Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old September 4th, 2011, 03:53   #1
kassel
Default What's your most efficient speed for max MPG?
My 2011 Jetta TDI seems to like 60 MPH for max MPG. I routinely get 50 MPG+ at 60 MPH. At higher speeds (65/70) the mileage drops to 45/46 MPG. What are others seeing?
2011 Jetta TDI - DSG Stock - Platinum Gray
2011 Jetta TDI - DSG - Reflex Silver
06.5 JETTA TDI SE DSG (33/38 MPG Stock)
kassel is offline   Reply With Quote
Old September 4th, 2011, 03:57   #2
deucelee
Fuel Economy: 45mpg @ 80% highway
My last fill up was 47.6mpg going 70mpg with 85% highway.
I bet I'd hit 50mpg easy with 60'ish to 65'ish.
2011 Jetta TDI | DG Short Shifter | DG Panzar Plate | DIY Tint Job | DIY Paint Protection | DIY JL 10w3v3 & 500/1 Amp
deucelee is offline   Reply With Quote
Old September 4th, 2011, 05:27   #3
Jack Frost
Jack Frost's Avatar
I have a Scanguage. My instantaneous mileage for my 2011 DSG is best at 80 kph or 50 mph. At that speed it is about 65 mpg but that drops off to about 50 at 60 mph. My combined city/highway/gravel road mileage over a tank is about 43 mpg.
2009 TDI, Spice Red with Black Interior, DSG, Purelli Winter Tires, VW Block Heater
1996 Suburu Legacy (wife)
John Deere 2130 Diesel Tractor
1989 Ford Mustang 5.0 (gone but not forgotton)
Jack Frost is offline   Reply With Quote
Old September 4th, 2011, 05:41   #4
kassel
I am curious about a scangauge and where is connects in the car (2011) and where I can get the gauge as well. I was under the impression the VWs were unique in their protocol and were readable using VAG COM only. Is this not the case anymore?
Old September 4th, 2011, 08:09   #5
philip_g
TDI(s): jetta
Its never been the case in regards to using a scangauge. Scangauge gets data from the obd2 port.
philip_g is offline   Reply With Quote
Old September 4th, 2011, 15:51   #6
Mundgyver
Mundgyver's Avatar
Fuel Economy: Not enough miles yet.
To get the best fuel economey you need to know at what rpm, peak engine torque is developed. Once you know that then it is just a matter of setting speed with rpm selected to the gear you are in.
I have not seen a torque chart for these TDI yet. Does anyone know where we can look at one?
On my Dodge Cummins, I set the engin at 1750 rpm in 6th gear and will get around 23 mpg, and this is a 1 ton truck.
2011 Jetta TDI Sedan
2001 Dodge Cummins
Mundgyver is offline   Reply With Quote
Old September 4th, 2011, 19:36   #7
Jack Frost
Jack Frost's Avatar
The best mileage speed depends on many factors.
My best mileage on a smooth highway is at 1600 rpm in 6th gear, but the best torque on the TDI is at about 2000.
Here a link to a torque curve ... http://www.tech-karma.com/sites/defa...1-kw-nm-c1.png
Old September 4th, 2011, 19:48   #8
Savageman69
Savageman69's Avatar
i seem to get best mpg at 90km/hr by the speedo on the car..thats scangauge confirmed and 51 mpg on a entire 1233km tank
2012 Highline Touareg v6 TDI - 8spd - Silver - Weathertechs - Buzzken Downpipe/Dpf/Scr Pipes - Hybrid 2260 - 4 Bar Map - JR Auto Performance/Buzzken Stage 3 Tune - 31 BFG k02s - Cayenne Trans Coding - Gutted/Painted Muffler - Full Led Swap
Savageman69 is offline   Reply With Quote
Old September 4th, 2011, 19:51   #9
Jack Frost
Jack Frost's Avatar
What is your rpm at your best mileage speed?
Old September 4th, 2011, 19:52   #10
Savageman69
i wanna say 1500 or so
Old September 4th, 2011, 20:16   #11
Imelda T Green
TDI(s): None Yet
Default Differences in F E
What must be consider is the big differences in RPMs between the DSGs and the manual 6 MTs per mile!
There is no way that the DSGs can obtain the F E of the late manual 6 MTs.
Imelda T Green is offline   Reply With Quote
Old September 4th, 2011, 20:35   #12
Savageman69
i think the dsg is almost spot on with rpm of the manual. I do agree that manual will put out better mpg IF the manual driver can drive it right.
Old September 4th, 2011, 20:54   #13
Imelda T Green
TDI(s): None Yet
Arrow Not So
Originally Posted by Savageman69 View Post
i think the dsg is almost spot on with rpm of the manual. I do agree that [the]
DSGs have a ratio of 2.31
6 MTs have a ratio of 1.98
At 96 KPH, the DSG is turning 1933
At 96 KPH, the 6 MT is turning only 1657
A difference is favour of the 6 MT by 275 revs
Because of the gearing, the 6 MT will do better
The 2009 gearing of the 6 MT was different, and they were closer to equal.
The '09 6 MTs were geared 2.23, and yes they would still do slightly better F E wise.
Old September 4th, 2011, 20:54   #14
RLWSNOOK
My read out says something like 74 mpg at 40 mph, but not sure if that's right.. nor would I want to drive around at 40 mph all the time... My car is still not really broken in so I've only once tried to see what fuel economy I could get out of it. I'm waiting until my break in allows me to drive the way I want to drive to get the fuel economy. Happy with the 36-45 mpg I'm getting now...
Edit: mind you this was an instant read out, and on a flat road with no ac, but I did maintain the mpg for a few mins...
RLWSNOOK is offline   Reply With Quote
Old September 4th, 2011, 21:05   #15
Plus 3 Golfer
Plus 3 Golfer's Avatar
Evidently you haven't seen this post or the thread.
Plus 3 Golfer is offline   Reply With Quote
Ernie interviewed by The Fresno Bee on Biodiesel and MAX MPG, his UBER MPG New Beetl Audi5000TDI Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 18 March 16th, 2006 15:32
Need MAX MPG-- HELP!!! itsmejerry TDI Fuel Economy 27 September 15th, 2004 22:24
What is the most fuel-efficient highway speed? markcochran VW MKIV-A4 TDIs (VE and PD) 10 July 2nd, 2003 20:58
Rise Idle speed to max rpm allowable - MPG lowering? significantly? Andrei Rinea TDI Fuel Economy 1 January 30th, 2003 18:56
can't get max speed Theo VW MKIV-A4 TDIs (VE and PD) 3 July 25th, 2002 00:26
Page generated in 0.47221 seconds with 10 queries
[Output: 127.89 Kb. compressed to 105.98 Kb. by saving 21.91 Kb. (17.13%)]
