Old August 28th, 2011, 12:28   #1
wincharger
TDI(s): 2002 NB
Default drain on intercooler
Anyone ever put a drain on the intercooler?
wincharger is offline   Reply With Quote
Old August 28th, 2011, 13:18   #2
schwarze Käfer
schwarze Käfer's Avatar
Fuel Economy: Average 50mpg @ 75mph
Yep, works great, too.
Just pulling the hose won't drain it all on a beetle. You'll still have quite a bit in the bottom from the tilt of the intercooler.
__________________________________________________ ____________________________________
03 NB TDI 5sp - Sprint 520s, Bilstein TC's, Atlas Skidplate, Bixenon HID, Airhorn, NAPA Clutch/orig. DMF
New Beetle Mini H1 Bi-xenon Retrofit Performance Videos
schwarze Käfer is offline   Reply With Quote
Old August 28th, 2011, 17:02   #3
p377y7h33f
p377y7h33f's Avatar
so you drilled through the lowest part of the plastic bottom i assume?
any guidelines to make sure the fitting isn't pushed out by the boost pressure?
p377y7h33f is offline   Reply With Quote
Old August 28th, 2011, 19:15   #4
josh8loop
josh8loop's Avatar
Fuel Economy: 45 MPG City with the previous 01M, 5-speed 60+ MPG City. Always searching for ways to make it better!!
Try not to penetrate any more than 1.5" through the IC plastic, and prefferably just barely enough to ge through the plastic or else you may puncture the metal fins. Get a 1/4" or 1/8" MPT tap, and tap the hole for a plug.
2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 60+ MPG City.
Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread.php?t=306799&page=4
Now have Nokian Entyre Low RR tires!
josh8loop is offline   Reply With Quote
Old August 28th, 2011, 19:50   #5
schwarze Käfer
Yes. I removed the intercooler, cleaned it, drilled it, and cleaned it again to get the plastic shavings out. Then I roughed the plastic around the hole with sandpaper and JB welded a nut (fine thread) to it. I Put a tight fitting o-ring on the bolt I used and also use a little teflon tape on the threads. So far, so good and no leaks!
If I had it to do again, I'd probably first try using a coarse thread, sealing screw by itself, as you only need a really small hole. What I did is a bit of overkill.
x2 with what Josh said - don't go deep with the drill!
I didn't try to tap the hole, but it could work.
20-25psi isn't much pressure to worry about.
Old August 28th, 2011, 20:40   #6
AndyBees
AndyBees's Avatar
Well, mentioned that a year or so ago and got a little criticism.
So, some time in the near future, I plan to install a drain plug in my IC too. I like the idea of using the JB Weld.
'84 Vanagon '02 ALH TDI engine(32 to 35+ MPGs consistently) Malone Stage 1 tune. Road trip to Nova Scotia 2013. Road trip to Alaska summer 2014 & 2016, 11k & 12k miles. 80k miles on install, Jetta Cluster odometer currently at 209k miles.
Old August 28th, 2011, 21:00   #7
VWBeamer
Fuel Economy: 42.79 mpg Woot!
I see no need or any harm.
What's the thinking behind adding one?
On a CR that lived up north, this might be a great idea.
800 club. 828.5 miles, 16.33 gallons, 50.79 mpg.
2004 Jetta GLS Wagon TDi-17/22, 2.5 DP.2.5 Exhaust, Stage 5 Malone Tune.3 bar MAP, pd150 Injectors, Ebay FMIC, 1.8T Pancake pipe. Gutted PD100 intake.
VWBeamer is offline   Reply With Quote
Old August 28th, 2011, 23:42   #8
schwarze Käfer
<snip>
Peace of mind & ease of checking/cleaning. I'm trying to avoid a hydrolock/runaway situation. As my car ages, who knows when/if the turbo bearings will fail. The drain sure makes it easy to stay on top of it.
A few weeks after I got my car, I drained over a cup of oil from the intercooler. Of course, that was mainly due to way the previous owner drove the car, and before I learned to properly drive it.
I just drained it yesterday. Had less than 1 ounce of oil in the intercooler for about 5k miles. And now, I feel much better.
Old August 28th, 2011, 23:57   #9
schwarze Käfer
Reading some of the horror stories on here made a believer out of me.
I'm sure those that criticize wouldn't pay for your new rods or head.
JB Weld is some really good stuff. It has saved me a ton of money over the years!
Old August 29th, 2011, 03:34   #10
Henrick
I see no point in doing that.
1) oil will still accumulate shortly in there;
2) draining it won't give ANY benefit
3) you can get rid of oil in IC just by flooring your car at least once.
Henrick is offline   Reply With Quote
Old August 29th, 2011, 11:17   #11
wincharger
TDI(s): 2002 NB
Any pictures of this?
Old August 29th, 2011, 13:23   #12
VWBeamer
He is using it monitor the amount of oil collecting in the IC.
I thought the same as you before he explained it.
Old August 29th, 2011, 13:36   #13
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
My right foot insures there will never be any buildup of oil in my intercoolers.
If you ever get an amount worth "draining", you are either driving too easy or your turbo is about to die.
oilhammer
www.cardocautomotive.com
Old August 30th, 2011, 08:31   #14
schwarze Käfer
I agree. This gives me an easy way to stay on top of both issues.
Intercooler drain plug ??? new2tdiguy VW MKIII-A3/B4 TDIs 4 March 4th, 2010 13:41
Intercooler Drain Plug? Beowulf VW MKIV-A4 TDIs (VE and PD) 14 February 12th, 2009 15:44
Add Drain Plug To Intercooler? DieselFumes VW MKIV-A4 TDIs (VE and PD) 13 March 22nd, 2005 19:58
New way to drain oil from intercooler - D' op!! redmondjp VW MKIII-A3/B4 TDIs 0 August 6th, 2004 10:42
Where do you drain the intercooler? RichCA VW MKIV-A4 TDIs (VE and PD) 4 November 2nd, 2003 09:24
Page generated in 0.13415 seconds with 10 queries
[Output: 126.19 Kb. compressed to 105.68 Kb. by saving 20.51 Kb. (16.25%)]
