Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old August 22nd, 2011, 16:44   #1
Franklosa
Default Catalytic Converter Problem ?? for 2011 VW GOLF TDI
I took my 2011 VW Golf TDi to the dealer today because of the warning light that indicates a malfunction/problem with the catalytic converter.
The car has a little less than 5k miles...
Does anybody know of problems with catalytic converters associated with new TDi's?
I am supposed to receive the diagnosis tomorrow and will update post with new information.
Franklosa is offline   Reply With Quote
Old August 22nd, 2011, 17:40   #2
El Dobro
El Dobro's Avatar
TDI(s): 2014 Volt
Fuel Economy: 120 MPGe
Are you getting the engine symbol lighting or the symbol that looks like a muffler?
"Drink the Kool-Aid" -Jim Jones
"Baa-baa-baa" -Sheep
"He's opening our minds to new ideas, KILL HIM!!!" -Futurama
Now, I drive more, worry less.
Penguin -The other white meat.
El Dobro is offline   Reply With Quote
Old August 23rd, 2011, 03:56   #3
740GLE
back when the early 2010's came out they tossed a MIL for ERG issues, it was linked to bad gasket, plus bad software, dealer took care of them. Not sure if this issues coming up but there's probably 1000 different reasons why you're seeing that MIL and no one will know until codes are pulled.
Have you noticed and driving/characteristic changes? how do you drive the car? lots of short trips or nice long highway burns?
Old September 7th, 2011, 10:49   #4
2011 Golf TDI
Warning light came on today. Engine symbol light rather than the light that looks like a muffler. Took it to the dealership and I am awaiting word on whether it will be fixed today. Took delivery of the car at the end of June and currently have about 1,900 miles on it.
2011 Golf TDI is offline   Reply With Quote
Old September 9th, 2011, 16:49   #5
mo_focus
mo_focus's Avatar
TDI(s): 84 944
I think it might be exhaust sensor or something
1984 Porsche 944- New Toy
2009 Acura RDX Turbo
mo_focus is offline   Reply With Quote
Old October 2nd, 2011, 21:06   #6
Got Haggis?
I have 5000 miles on my car and this light just came on (looks like an engine i guess...the manual claims its the 'catalytic converter' light. Hope it's nothing major, not real happy about problems so soon
the only strange thing I noticed was last week as soon as I got out of my car, I walked into a very hot air mass that was coming from my car...like..extremely hot...and then the car fan kicked in...it wasn't super hot outside, around 75 but it was very humid....temp reading on the dash seemed fine.
Got Haggis? is offline   Reply With Quote
Old October 2nd, 2011, 22:07   #7
TDI_Timmy
TDI_Timmy's Avatar
I can't comment on the light -
but if you do some searches for DPF (Diesel Particulate Filter) on this forum and read info here:
http://www.myturbodiesel.com/1000q/D...AQ-VW-Audi.htm
(The light on in the pic is the DPF needs a regeneration light - or needs more attention and needs to be seen by dealer - as it will be warranty work at this point)
it might give you some more info on how the DPF regen process works and why the fans turned on - which is why your fans started running. You either shut off during a regen or just after a regen and to keep under hood temps in check and not melt the plastic (gets really hot when that DPF is going through regen) fans kick on full speed or thereabouts to push the hot air out.
2012 JSW DSG sunroof - white - "Wally"
2004 Chevrolet Aveo - red - "Lil' Red"
1967 Ford Fairlane 500 convertible - converted to 5 speed manual - red - "Betsy"
TDI_Timmy is offline   Reply With Quote
Old October 7th, 2011, 11:33   #8
shortysclimbin
shortysclimbin's Avatar
To clear things up you have three lights that can come up for failures
1) check engine light (looks like block with a lightning bolt)
2) glow plug light (coil and it flashes)
3) DPF light
A check engine light is a more general light, it could mean you have issues with any part of the system mechanical, electrical, or computer related
A glow plug light error usually comes up with an check engine light, this is related to fuel, or glow plug issues.
A DPF light comes on with anything emissions related for DPF, or pressure related.
Some common issues I have seen and had customers with on DPFs:
1) clogged DPF pipes (VW has had four revisions of these downpipes since they first came out)
2) Bad sensors or bad gaskets
3) Intercooler pipes poping out plugging DPF
4) Turbo chargers going due to plugged or caked DPF units
5) flapper valves clogging and not operating properly so when car regenerates the particulate into ash you get a less eff. burn
The OP has an unknown issue period, I do not know if it is DPF related. Lets see what the codes/ dealer says
Got Haggis- I think your car was going through a regen cycle which goes into more detail on myturbodiesel.
11 golf- Lets wait and see what the codes where, did you have any other strange feelings or problems? Could be a loose plug, bolt, nut, or connection....
shortysclimbin is offline   Reply With Quote
Old October 7th, 2011, 15:45   #9
El Dobro
El Dobro's Avatar
TDI(s): 2014 Volt
No OP since August.
WTB: TDI catalytic converter blueskies Private TDI Items for Sale/Wanted 2 January 16th, 2011 07:44
Catalytic converter problem downcycle VW MKIV-A4 TDIs (VE and PD) 8 August 1st, 2006 18:50
TDI Catalytic Converter same as a gas? LocalAction TDI (Diesel) Emissions 2 October 17th, 2005 19:21
Has anybody seen INSIDE a TDI's catalytic converter? mickey TDI Power Enhancements 24 October 31st, 2002 22:05
catalytic converter on Golf damir VW MKIV-A4 TDIs (VE and PD) 3 June 24th, 2002 00:56
Page generated in 0.14215 seconds with 10 queries
[Output: 91.64 Kb. compressed to 78.30 Kb. by saving 13.34 Kb. (14.56%)]
