Old September 1st, 2011, 12:07   #1
OlyTDI
TDI(s): '04 Golf
Default FrostHeater Plug-in Mod: My Solution w/pics
I wasn't happy with the tuck-it-in-the-grill method of storing and using the plug for my FrostHeater so I decided to mount a dedicated plug-in device.
The unit I used can be seen here though I cannot remember where I purchased it. I think I paid about $35 for it:
http://www.google.com/products/catal...28895421430288#
It is Hubble Part Number HBL61CM64.
The process:
I chose the front bumper driver's side for a couple of reasons: First, it's the side I see when I get in the car, secondly, it just looks correct to me there, and thirdly, it's where the FrostHeater cord already resided, and fourthly, this area is the flattest area on the bumper.
Prior to install, I painted the device with touch-up paint matching my car. It was a clumsy process but it came-out more than adequately. I spray clear-coated the device a couple of times after the paint cured overnight.
As for mounting: First, tape-off the whole area you'll be working on so that there aren't any scratches and so you can mark-up the area with your sharpie or pencil. I used the blue masking tape and that worked well.
After measuring carefully where I wanted the hole (this was nerve wracking part -- second in "Oh-Sh!t" factor only to once drilling a large hole through the hull of a 36 foot sailboat) I drilled a 2 inch hole using a holesaw in the correct spot. The bumper is quite soft so the drill goes through in seconds. Just be extra careful, steady and grip the drill firmly.
After drilling the main hole and using the weather-sealing gasket as a template, I marked and drilled the four mounting holes using the appropriately sized drill bit. I should note at this point that I abandoned the included mounting screws and instead, went with stainless machine screws, lock washers, and nuts. I removed the tape before continuing, of course.
The rest was quite straight forward: insert the gasket into the hole, and then thread your FrostHeater cord (with plug freshly cut-off) into the back of the gasked (inside the bumper). I then stripped the three wires and crimped-on terminals that then were tightened-down onto the device. This made for a nice, firm, attachment. So you've got a wire coming through the back of the gasket and onto the device. Then it's just a matter of sandwiching the gasket between the device and the bumper, lining-up the holes, and through bolting with the stainless hardware.
Last steps were to seal the wire entrance hole from the inside of the bumper with some liquid electrical tape and to secure the cord to the horn using zip ties thereby creating a drip loop so that any water doesn't drip into the device.
Took less than an hour start to finish (minus the painting the day before). I placed the front of the car on ramps in order to crawl under the bumper and everything was quite accessable that way.
Here's the finished product:
Of course, I cannot assume any responsibility or liability for any problems you may encounter attempting this. Do this at your own risk.
Cheers
2004 Golf GL PD TDI
Malone Tuned, SBC Stage II Daily, Nicktane Cat 2 fuel filter, Dieselgeek bypass oil filter, Whitedog intake hose fix, A4 Defender skid plate, GLI Recaros, Check Temp III, Ventectomy, LED trunk lighting mod, Volx glass headlight lenses, VR6 front and wagon rear springs. Koni FSDs all around. FrostHeater with bumper mounted plug-in mod (details here).
OlyTDI is online now   Reply With Quote
Old September 2nd, 2011, 06:57   #2
740GLE
looks good, maybe a bit over stated, but looks like it'll hold up for year and years to come.
Old September 2nd, 2011, 10:04   #3
OlyTDI
TDI(s): '04 Golf
Thanks, 740. Actually, from a standing and walk around the car perspective, it's not at all bold. Those are in your face, ground level photos.
2004 Golf GL PD TDI
Old September 8th, 2011, 21:31   #4
Corsair
Corsair's Avatar
Fuel Economy: 52/48/??
interesting and well done- thanks for sharing.
I think those plugs are available at RV / camper stores.
I suppose the tradeoff is how one feels about cutting a hole in the fascia.
Best Regards.... Corsair....
2002 Jetta GLS TDI 5-spd 325Kmi, 2014 JSW TDI 6M
2006 Audi A4 Quattro Avant 2.0T 6M
2004 Jetta GL wagon 2.0L (gas) 5-spd (sold)
[also had 03 TDI GLS 5spd wagon bought new, sorely missed]
Corsair is offline   Reply With Quote
Old September 8th, 2011, 21:41   #5
Nurumkin
TDI(s): 04 jetta
Default re
Looks great, hope you don't mind if I copy it.
Nurumkin is offline   Reply With Quote
Old September 9th, 2011, 00:40   #6
NukeIT
NukeIT's Avatar
Looks awesome. If I lived in a cold weather climate. Would be the way I would go.
NukeIT is offline   Reply With Quote
Old September 9th, 2011, 03:56   #7
Souzafone
Souzafone's Avatar
Fuel Economy: Worst 43+ Best 56.1 Avg. 45-46
Marinco makes one for marine use that has a rubber weather tight cover. This one is held on from the back by a large nut, a hole saw allows it to mount in the lower grill securely and unobtrusively.
"I did choose to work for this car brand because their German Engineer does not follow and this cars are unique in designed."
