Old August 22nd, 2011, 11:13   #1
sullystull
Default School me on bio-blends and winterization
I have access to B2 diesel which I try to use on a regular basis. It is supplied to the area filling stations by Holtzman Oil Corporation. I called Holtzman to see if they winterized their fuel at all in this area--they do not. I currently do not use an additive in addition to the B2.
So, my question is, should I add a (winter) additive to my '11 JSW in addition to the B2 fuel? Will adding PS/opti-lube, etc to the B2 be okay?
I live in the mountains of WV and we see 200-260" of snow/yr...similar to the upper NE. I am concerned about gelling during those cold spells. Any thoughts?
Thanks!
sullystull is offline   Reply With Quote
Old August 22nd, 2011, 11:28   #2
jettawreck
jettawreck's Avatar
Thanks!
I live in northern MN, and we have a state regulation of B5. No issues w/pump fuel to date, even w/o additives, although I do usually add a shot of PowerService White bottle formula when I run the tank down to the fuel light before refueling. I figure this dose will have the best chance of removing any moisture left in the current fuel and treat the soon to be added fuel. I haven't had any issue(s) w/"gelling" even down to -30F. I am concerned more with water in the fuel. That can give trouble at any temp below freezing, although never had that issue either, yet.
What kind of low temps are common for your location?
I don't know if any additives are officially VWOA approved for the new TDIs.
2004 Cadillac SLS (wife's)
Old August 23rd, 2011, 05:50   #3
Navy Chief
TDI(s): 2011 Jetta
Fuel Economy: around 42
If they are not winterizing their fuel I would add the recommended dose of Powerservice in the white bottle every fill up to ensure that you do not have any gelling issues with the fuel. Even if they are winterizing the fuel the additional protection from the powerservice is not going to hurt.
Navy Chief is offline   Reply With Quote
Old August 23rd, 2011, 07:37   #4
sullystull
Thanks for the info! The low extreme for us would be nights dipping into the -15F range with highs in the day only hitting 5F for a few days straight. Again, that's the extreme lows--nothing too crazy. I guess I'll start using an additive (with the B2 blend) once temps begin to drop.
Old August 23rd, 2011, 08:06   #5
naturist
@sullystull, you shouldn't have any trouble with B2-B5 if you add the PowerService. The current blend is supposed to be able to deal with blends up to B20. For what it is worth, I'm a bit south of you, our extremes only go as low as about -10, and I've run B20 w/ PowerService in those temperatures and never had a problem.
2001 Green Jetta TDI
2005 Khaki Jeep Liberty CRD, now deceased
2012 BMW X5 35d
naturist is offline   Reply With Quote
Old August 23rd, 2011, 08:13   #6
jettawreck
jettawreck's Avatar
So, my question is, should I add a (winter) additive to my '11 JSW in addition to the B2 fuel? .....
I think the answer you got from the fuel supplier is misleading. There are standards that diesel fuel has to meet for pour point, etc., depending on where normal temp "averages" are for the area. While they may not add the additives, then it is probably ordered from the refinery to meet those standards. Regardless, for peace of mind, it may be best to use PS anyways-unless it creates a warranty issue with the '11 TDI.
Old August 24th, 2011, 09:27   #7
740GLE
remember there's pour point and cloud point, two different temps. With straight untreated bio won't cloud point also lead to problems on initial start up and cold filters?
Stating that, I've never had a problem running B5 from the truckstop pumps with either stanadyne or PS White all year round clodest I saw on the MFD was -12F.
Old August 24th, 2011, 10:39   #8
sullystull
You're running the additive year round in your B5 fuel?
Old August 24th, 2011, 11:12   #9
jettawreck
jettawreck's Avatar
1) Yes, they are different temps.
2) I guess it depends on what temp you're referring to.
I run straight pump diesel fuel (B5 +/- MN) until it gets -0F then start using some PS additive, never had any issue(s) starting or w/filters (and I run a CAT 2 micron on the '01). BUT, the stations here all have fuel that is well "additve enhanced" for the normal temps expected for that time of year-with a healthy fudge factor. Some (Holiday in particular) post a sign detailing what temp the fuel is figured for and the time of year these temps are "expected".
I've had -34F on the Scan Gauge intake temp, which is always warmer than ambient when driving and with normal pump fuel B5. For whatever reason (and I have a theory), I get better warm weather fuel mileage w/o additives, so I use it when I consider needed.
Your results can/will vary.
Old August 24th, 2011, 13:07   #10
740GLE
sure, why not?
I guess I mentioned this for those reading and are thinking of splash mixing bio to make B2 or B5, that the added bio to a cold tank might sludge up much easier than the straight road pump D2.
Old August 25th, 2011, 09:09   #11
sullystull
sure, why not?
Just was curious, that's all. Thanks for sharing!
Why the heck can't I find bio blends in Edmonton? Madorski Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 5 June 19th, 2011 18:44
D2 or Bio blends,AR,MO ? chfscott Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 2 April 25th, 2011 13:46
Help high school students keep brewing bio! Joester General Automotive 10 October 19th, 2010 23:30
making bio the new school way pdxgrease Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 1 March 26th, 2008 13:36
Minnesota Insists on Standards-based bio blends? BeetleGo Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 7 November 10th, 2005 06:12
Page generated in 0.16759 seconds with 10 queries
[Output: 109.48 Kb. compressed to 93.25 Kb. by saving 16.23 Kb. (14.82%)]
