Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old September 2nd, 2011, 20:22   #1
iefstath
Default No power at 12 volt outlets, no blown fuses
Both front and rear 12 volt outlets just stopped working, there is no Fuse map but from what I can tell there are no blown fuses either under the dash or under the hood. The dealer was less than helpful, unless I wanted to leave the car all day.
Any ideas?
iefstath is offline   Reply With Quote
Old September 2nd, 2011, 20:54   #2
The67beast
Any ideas?
Call the Dealer and ask for a fuse map printout or do what I did when I lost some power. Start pulling fuses one by one.
The67beast is offline   Reply With Quote
Old September 3rd, 2011, 00:05   #3
MyAvocation
MyAvocation's Avatar
How did you test the fuses? Not knowing which one it is you'd have to put an ohm meter on every one. Keep in mind it's possible for a fuse to 'look' OK and be blown.
Fuses aside, I think leaving it with the dealer is your best choice. Most likely a loose connector or bad pin termination. Either way someone has to open-up the console, fuse block and numerous wire looms.
MyAvocation is offline   Reply With Quote
Old September 3rd, 2011, 06:30   #4
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
I have a feeling this one is a grounding issue. Just a hunch.
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old September 3rd, 2011, 07:08   #5
The67beast
Just start pulling them. It will take you all of 15 minutes. Pull it and if it looks good move on to the next. Then let is sit at the dealer for a day.
Old September 5th, 2011, 16:35   #6
iefstath
Dealer gave me a 10 page print out for wiring, turns out the fuse was blown but it did not break in the middle and passed my initial overview. We'll see if this is a reoccurring event.
Old September 6th, 2011, 08:51   #7
mwayner69
mwayner69's Avatar
I had the fuse blow for my 12v outlets as well. The dealer told me that they had seen a few others do the same. His advice was to make sure nothing was plugged in when you started the car to try to prevent it from happening again. I don't know that it will make any difference, but it's easy enough so I've followed that advice.
2011 Jetta TDI DSG
2007 Rabbit 2.5 5-speed
2001 New Beetle 1.8t 5-Speed
mwayner69 is offline   Reply With Quote
Old September 6th, 2011, 09:40   #8
740GLE
what's the rating of the fuse?
also you guys have anything plugged in to your outlets?
maybe there's a short someplace down stream of the fuse and the blown fuse won't fix your problem. Try and snag a metter and see if the two leads of the fuse socket, are shorted to each other or ground.
Old September 6th, 2011, 10:08   #9
mwayner69
mwayner69's Avatar
I had 2 phone chargers, a GPS and a Nintendo DS charger plugged into mine when it blew, so I probably overloaded it. We were on a 13 hour road trip at the time and I've not had more than a phone charger and the DS charger plugged into it at one time since. I do make sure that I unplug my phone charger when I'm done with it, just in case.
2011 Jetta TDI DSG
Old September 6th, 2011, 11:17   #10
MyAvocation
This is a red flag in my book. All those devices combined should not exceed a 3 amp draw and IIRC these outlets typically have a 10A fuse. With that said, I'm guessing a decent sized AC inverter will pop fuses within 10 seconds.
Old September 6th, 2011, 11:40   #11
mwayner69
mwayner69's Avatar
I forgot to mention that I did have an inverter plugged in at times as well. It didn't stay plugged in the whole time though.
2011 Jetta TDI DSG
Old September 6th, 2011, 18:56   #12
iefstath
Its a 20A fuse, 1 phone charger and 1 maglight
12 Volt Power Source Shorting Out terrydtdi TDI 101 4 April 23rd, 2011 23:18
Help troubleshooting 12 volt power outlet. belome VW MKIV-A4 TDIs (VE and PD) 4 April 26th, 2010 14:12
12 volt power sorce not working terrydtdi General Automotive 1 August 31st, 2007 09:12
12 Volt Power Outlets Airplane MD VW MKV-A5 Golf/Jettas 3 August 3rd, 2006 09:29
12 Volt Switched Power for Volt Gauge Install PDJetta Upgrades (non TDI Engine related) 3 December 2nd, 2005 14:16
Page generated in 0.15572 seconds with 10 queries
[Output: 106.37 Kb. compressed to 89.06 Kb. by saving 17.31 Kb. (16.27%)]