“Your lack of Oink Oink shows that you are Dazed and Confused as the biggest content in your reply, I had authored .”
99.5 Jetta, whitish.
Souzafone is offline   Reply With Quote
Old September 9th, 2011, 08:43   #8
CGDoig
CGDoig's Avatar
Fuel Economy: 40 mpg avg, 50 best
http://forums.tdiclub.com/showthread.php?t=117822
Thats the one I did. Worked great.
2005 GLS || Malone Stage 5 || VNT 17/22 || PD130 Injectors || Eurojet FMIC
2.5" TT Downpipe / 2.5" Back || Koni FSD's || Eibach Pro-kits || Sb Stage 3
CGDoig is offline   Reply With Quote
Old September 9th, 2011, 17:39   #9
OlyTDI
TDI(s): '04 Golf
By all means -- that's why I posted.
2004 Golf GL PD TDI
Old September 9th, 2011, 17:41   #10
OlyTDI
TDI(s): '04 Golf
That's what motivated me. I knew I wanted to have it on the side. It's all good!
2004 Golf GL PD TDI
Old September 13th, 2011, 17:54   #11
Captain Morgan
Captain Morgan's Avatar
Fuel Economy: 42/50
get one with auto-eject! then you dont even have to worry about unpluggin it
Morgan
00 VW Jetta GLS TDI - 350,000 Miles, 5-Speed Swap, SMF, 108mm Flanges, VR6 Brakes, TT Short Shifter, Vogtland Springs
93 GMC Typhoon #0180 . 93 GMC Typhoon #1579 . 07 Chevy Trailblazer SS . 01 Chevy Silverado 2500HD 4x4 . 52 Cadillac Coupe
Captain Morgan is offline   Reply With Quote
Old September 14th, 2011, 07:59   #12
The J
Fuel Economy: Great!
I'd spray the top of the screws black to blend in a little more.
Nice write-up and install. Looks good!
I wonder if it's possible to install a plug behind the bumper sidemarker light?
Those lights come out pretty easily, but you'd need it to hinge and locking tab instead of just popping it into place like they are normally. It would be really sweet to flick a tab and hinge out the sidemarker to reveal a plug behind it.
The J is offline   Reply With Quote
Old September 14th, 2011, 15:02   #13
FireStorm005
FireStorm005's Avatar
Fuel Economy: 39,45,50(70mph)
Shouldn't go anywhere, but I personally would pass on putting it there on anything but a dark colored car. Anyone ever tried putting one of the round ones in a fog light bumper grille?
1985 Golf Diesel "ME" MPG: unknown (broken Odometer) (dead due to fire 2/27)
Mods: K14 w/ Turbo Pump & Injectors, Recaro seats, Tygon fuel lines, GTI vented rotors, 14" wheels
1999 New Golf GLS TDI TDTuning Stage 2, Sprint 520 nozzles, VNT17, TT downpipe, Neuspeed exhaust
FireStorm005 is offline   Reply With Quote
Old September 15th, 2011, 07:36   #14
Pat Dolan
Fuel Economy: 800km/1100km/tank
Oly:
I like your solution. I use a similar, but chrome plated one on my big trucks. The only downside is that it is getting harder to find heavy duty cords with single receptacle on the end. Been thinking of something less obtrusive for the Jetta, so your post is quite timely.
BTW: we had a not-so-bad solution to this many years ago. It was a retractable cord reel sold as the 'Hidini' (no kidding). But, it still had that goofy plug sticking out the front (as does my wifes car at this very moment). The current normal thing to do is put the connector inside of the engine room and just pull the cord out for winter, but then you end up with a big rubber plug flapping around and making a real mess all winter.
Pat
4L='14 Q7 TDI, B7='15TDI(buy back), B6='09 wagon gasser, A4=2003 TDI Variant, A3=Golf CL, A2=2x1.6 Jetta TDs, Golf Syncro Country, A1=Scirocco Mk1 & 16v, Audi 5000TD, 2014 I, Porsche 924/M471 and a bunch of diesel trucks.
Pat Dolan is offline   Reply With Quote
Old September 15th, 2011, 14:02   #15
shizzler
Fuel Economy: Solid 50, daily life.
My version:
'03 ALH Jetta: For Sale
shizzler is offline   Reply With Quote
New Plug on Frostheater bagdwag TDI 101 16 January 15th, 2011 06:54
JSW TDI Frostheater pics Bugdoc VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 1 October 8th, 2010 04:44
Looking for frostheater help and pics countryboy9799 VW MKV-A5 Golf/Jettas 7 October 20th, 2009 14:43
Frostheater Install pics Brockflock TDI 101 4 April 22nd, 2008 11:14
Two leaks found on my TDI, need help with finding solution (pics included) ocelot TDI 101 11 May 23rd, 2007 11:10
Page generated in 0.16458 seconds with 10 queries
[Output: 130.64 Kb. compressed to 109.35 Kb. by saving 21.30 Kb. (16.30%)]
