Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Past TDIFests > TDIFest 2011
TDIFest 2011 Discussion about TDIFest 2011 on the Labour Day weekend (September 2-4th, 2011) in Lexington, KY.
Old August 22nd, 2011, 13:04   #1
compu_85
Gadget Guy
compu_85's Avatar
Default Adding extra events after the fact?
I was just trying to add the Pig Roast to my order... however PayPal tells me I have to enter a value more than 0 to complete my order.
Are we using the OSCommerce cart for event tracking?
-J
Present:
2018 Tesla Model 3 DM. 3500 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 33,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old August 22nd, 2011, 18:33   #2
paramedick
paramedick's Avatar
If you bought a regular registration, you receive the pig roast automatically. Ditto with companion registration. Having said that, were at 197. The pig roast total caps out at 200, as noted on registration page.
The button was just to let us keep a quick running count. Ditto with the scenic drive and SNS button.
Old August 23rd, 2011, 12:43   #3
brnsgrbr
brnsgrbr's Avatar
Fuel Economy: 44 mpg
I just added it and chose to pay 0$ with a check.
2.0Ltr ALH w/BHWs, WB girdle, IE Tuscan rods, RyanP GtB2260Vk kit, 4bar MAP; Kerma 3" exhaust w/HF cat & Aeroturbine 3030XL, headwork, DRW 6speed w/DG Sigma shifter;SBC S2 End race clutch W/ferramic disk; Peloquin TBD; Bosio Stage 2 R520s; DLI Technik mounts ; 11mm; TT CA bushings; DG Panzer FMJ, RP,& 100K TB&SB upgrade; Coolant heater; DRL & EGR deletes; ventectomy; Accuair/Airlift suspension;B20-B100
brnsgrbr is offline   Reply With Quote
Old August 23rd, 2011, 18:26   #4
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Will your check for $0 bounce?
Svante Arrhenius 1896
Old August 23rd, 2011, 20:21   #5
cevans
TDI Parts Ninja Vendor
cevans's Avatar
I'm guessing it would for those of us that already have a negative balance!
IDParts.com - IDParts.com Vendor Thread - The IDParts Blog - IDParts YouTube Channel
My Diesel "Addiction": '17 Canyon 2.8L DMax, '11 R350 BT, '06 E320 CDI // Past: 15' Ram ED, '13 NMS, '10 JSW, '10 Jetta Sedan, '07 R320 CDI, '03 Wagon, '00 Golf 2-Dr, '00 NB (Yellow :-)
Stop Hunting for Torque Specs - Get A Free IDParts Torque Spec Poster Today!
cevans is offline   Reply With Quote
How do you specify PayPal after the fact? BeetleGo TDIFest 2007 1 July 30th, 2007 21:04
Adding an extra gas tank to a non TDI car? batchman General Automotive 7 April 9th, 2007 19:04
Adding a larger or extra Fuel Tank AlanH70 TDI 101 5 February 23rd, 2007 22:46
Interesting fact sodapop6620 TDI Fuel Economy 9 July 28th, 2006 12:28
EXTRA EXTRA Read all about it!!Tming belt changes $275.00 in the Chicago area!! Drivbiwire VW MKIV-A4 TDIs (VE and PD) 18 December 4th, 2000 07:10
Page generated in 0.16566 seconds with 10 queries
[Output: 73.15 Kb. compressed to 64.81 Kb. by saving 8.34 Kb. (11.40%)]
