Old September 15th, 2011, 14:24   #16
MayorDJQ
Is the cover secured to anything other than the bumper cover? What I'm getting at is does the surrounding plastic flex when plugging in/unplugging?
My only concern would be putting pressure/stress on the plastic of the cover in very cold weather.
MayorDJQ is offline   Reply With Quote
Old September 15th, 2011, 16:33   #17
OlyTDI
TDI(s): '04 Golf
No, it's very firm. The outer portion of the device is through bolted and sandwiches a gasket. So with flat washers on the other side and all of them snugged firmly down, I see and feel no play. Also, for what it's worth, I always keep my plugs/recepticles slippery and clean.
Hope that answered your question!
2004 Golf GL PD TDI
Malone Tuned, SBC Stage II Daily, Nicktane Cat 2 fuel filter, Dieselgeek bypass oil filter, Whitedog intake hose fix, A4 Defender skid plate, GLI Recaros, Check Temp III, Ventectomy, LED trunk lighting mod, Volx glass headlight lenses, VR6 front and wagon rear springs. Koni FSDs all around. FrostHeater with bumper mounted plug-in mod (details here).
OlyTDI is offline   Reply With Quote
Old September 15th, 2011, 16:35   #18
OlyTDI
TDI(s): '04 Golf
Originally Posted by shizzler View Post
My version:
Excellent!
2004 Golf GL PD TDI
Old November 18th, 2011, 11:08   #19
wfg97079
Default Mkvi
Anyone got a good solution for something similar on a 2011 JSW?
Originally Posted by OlyTDI View Post
Excellent!
wfg97079 is offline   Reply With Quote
Old November 18th, 2011, 11:14   #20
scurvy
Good Ol' Boy
scurvy's Avatar
TDI(s): 2006 Golf
Fuel Economy:
I've got basically the same install as Shizzler, but I installed my Marinco outlet directly into the existing lower driver's side grille. It's been held in with friction only for the past 5 years without issue - I never got around to securing the marine outlet into the grille insert with RTV or silicone.
If you post a question, post your solution!
mk4 front wheel bearing | scurvy winter front | VCDS in Chicago, IL USA
You are entitled to your opinions but not your own facts.
scurvy is offline   Reply With Quote
Old November 18th, 2011, 18:36   #21
OlyTDI
TDI(s): '04 Golf
Glad to hear the different solutions.
Since the install I did, there have been no problems. The inside of the recepticle is nice and dry (I worried about the door letting moisture in) and works wonderfully. At this point, I think I can heartily recommend this mod.
BTW -- I loop the extension cord over the driver's side mirror so that it is evident when I get into the car. A side-mounted plug-in isn't something you'd want to leave plugged-in when you drive off!
2004 Golf GL PD TDI
Old November 29th, 2011, 11:43   #22
slug1121
slug1121's Avatar
Fuel Economy: 42 avg.
Oly, I do really like the idea; it turned out looking really good! Has anyone tried mounting an outlet behind the grille emblem? I thought this would work nicely if the emblem was then mounted on a hinge.... Something I'm probably going to try. I'll post pics if I manage to follow through.
'04 Jetta TDI 5spd, 326k miles - JL Stealthbox, Monster Mats, TDI Heater.
'04 Jetta TDI 5spd, 242k miles - Stock (Wife's)
'05 GLI BMP 6spd, 167k miles - Gonzo Tuned, 2.5" exhaust.
slug1121 is offline   Reply With Quote
Old November 29th, 2011, 11:49   #23
leicaman
leicaman's Avatar
Fuel Economy: Much better than the average car... :o)
My advice for ANY frostheater user is to use good winter rated cords that are brightly colored. When I lived in Central Wisconsin and I drove a 1981 Plymouth reliant with a block heater, I once backed up and the cord went like a whip! Didn't wreck anything other than my 23 year old ego...at the time in 1981-82. Today I use bright orange ones and make sure I have a frostheater plug cap on to prevent derbis from getting the outlets smagged up.
2015 Golf SE TDI with DSG, 61k.
2005 Passat GLS TDI - RIP, 208k miles. Many good memories and friends made with this car.
leicaman is offline   Reply With Quote
Old November 29th, 2011, 17:03   #24
OlyTDI
TDI(s): '04 Golf
That would be an awesome mod if done right. I'll be interested in following your progress!
2004 Golf GL PD TDI
Old December 2nd, 2011, 20:39   #25
MonsterTDI09
MonsterTDI09's Avatar
Here is my version. I used a hole saw on a drill press to keep it strait.The socket is held in by the back nut.I can do a write up if some one see how i did it.The next one, I do I will try to put were the fog light goes.I think it will look nicer.
2010 Jetta sedan TDI DSG Platinum gray metallic.Build date (5/10) Mods ----EV skid plate, E code head lamps, Polar FIS
A cleaning service for DPF. http://www.dpfregeneration.com/ I have no affiliation
MonsterTDI09 is offline   Reply With Quote
Old December 3rd, 2011, 13:48   #26
spartan
spartan's Avatar
That looks great, nice job.
spartan is offline   Reply With Quote
Old December 6th, 2011, 09:06   #27
JPDiesel
Shizzler
How are the mounting screws for your covers attached to the car?
What material are the covers made of?
Thanks for the info.
JPDiesel is offline   Reply With Quote
Old December 11th, 2011, 14:16   #28
slug1121
slug1121's Avatar
I have altered my plan a bit and decided to turn the front emblem in to a twist-lock cover for the outlet, now I just need to come up with a reasonable latch system to prevent it from spinning out... I think it will work better in the cold weather than a hinge system would though. Thanks by the way, I will make sure to keep you in the know!
Old December 13th, 2011, 18:39   #29
rocketeer928
rocketeer928's Avatar
I did this recently:
Here's a link with further details on my TDI's thread:
http://forums.tdiclub.com/showpost.p...&postcount=789
2003 Jetta GLS TDI with RocketChip RC5-ASV-Euro tune specific to my performance modifications - Platinum Gray
yo
rocketeer928 is offline   Reply With Quote
Old December 13th, 2011, 22:55   #30
MonsterTDI09
That looks good. Nice job,just keep your extension cord short as possible.
New Plug on Frostheater bagdwag TDI 101 16 January 15th, 2011 05:54
JSW TDI Frostheater pics Bugdoc VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 1 October 8th, 2010 03:44
Looking for frostheater help and pics countryboy9799 VW MKV-A5 Golf/Jettas 7 October 20th, 2009 13:43
Frostheater Install pics Brockflock TDI 101 4 April 22nd, 2008 10:14
Two leaks found on my TDI, need help with finding solution (pics included) ocelot TDI 101 11 May 23rd, 2007 10:10
Page generated in 0.17721 seconds with 10 queries
[Output: 130.95 Kb. compressed to 109.37 Kb. by saving 21.57 Kb. (16.48%)]
