, my friend and I were discussing it wondering if it would drop your oil pressure due to smaller microns, I talked to Napa they said that it also has more pleats so better surface area.
Old September 13th, 2011, 13:04   #5
AndyBees
AndyBees's Avatar
I've used Purolator for years (pre-TDI days) and have not had any problems that I know of. And, sort of like what Jettawreck said, I don't have a clue what the micro rating would be for them. Purolator has a higher end filter.........seems they are all (Purolators) are all made in Israel.
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
AndyBees is online now   Reply With Quote
Old September 13th, 2011, 16:14   #6
danielcram
TDI(s): 2003 jetta
wow I scrolled down and read a few old posts about napa gold filters and now I think I will bring them back, I am going to buy a one from vw and compare the two, check out these old posts from 2008 and 2006 below, it talks about the filters having impropper o rings and letting oil leak down and causing dry start conditions, and not having propper baffles, I think to be safe i am going to stick with OEM, thoughts anyone??? Read the old posts!
hey AndyBees, you probably drove right through grande prairie on your way up the alaska highway where i live!!
Old September 13th, 2011, 16:19   #7
AndyBees
AndyBees's Avatar
Yeah, I've spent the night in Grande Prairie several different times. I had my '83 Vanagon serviced at the VW Dealership there in 1999. We stayed at a motel within walking distance of the dealership. Bathegate I think is the manager there!
EDIT: The Purolator filter has "Top" stamped on it, fits tight and looks like the Mann filter!
Old September 13th, 2011, 17:47   #8
danielcram
TDI(s): 2003 jetta
ok so i wanted to go home and check the napa gold filters i bought, they do have the baffles in side the oil filter and it says top on one end and made in poland, i think they will be fine, i am going to buy a vw one tomorow morning and compare the two, i will try to post some pics.
Old September 14th, 2011, 06:20   #9
jettawreck
jettawreck's Avatar
All the NAPA Gold filters for the TDI I've bought have been fine. I usually change oil (Rotella T6 5w-40 or M1 TDT 5w-40) every 10K and the filter every 20K, never had one fail or clog up. They have a "cheaper" non-Gold product which I have not tried (and have no reason to). Maybe they are the ones that were found sub-standard.
Old September 14th, 2011, 07:51   #10
Elfnmagik
Elfnmagik's Avatar
I thought they were Wix filters?
HPFP, DSG, DPF, DMF...I hate acronyms!
Elfnmagik is offline   Reply With Quote
Old September 14th, 2011, 08:28   #11
Keith_J
Keith_J's Avatar
Fuel Economy: 38 MPG @ 80 MPH with 2 bikes on top. 52 MPG @ 60 MPH slick
22 microns is still less than 1/1000th of an inch. Bearing clearances are 2-4 thousandths.
2k Jetta manual. PP520s. Ventectomy, Panzer Plate, DT hitch, 16"s w/ 205 55s. Short shifter. Boost gauge with blue LED backlight, same intensity as dash. Blistein struts and shocks. 0.658:1 5th gear swap and LOVING IT.
Keith_J is offline   Reply With Quote
Old September 14th, 2011, 09:40   #12
T_D_I_POWER
T_D_I_POWER's Avatar
Both Hengst oil & fuel filters are 10u
//TDI POWER
2004 B5.5S
1st TO USE Mobil 1 ESP Formula M 5W-40 IN THE CLUB http://forums.tdiclub.com/showpost.p...56&postcount=9
1st TO PREFILL OFH/OFI INSTL W/ OIL IN THE CLUB http://forums.tdiclub.com/showpost.p...02&postcount=5
1st TO PREFIL FF W/ DIESEL FUEL IN THE CLUB http://forums.tdiclub.com/showpost.p...4&postcount=14
T_D_I_POWER is offline   Reply With Quote
Old September 14th, 2011, 12:19   #13
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
What is the micron rating of mann?
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old September 14th, 2011, 13:49   #14
Crows Synthetics
Crows Synthetics's Avatar
TDI(s): 2009 Jeta
Fuel Economy: 38-42
Wink
I have wanted to know that answer as well.
I went to Mann's website on that site the FAQ How do long-life oil filters differ from conventional oil filters?
Down a few answers a broad range 5-18 microns better than napa. I does look like they are a better filter and designed for extended oil drain.
Thanks for asking the question.
Bill
2009 Jetta Sedan TDI --- 2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD---New Holland T1520 Diesel
Bill Crow - Amsoil Direct Distributor
www.FreeOilHelp.com --- www.BillsOilHelp.com
Crows Synthetics is offline   Reply With Quote
Old September 15th, 2011, 08:46   #15
danielcram
TDI(s): 2003 jetta
thanks everyone for all th info, i bought i vw filter yesterday and compared the napa gold filter and the vw, the baffles inside are identical, the napa filter is made in poland and is labeled top on one end. I counted the pleats and the napa filter has around 60 pleats and vw filter has around 50. Is mann the company that makes the vw filter, I went onto mann's website and I was unable to find the micron rating of the filter for my 2003 jetta tdi, Crows synthetics could you please post the link to the place where you found the micron rating of that filter, thanks. The guy at the parts store told me that the napa gold had a higher micron rating then the stock filter but maybe he was just full of it.
Napa Gold Oil Filters Jeepmb TDI 101 14 September 24th, 2008 10:07
Anyone using NAPA GOLD oil fisters and Runaway_TDI VW MKV-A5 Golf/Jettas 23 March 11th, 2008 07:40
Napa Gold Oil Filter - Not Good! hl649 VW MKIV-A4 TDIs (VE and PD) 19 February 6th, 2006 06:07
Napa gold 7210 oil filter Honcho12 Fuels & Lubricants 6 September 3rd, 2005 12:41
2 Micron Cat Filters, Oil Filters, Injector Servic LanduytG Vendor & GroupBuy items for sale 2 February 9th, 2005 13:07
Page generated in 0.16151 seconds with 10 queries
[Output: 132.81 Kb. compressed to 111.03 Kb. by saving 21.77 Kb. (16.39%)]
