I finished this crankcase ventilation filter modification on my 2006 Jetta TDI three weeks ago.
BRM 1.9L TDI seem to have a lot of blow-by vapors that eventually clog up the ERG valve and intake manifold since the oily mist mixes with the EGR soot.
This crank case ventilation filter prevents that oily mist from entering the intake manifold and mixing with the EGR soot, thus eliminating the clogged intake manifold problem for good!
It has already captured 0.5 ounces. Estimated life time blow-by oil that will be captured, approximately 166 ounces.
Calculations based on as follows:
0.5 ounces = three weeks of operation.
The vehicle has been in operation for 64 months:
64 months x 4 weeks/month = 256 weeks of operation.
256 weeks/3 weeks per 0.5 ounces = 85.33 ounces estimated entry into air intake system
Therefore, if the vehicle is currently at 85,000 miles = 85.33 ounces
And vehicle lasts until 250,000 miles, this will be = 250.97 ounces
The remainder between 250.97 - 85.33 =
165.64 ounces estimated captured by Moroso CCVF. That's
1.24 gallons of engine oil that will NOT enter the intake manifold and EGR throttle valve.
This is an air/oil separator system and anyone with a TDI that has blow-by vapors entering the intake manifold should be interested in doing this modification. Although, not all TDI vehicles have enough room in the engine compartment.
PLEASE read everything fully and carefully before you install to ensure you understand everything and the problems I have overcome.
Furthermore, I will not be held liable for any dissatisfaction or damages of such that this modification may cause to any persons vehicles. Remember, any modifications other than VW recommended is at your own risk.
I bought the CCVF Moroso off of eBay for $146.88, it is designed for a 5.0L Ford Mustang but is ideal for the 1.9L BRM TDI (turbocharged direct injection).
The Moroso kit aluminium air/oil separator cans are ALL the same, regardless if it is the Jeep, Ford, Chevy, Universal kits.
I purchased the Jeep kit, mainly because it was the CHEAPEST one available. I had to grind the engine steel mount to the dimensions I wanted for use with my custom stainless steel engine mount bracket.
The Moroso comes with the basic hardware for the air/oil separator. The kit also comes with three feet of Parker heater hose and is PERFECT length for this TDI engine. JUST MAKE sure you cut one piece LONGER than the other if you install the CCVF to the left of oil filter like I did.
I custom built a stainless steel engine mount and mounted my Moroso CCVF on front the the TDI BRM engine mount that has threads manufactured into the engine from VW. (This area is located slightly to the right of the dipstick and behind a smaller radiator hose.)
Before I had the engine mount built I used copper house electrical cable bolted to the CCVF eyelet and wrapped the wire around the dipstick area.
Total installation with all parts cost just under $160.00 CANADIAN funds.
-I purchased the CCVF
Moroso air/oil separator off of eBay (SpeedUnlimited Seller) with FREE shipping ($146.88)
-Purchased two additional
Parker 3/8 tangent brass fittings to thread into the former VW bleeder hose ($12.00)
Teflon tape to wrap around the fittings ($0.40)
Link for Moroso CCVF:
http://www.moroso.com/catalog/categorydisplay.asp?catcode=18549
http://cgi.ebay.com/ebaymotors/_W0QQcmdZViewItemQQitemZ190551243545#ht_2483wt_760
I bought two additional tangent/straight fittings made by Parker (3/8's tangent fittings) and threaded them into the formed VW bleeder CCV hose that comes as one piece from the crankcase and to the intake hose.
From this, I was able to attach the Parker 3/8's heater hose that comes in this kit to the additional fittings I purchased and all the way to the Moroso air/oil separator fittings. (If you have trouble pressure fitting the heater hose to the fittings, just rub on a little bit of dish soap and it will slide on the fittings perfectly and NEVER come off!).
This VW BLEEDER CCV hose is actual THREE pieces pressure fitted together. Its very simple to remove. All you have to do is apply even pressure on the release clips around the intake hose and crankcase areas it is attached to.
To dismantle this entire piece, I submerged the bleeder hose in very HOT water and was able to pull the two adapters apart from the flex joint hose that connects the two. The two adapters are what I threaded the two additional Parker brass fittings into using my hand grasping the adapter CAREFULLY not to break the release clips and a wrench to slowly tighten the fittings into the adapters.
Eventually, I put the entire Moroso kit together, threaded the brass fittings into the aluminum air/oil separator and tightened them snug. I used Teflon tape to ensure the fittings keep their seal!
From this, I cut the heater hose according to the length required from crankcase to CCVF and then back from CCVF to intake manifold. I was able to have the heater hose hidden behind the engine plastic cover and under the intake manifold up until the intake attachment area.
DIFFICULTIES with modification:
- engine cover brushed up against heater hose and caused excessive wear: the most vibrations occur at idle, I overcame this problem by tightening the brass fittings to the aluminium can DOWNWARD thus providing more clearance.
-heater hose if too long impacts manual transmission selection: hose may be too long and causing restricted clearance in transmission fork selector area (located under intake air filter) CUT hoses in proper length
-Radiator hose brushing against stainless steel engine mount causing excessive wear: overcame this problem by using a piece of scrap heater hose and wrapping that around radiator hose to avoid damage as it is a cushion.
-I DID NOT install the brass fitting on the BOTTOM of the CCVF as it would take up too much room in engine compartment.
I prefer to remove the canister's bottom and dump the oil out by hand instead of using the drain valve fitting that threads into the bottom of the CCVF.
Here are some pictures of my work of art:
http://imageshack.us/photo/my-images/855/img6461d.jpg/
http://imageshack.us/photo/my-images/844/img6454c.jpg/
http://imageshack.us/photo/my-images/69/img6455d.jpg/
http://imageshack.us/photo/my-images/703/img6456c.jpg/
http://imageshack.us/photo/my-images/508/img6459r.jpg/
These photos are not entirely up to date as I have made minor adjustments to the Moroso but it is very similar.
I have angled the fittings downward for more clearance and strengthened the engine mount with another cross member.
And yes, I did all the custom red and silver TDI paint job myself.
This procedure has been ambiguous and enjoyable to do.
I do not have an explicit procedure layout for anyone, my advice is look at the problem at hand, identify what your demands are for the modification and make it work by adjusting the modification as minor problems occur.
Best regards,
ROVERTTDI
