Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Past TDIFests > TDIFest 2011
TDIFest 2011 Discussion about TDIFest 2011 on the Labour Day weekend (September 2-4th, 2011) in Lexington, KY.
Old September 2nd, 2011, 19:55   #16
red golf tdi
Fuel Economy: 53/48/42
Looks like I will be missing the dyno, on my trip here I've lost about 4 psi over my entire boost range.
Darn, I really wanted to see what all my mods do for horsepower and torque.
Terry
1999.5 Golf TDI 2 door 402K; Owner of FrostHeater-Custom Engine Heater Kits
29+ different heater kits available for Volkswagens. Got Heat? Be warm this winter! http://www.FrostHeater.com
red golf tdi is offline   Reply With Quote
Old September 2nd, 2011, 22:43   #17
oldpoopie
oldpoopie's Avatar
Wish I was there with you guys!
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
Old September 3rd, 2011, 11:00   #18
Madmanmartin
TDI(s): 02 Golf
Default Dyno results?
I think Fast Enough uses a dyno dynamics dyno, probably the best machine I ever worked on.
Let see some numbers!!!
Thanks Madmartin
Madmanmartin is offline   Reply With Quote
Old September 3rd, 2011, 18:24   #19
Nash_TDI
Veteran Member -TDIClub Enthusiast
Nash_TDI's Avatar
Fuel Economy: 63.25mpg max
I got 163.
2.0 ALH, GTB2260, 12mm, etc, etc.....
www.nashimporters.com http://louisvillevw.org/
TDI Repair Available, TBs, Clutches, Manual Swaps, BSM, etc..
PD Cam tools, BSM tool, VE & PD TB tool rental available.
Nash_TDI is offline   Reply With Quote
Old September 4th, 2011, 07:33   #20
Madmanmartin
TDI(s): 02 Golf
Did only 1 car made it to the dyno? how many signed up? come on lets see some ###
Thanks Madmartin
Old September 4th, 2011, 11:32   #21
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
Originally Posted by Nash_TDI View Post
I got 163.
That seems low for the mods in your sig.. Did you get a torque number too? I did 200 with a similar setup, only differences for the most part were I had a stock cam, and my head was ported by 87turboquattro.. same injectors, turbo, pump, and tune as yours.. .
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Old September 4th, 2011, 12:11   #22
A5INKY
Fuel Economy: pretty good
The dyno at 'fest was a Dyno Dynamics eddy current portable unit. After being somewhat disappointed with my result I did some reading on it. From what I have gathered it is widely known as a "hearbreaker", consistently giving lower numbers than most other popular brands. It is also regarded as very consistent and accurate.
I did not think to ask about any specific correction factors used by the operator. I will reach out to them and find this out. It was quite hot on Saturday, close to 100F.
I posted 178.6 WHP.
A5INKY is offline   Reply With Quote
Old September 4th, 2011, 12:34   #23
Dieselfever78
Dieselfever78's Avatar
Fuel Economy: 44 mpg
I know of a Dyno Dynamics at a shop that specializes in Diesel trucks and many claim it seems to usually give "higher than standard numbers" that or the shop is much better at tuning their customers trucks than others.
How were the cars dyno'd? Were they loaded then accelerated or taken up to a higher RPM then loaded down and "brought to their knees"?
-Michael
2010 Golf: 2.0L TDi, 6 speed
2002 Excursion: Limited, 7.3L PSD, 4R100, 4x4
1997 F350: Regular cab, XLT, 7.3L PSD, 5 speed, 4x4
Current Best: 1/4mi - 14.3 @ 93.5mph, Dyno - 401hp & 807ft/lbs, Approx - 6700 lbs
Dieselfever78 is offline   Reply With Quote
Old September 4th, 2011, 12:45   #24
A5INKY
-Michael
I also read that the Dyno Dynamics numbers can be inflated with manual correction factors. Not saying that this is what happens at the particular shop you speak of, just that it is possible. I just emailed the dyno shop (Fast Enough Performance) inquiring about the correction factors, if any, used Saturday.
The cars were accelerated on the dyno, not loaded down once up to speed - inertia mode IIRC?
Nice numbers are good for bragging rights, and franky, I would have like to see some higher numbers at 'fest. But it seems the better use is for gathering empirical feedback in the tuning process. Fortunate for me, Fast Enough Performance is only an hour from home. I can go back and chart my progress as I get the car tuned in.
Old September 4th, 2011, 13:03   #25
I thought they were low, too. I got 184 with a very similar setup but no cam or head modifications, also on a dyno dynamics dyno. And at the last dyno day I got 167 having switched back to a 10mm pump. No correction except atmospheric on either dyno run.
Anyone else run?
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old September 4th, 2011, 13:05   #26
TDIJetta99
TDIJetta99's Avatar
I posted 178.6 WHP.
Ya mine was done on a "heartbreaker" as well, but it was MUCH cooler outside..
Old September 4th, 2011, 13:27   #27
diesel-dave
diesel-dave's Avatar
I got 163.
i think you got 163 because of those head stuPs
2003 Bora Wagon TDI Bosio R520's,colt cam, VNT 17
q loader. no smoke and so on
2001 Beetle TDI GLS Bosio 764 7 hole's, qloader, VNT 15 and so on
2010 JSW wagon DSG loaded
2003 golf auto PP520's
diesel-dave is offline   Reply With Quote
Old September 4th, 2011, 14:15   #28
jimbote
jimbote's Avatar
anyone witness my buddy Lloyd's cosmic green GTI/TDI on the rollers?...he texted me 164/247....wish I could have been there to see it...
Old September 4th, 2011, 16:29   #29
kafer65
kafer65's Avatar
That is a beautiful car! Loving that color on a Golf! Sadly, I missed the dyno runs.
kafer65 is offline   Reply With Quote
Old September 4th, 2011, 18:13   #30
jimbote
jimbote's Avatar
yeah he's poured alot of effort into that ride....I love the suede interior bits!!
Joizey Dyno Day Food Thread ChippedNotBroken Eastern USA 16 November 19th, 2010 19:10
Nov 21/22 Rocketchip Tune And Dyno Day Sign Up Thread TDI'ed Ontario 68 October 20th, 2009 16:50
NE Dyno Day VI Social/Food Thread. Varkias Eastern USA 98 October 19th, 2007 22:22
Sticky Dyno Thread? Beeah TDI Power Enhancements 5 August 21st, 2007 08:01
Page generated in 0.16679 seconds with 10 queries
[Output: 129.97 Kb. compressed to 108.44 Kb. by saving 21.53 Kb. (16.57%)]
