Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Past TDIFests > TDIFest 2011
TDIFest 2011 Discussion about TDIFest 2011 on the Labour Day weekend (September 2-4th, 2011) in Lexington, KY.
Old September 5th, 2011, 16:29   #1
DCELL
DCELL's Avatar
Fuel Economy: 44mpg ave
Default Leaving the fest, anyone else see this??
As I was leaving the fest Sunday (I left just as it started raining hard, the raffle was still wrapping up), I witnessed a pole transformer explode as I was waiting to turn onto KY4/ new circle road. The stop light blinked a couple times and rain and wind were starting to get very violent. All of a sudden there was a blinding blue flash and a shower of sparks just behind me. At first I thought lightning hit it. Just wondering if anyone else saw it or if I was the only one! Definitely not something I'll forget for a while!
TDI service work available on a limited weekend basis. Timing belts, maintenance, etc. PM me with your needs!
When opportunity knocks, and I'm not home, opportunity waits.
DCELL is offline   Reply With Quote
Old September 5th, 2011, 16:42   #2
MayorDJQ
Didn't see it, but I work in the electric utility business, and electrical items can make some pretty dramatic displays. Even something as minor as a blowing transformer fuse is enough to kake you jump out of your shoes.
MayorDJQ is offline   Reply With Quote
Old September 5th, 2011, 17:28   #3
mo_focus
mo_focus's Avatar
TDI(s): 84 944
yeah wife saw it from our room!
1984 Porsche 944- New Toy
2009 Acura RDX Turbo
mo_focus is offline   Reply With Quote
Old September 5th, 2011, 18:45   #4
TDI Stevestr
Oh man wish I had seen it. They can also be pretty loud when they blow. All I had was some band playing at the bar next door blasting into my room until 11:00 last night.
5K149M 2011 Golf 4-DR 2.0L TDI Auto Exterior: A1A1 - Black / Interior: KA - Titan Black
Options: 9VE Dynaudio; 9W7 Bluetooth; GTM Rubber Mats and Chrome Exhaust (Port); P71 Navigation (310); P83 Xenon Headlamps; W79 Cold Weather Package
Mechatronics: 1 / Transmissions: 1 (14,200 Mi) ** VCDS/VAGCom Available **
TDI Stevestr is offline   Reply With Quote
Old September 5th, 2011, 20:29   #5
MonsterTDI09
MonsterTDI09's Avatar
+1
2010 Jetta sedan TDI DSG Platinum gray metallic.Build date (5/10) Mods ----EV skid plate, E code head lamps, Polar FIS
A cleaning service for DPF. http://www.dpfregeneration.com/ I have no affiliation
MonsterTDI09 is offline   Reply With Quote
Old September 5th, 2011, 21:50   #6
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
I happened to also see it. I was surprised that the hotel didn't lose power, but the book store and seafood restaurant (and probably others) did for about 5 seconds before an alternate supply was connected.
Pretty impressive, I thought.
Oh yeah, the flash was impressive too.
Svante Arrhenius 1896
Old September 5th, 2011, 22:19   #7
MayorDJQ
The "fault" was probably isolated by the transformer fuse(s) and/or may have been downstream from the hotel or simply on another feeder. Sometimes even a branch across the primaries can make a huge shower of sparks and blow fuses.
Old September 5th, 2011, 23:27   #8
TDIDaveNH
Left Lane Coal Roller at Large
TDIDaveNH's Avatar
TDI(s): 1997 Passat
I was lying in bed at the time, but recall a peculiar sounding thunder clap which touched down rather close to the hotel and was alarming, but chalked it up to Kentucky thunder just sounding different and went back to bed.
Per cogo, non per mico (By compression, not by spark)
GLX conversion in Storm Grey- my first TDI engine rides again.
TDIDaveNH is offline   Reply With Quote
Old September 6th, 2011, 11:52   #9
Good Ol' Boy
VeeDubTDI's Avatar
I was looking out the window of the room and saw what looked like lighting out by that stoplight. I guess it was the xformer blowing up!
Old September 6th, 2011, 20:34   #10
AndyBees
AndyBees's Avatar
Yeah, I heard it from the room......thought it was Thunder! And, the utility trucks and repairmen were on-site working on it as we drove into town for Breakfast!
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old September 6th, 2011, 21:06   #11
Ski in NC
Fuel Economy: 48-52 typical
Just a little tidbit about power lines: The fuses have a little explosive charge inside that does two things: Mechanically separate the fuse so a lineman observing from the road can see the "open load", and also: blow out any arc that that might start if a standard type fuse is used. So a fuse blowing can be really dramatic. BANG and lots of sparks!
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old September 6th, 2011, 21:30   #12
MayorDJQ
Yep, like a shotgun, but even louder.
Want to help out at the Fest?? Fest Volunteer Thread. Zippy_car TDIFest 2007 28 August 25th, 2007 19:36
Ho5G Post-Fest Fest Hamsterdiesel Eastern USA 304 September 25th, 2006 17:25
Leaving Tomorrow Thadude TDIFest 2006 16 September 1st, 2006 09:59
TDI Fest 2002 Exp/Income (2003 Fest take note) The Ripster TDIFests 2000 - 2003 10 September 9th, 2002 18:15
Page generated in 0.14843 seconds with 10 queries
[Output: 107.71 Kb. compressed to 90.23 Kb. by saving 17.48 Kb. (16.23%)]
