Old December 4th, 2017, 21:50   #46
OlyTDI
TDI(s): '04 Golf
Just to update after 6 years of using this mod:
The plug-in mod has endured without problems for the last six years of daily commuting. The paint wore off the receptacle but I've not been motivated to repaint it and I've gotten used to seeing it lighter grey. The plug prongs remain shiny bright -- like new and the door works perfectly and spring remains firm. Nothing has come loose. About two years ago, I re-coated the wires behind the bumper with liquid electrical tape simply to retain the water proofing. Everything has been just perfect and maintenance free.
2004 Golf GL PD TDI
Malone Tuned, SBC Stage II Daily, Nicktane Cat 2 fuel filter, Dieselgeek bypass oil filter, Whitedog intake hose fix, A4 Defender skid plate, GLI Recaros, Check Temp III, Ventectomy, LED trunk lighting mod, Volx glass headlight lenses, VR6 front and wagon rear springs. Koni FSDs all around. FrostHeater with bumper mounted plug-in mod (details here).
OlyTDI is offline   Reply With Quote
Old December 4th, 2017, 22:16   #47
phaser
Fuel Economy: 47 MPG B-20
I mounted the marine plug in the grill, right in the center of the VW emblem.
My wife (me too) loves the ease of plugging and unplugging without having to stoop down, plus it's always clean.
2004 Jetta BEW 5M - 460k - 47 mpg / Fuel B-20 / Fuel Filter - Cat IR-0750 /
Oil Filter - Hengst / Oil - Schaeffer Supreme 9000 5W-40 /
Bypass Filter EaBP100 /
Air Filter - EaA208
/ Transmission Oil - VW G50
phaser is offline   Reply With Quote
Old December 5th, 2017, 19:59   #48
OlyTDI
TDI(s): '04 Golf
That's great, Phaser -- if you back out of the garage and your plugged in, it would pull out without damage.
Got any pix?
2004 Golf GL PD TDI
Old December 12th, 2017, 15:36   #49
phaser
Here it is.
Air Filter - EaA208
Old December 16th, 2017, 21:30   #50
OlyTDI
TDI(s): '04 Golf
That's awesome! Good on ya!
2004 Golf GL PD TDI
Old December 31st, 2017, 09:35   #51
mrowens33
Default Looking for just the heater unit
My block heater from Frost heater that I installed on my 2004 Jetta 5 years ago has stopped working. It popped the one circuit. Then when I tried another circuit in the garage, it produced no heat. Does anybody know where I can buy just the heater? I don't see just the heater unit listed on the Frost Heater website.
***Update: I was apparently too impatient. It seems to be working properly now. ***
mrowens33 is offline   Reply With Quote
Old December 31st, 2017, 10:25   #52
MichaelB
Call or email Terry I'm sure he will help you out.
MichaelB is offline   Reply With Quote
Old December 31st, 2017, 18:26   #53
Beaker80
It's called a Zerostart heater made by Phillips & Temro Industries. There are a few different models to choose from. I bought a model 3308003 1500 watt and removed the check ball.
https://phillipsandtemro.com/solutio...ation-heaters/
Beaker80 is offline   Reply With Quote
Old December 31st, 2017, 20:56   #54
narongc73
I dunno. i had enough of cords. Installed a Webasto this winter. Cordless warmups. Priceless.
narongc73 is offline   Reply With Quote
Old January 3rd, 2018, 07:34   #55
Kriesel
Kriesel's Avatar
My heater also seems to have stopped working. Going to verify with an amp-clamp tonight, but pretty sure it stopped.
Might take mine apart and see if it can be fixed internally... Can't break it anymore than it already is!
Kriesel is offline   Reply With Quote
Old January 17th, 2018, 09:45   #56
Kriesel
Kriesel's Avatar
Verified that power is working ok, but on the colder days I must not have had the timer on long enough to make a difference. Changed the length on the timer, and seems to be starting better now.
Old January 25th, 2018, 14:27   #57
Nevada_TDI
I recently installed a Frostheater in my Jetta, today I had to scrape ice off of the glass but the engine started right up w/o issue.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, Stage 4 Custom TDTuning, PP764's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
New Plug on Frostheater bagdwag TDI 101 16 January 15th, 2011 05:54
JSW TDI Frostheater pics Bugdoc VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 1 October 8th, 2010 03:44
Looking for frostheater help and pics countryboy9799 VW MKV-A5 Golf/Jettas 7 October 20th, 2009 13:43
Frostheater Install pics Brockflock TDI 101 4 April 22nd, 2008 10:14
Two leaks found on my TDI, need help with finding solution (pics included) ocelot TDI 101 11 May 23rd, 2007 10:10
Page generated in 0.13816 seconds with 10 queries
[Output: 112.85 Kb. compressed to 95.63 Kb. by saving 17.22 Kb. (15.26%)]
