Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Past TDIFests > TDIFest 2011
TDIFest 2011 Discussion about TDIFest 2011 on the Labour Day weekend (September 2-4th, 2011) in Lexington, KY.
Old September 4th, 2011, 18:22   #31
Madmanmartin
TDI(s): 02 Golf
Was anyone tuning at the dyno? Thats the only reason i can see to dyno is to tune.
Madmanmartin is offline   Reply With Quote
Old September 4th, 2011, 20:41   #32
Torque_Delight
Modded
Torque_Delight's Avatar
Fuel Economy: ~5 l/100km
If it can help... Here's a picture I took of the numbers when I was there Saturday
Jetta TDI 2001 GL (~680 000 km) : GT-1749VB, EGT/O2/Boost Gauges, Scangauge II, Sachs VR6 Clutch kit, OEM G60 Flywheel, 502 Nozzles, MRTuning, Euroswitch, Hella Micro-DE w/ yellow bulb, Rear fog, Wolfsburg's Heated Seats, Koni STR.T Shocks, H&R OE Sport Springs, TT Control Arm Bushings, 17" Santa Monica (GTI VR6) Wheels, DieselGeek Skid Plate, FX35 HID Projectors Retrofit, GLI Tail Lights, 2004 Trunk lid.
Torque_Delight is offline   Reply With Quote
Old September 5th, 2011, 08:16   #33
A5INKY
Fuel Economy: pretty good
Originally Posted by A5INKY View Post
...I just emailed the dyno shop (Fast Enough Performance) inquiring about the correction factors, if any, used Saturday...
Got this emailed reply from Chris Koptizke this morning:
"...We use the built in weather station with the intake air probe at the air filter, it also factors in outside air temp, baro, and humidity. The drivetrain loss on your car should be around 35% so your crank horsepower is about 240.( we know this from extensive engine/chassis dyno testing)"
Anyone know if 35% drivetrain loss is reasonable for our cars? IIRC from reading on this forum, 15-20% loss is the usual number.
A5INKY is offline   Reply With Quote
Old September 5th, 2011, 08:38   #34
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
What did you tweak between your runs?
I thought it was odd that all of the cars were PD's. (seriously, it took me a while before I realized that in the non-tdi world that pd could mean something else)
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old September 5th, 2011, 08:42   #35
No, 35% is reasonable (a bit high) for AWD. You're right, most use 15% for FWD.
I know some of these cars and how they're set up, and all these numbers look a bit low. But it was a hot day, I hear.
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old September 5th, 2011, 08:51   #36
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
Haha.. I remember seeing that at a dyno session once and it took me a while to realize it meant that they had already PAID lol
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Old September 5th, 2011, 09:13   #37
A5INKY
What did you tweak between your runs?...
Just the tune.
Struggled getting rid of smoke for months only to have the MAF finally crap out (but somehow still pass all the "tests" I could find on the boards). Just changed to a MAFless tune a couple weeks ago and had started adding fuel back in. First run went completely smokeless and torque dropped off big time after 4000 RPM. Second runs were better but there is still room for more fuel, and I have the hardware to deliver it.
Old September 5th, 2011, 12:44   #38
Milage King
Milage King's Avatar
Fuel Economy: 40 / 46
I only got 142 hp, my tune is really smokey down low, so I set the IQ at 10, and didn't realize i had no smoke on the dyno. Oh well, was my first one, live and learn.
03 Jetta - stg 3 TD Tuning, full speed density.
Milage King is offline   Reply With Quote
Old September 5th, 2011, 14:21   #39
autoelf92
autoelf92's Avatar
Fuel Economy: 40-52
Hopefully I can break the 100 mark next year......
2002 Jetta GLS TDI 5 Speed - 214K miles - Q-Loader, VNT 17, EGR Cooler Delete Mufflerectomy, Cat Delete, Custom 2.5" Downpipe-back, Custom Race Pipe, Cage Mod, Bosio DLC 1019's, Sachs G60/VR6 Clutch & Flywheel, Frostheater, Ventectomy, More to come....
autoelf92 is offline   Reply With Quote
Old September 5th, 2011, 14:45   #40
Growler
Got Soot Vendor
Growler's Avatar
Mine was 118.6/215
It was a fun time, and I got mine done before all of the heat really kicked in. right around 10am.
I need to photograph my Dyno Sheet and post it up here.
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Old September 5th, 2011, 14:51   #41
Madmanmartin
TDI(s): 02 Golf
I have a nice article on dynos http://forums.tdiclub.com/showthread.php?t=329073
Thanks Martin
Old March 26th, 2012, 05:20   #42
Nash_TDI
Veteran Member -TDIClub Enthusiast
Nash_TDI's Avatar
Fuel Economy: 63.25mpg max
I re dynoed yesterday on the same dyno and did 178.
2.0 ALH, GTB2260, 12mm, etc, etc.....
www.nashimporters.com http://louisvillevw.org/
TDI Repair Available, TBs, Clutches, Manual Swaps, BSM, etc..
PD Cam tools, BSM tool, VE & PD TB tool rental available.
Nash_TDI is offline   Reply With Quote
Joizey Dyno Day Food Thread ChippedNotBroken Eastern USA 16 November 19th, 2010 19:10
Nov 21/22 Rocketchip Tune And Dyno Day Sign Up Thread TDI'ed Ontario 68 October 20th, 2009 16:50
NE Dyno Day VI Social/Food Thread. Varkias Eastern USA 98 October 19th, 2007 22:22
Sticky Dyno Thread? Beeah TDI Power Enhancements 5 August 21st, 2007 08:01
Page generated in 0.13893 seconds with 10 queries
[Output: 114.81 Kb. compressed to 97.02 Kb. by saving 17.78 Kb. (15.49%)]
