Old August 26th, 2011, 13:25   #1
diesel crazy
Default Engine noise on AM radio
I have the stock Monsoon radio. When I got the car back in Nov. 2010 I tried the AM radio and remember it pulling in a weak station that I listen to very well. After having the BSM done and a transmition replaced I noteced that there is a noticeable hash sound only on AM. It only happens when the engine is actually running. If the ignition is on and the engine not running it sounds fine.
Any ideas of how to track it down? Would doing the BSM and Tranny change have anything to do with it? Perhaps some ground isn't solid or some wires got put into a diffetent postition?
Any suggestion would be appreciated
diesel crazy is offline   Reply With Quote
Old August 26th, 2011, 14:19   #2
abctdi
abctdi's Avatar
Old spark plug wires?
Free bump.
05 Passat GLS 2.0 PD, UnChained & Steel GPs by VW, 15" steelies, New TB/WP, motor mounts, alt pulley, trans filter, cv boots, TSB #P9/66C8, clear bra & tint, both raxles. Now only driven 1-2 times per week. 123k miles (sold)
DD is a 2012 Kia Optima SX turbo with 274 hp and 269lb-ft@1,750-4,500rpm
abctdi is offline   Reply With Quote
Old August 26th, 2011, 15:15   #3
thundershorts
its alternator hash. you can put a couple capacitors on the b+ and it will eliminate the hash. most european cars already have them
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old August 26th, 2011, 19:45   #4
diesel crazy
I am not sure if it the alternator because the noise doesn't change with engine speed.
Old August 27th, 2011, 07:55   #5
diesel crazy
I disconnected the alternator and still have the noise. What other sources of noise would there be? Fuel pump? ECU?
Old August 27th, 2011, 11:34   #6
thundershorts
you could see if its the fuel pump by pulling fuse. it may be a ground of a shielded circuit. did you try blower fan at different speeds? any motor with brushes is suspect.
high pitch noise coming from xm radio galrol TDI 101 0 June 16th, 2011 12:01
High pitched Radio noise diesel4life TDI 101 11 October 27th, 2007 15:26
Noise/static on AM radio? vwestlife VW MKIII-A3/B4 TDIs 6 June 24th, 2005 09:47
electrical noise thru radio? marinediesel VW MKIV-A4 TDIs (VE and PD) 1 October 20th, 2004 09:28
Unwelcome noise from the radio... hover_one VW MKIII-A3/B4 TDIs 1 October 20th, 2003 05:16
Page generated in 0.13323 seconds with 10 queries
[Output: 72.21 Kb. compressed to 63.13 Kb. by saving 9.08 Kb. (12.58%)]
