Old August 17th, 2011, 21:07   #1
BleachedBora
BleachedBora's Avatar
Thumbs up Boraparts.com 02J 5 -> 6 speed Conversion Kits!
Ordering information here.
Well folks, this kit has been a work in progress since 2005. Yes, 2005. Finally, after...well...a lot of things, we are ready to post this up. We will have pricing very soon. This is a complete bolt on kit to turn your 02J 5-speed transmission into a 6-speed. You will therefore retain your original clutch, starter, axles, mounts, shift box/linkage, etc... Everything needed to do the swap will be included in this kit. There will be different price levels depending on what you want to do.
Kits will be offered with a .658, .622 and (probably) .586 6th gear. Once you start going taller than a .586 gear strength becomes an issue. We will have options for taller ring and pinions, and probably eventually we'll have a custom R&P that can be installed.
The plan is to start with the 02J, but as interest grows for other kits we will expand. This is not limited to the TDI either, this kit will also work for the gassers. We will update this thread with information as it becomes available.
Meanwhile, here is a pic of our first working unit.
BleachedBora is offline   Reply With Quote
Old August 17th, 2011, 21:24   #2
manual_tranny
Smyth Performance- Intern
manual_tranny's Avatar
Fuel Economy: Is just one piece of the puzzle that is our bottomless appetite for oil. Cars donít have to be consumable. Instead of throwing them away, we can rebuild them, better. We have the technology.
Congrats! My Smyth build will eventually need some of those crazy tall gears. I'm not going to be happy unless 5000rpm in 6th gear = 170mph.
manual_tranny is offline   Reply With Quote
Old August 17th, 2011, 21:35   #3
79TA7.6
79TA7.6's Avatar
Location: Live: Wilbur/Creston; Work: Moses Lake Washington
So I am assuming that if someone were to go with the .586 that you would want to have something like a .681 or .658 5th gear then? Would this be part of the package as that would be a huge bump from one gear to the next?
What would someone who spends 75% at 65mph, 20% at 75mph and the rest in town want in order to be able to still drive it comfortably? I would think .681 5th and .658 6th.
2003 Jetta 5 Speed 301K miles. Malone stage 3. Titan 502 big hole injectors. VNT17 turbo. BuzzKen 2.5" down pipe. Ventectomy, EGR and cooler delete, Euro Switch, Home made custom HID.
79TA7.6 is offline   Reply With Quote
Old August 17th, 2011, 21:53   #4
DCdesign
DCdesign's Avatar
Keep up the good work Aaron!
RC4+ 24psi, 17/22, 11mm pump, 3" SS Kerma Turbo-Back, Titan 764's , STG II Franko6 Cam, ARP STUDS, SouthBend Stage 3 daily, Eurojet RACE FMIC, Custom Intercooler piping, OMI, TT Shifter/LCA's, 42 Draft aluminum shift bushings, DG Panzer FMJ, PD150 Intake, Race Pipe, Koni STR.T, GLI Sport springs, TT Brakes Front, GLI rear, 18" GLI BBS RC's, Poly bushings, O-bar, komfortblinker.Www.mmautocycle.com
DCdesign is offline   Reply With Quote
Old August 17th, 2011, 22:32   #5
BleachedBora
Thanks guys! I've been chomping at the bit for years, but I'm glad to finally have these up for everyone to start planning for!
I'll be working on charts, but if one were to go the least expensive route they'd keep their stock 5th gear and get a .622 or .586 (that ratio is not set in stone) 6th gear. That would put them at roughly (very roughly!) 75 MPH at 2,000 RPM. Also the drop from 5th to 6th would be similar to the drop from 4th to 5th, so it'd not be an overly crazy ratio to deal with. This goes in line with our idea in making the 6th gear a true overdrive gear. Obviously the more you change from your current setup the higher the cost will be.
Another option is if you're someone who tows and wants the ability to cruise in 5th we could do a gasser stock 5th gear and add a .681 6th gear for when they are not towing. There are plenty of possibilities!
-BB
Old August 17th, 2011, 22:57   #6
AUGSX
AUGSX's Avatar
Fuel Economy: 36 mostly city/ 43 best
Will this work with my 3.16 RG and current Limited Slip?
2001 Jetta GL TDI 5spd
Build thread
http://forums.tdiclub.com/showthread.php?t=307477
AUGSX is offline   Reply With Quote
Old August 18th, 2011, 01:27   #7
squire89
squire89's Avatar
TDI(s): 2002 jetta
Fuel Economy: low 40s
...prices?
2002 jetta
check the thread for mods along the way
squire89 is offline   Reply With Quote
Old August 18th, 2011, 05:13   #8
arne487
arne487's Avatar
Fuel Economy: 62.4 max, 53 avg
Lots of questions (some already asked). Will an 02J LSD and CTN R&P still work in this setup? Will any strengthening or oiling mods be offered? How much torque will it be able to handle? And most importantly, how much will it cost?
His: '03 Golf - The Saga Continues
'04 Passat Wagon 1.8T 4-Motion 5-Speed - Bone Stock
Hers: '10 TDI Cup Jetta - Now back in the hands of VW.
arne487 is offline   Reply With Quote
Old August 18th, 2011, 12:34   #9
paramedick
paramedick's Avatar
Oooh! You found the fabled good ol' boy that VW hosed!! Good work!
Old August 18th, 2011, 15:50   #10
dieselfuel
-BB
That sounds like a great idea! Would a WaveTrac fit, also?
df
2003 Jetta TDI 200,000 mi. Horrible fuel milage? Check your thermostat: http://forums.tdiclub.com/showpost.p...49&postcount=7
dieselfuel is offline   Reply With Quote
Old August 18th, 2011, 16:25   #11
boertje
boertje's Avatar
Now he comes out with this after I sold my 5 speed out of my bug. Oh well.
'01 and a 2nd '01 and a '03 NB TDI with 6 spd manual. '06 NB GLS TDI DSG.
All with Malone tuning of course.
Auto to 5/6 spd manual swap with wiring instructions for MKIV. Click here.
boertje is offline   Reply With Quote
Old August 18th, 2011, 17:04   #12
79TA7.6
79TA7.6's Avatar
Curious if the cruise still works too. If I knew more about transmissions I would likely not have to ask this, but I am asking.
Old August 19th, 2011, 05:39   #13
mech644
Yup, I'm down for this, depending on cost of course. Looking fwd to anwers for the above ?'s.
2012 Platinum S-line A3 DSG- bought back by VW
2000 Golf 5spd, 301k, the usual mods, sits forlornly in the backyard.
2006 Jetta DSG- gone
2015 GHB SEL 1.8 tsi
2014 Touareg
mech644 is offline   Reply With Quote
Old August 19th, 2011, 06:37   #14
drklawz
Default i think i love you
subscribing to this one! KEEP UP THE GOOD WORK, we need a viable, affordable option.
I'd talked with you before about the .658 for cruising in the mountain states... sounds like i should hold off on that and wait...patiently wait.
ALH w/ 02J gets goosed!
drklawz is offline   Reply With Quote
Old August 19th, 2011, 07:47   #15
john.jackson9213
TDI(s): 1996 B4V
Very interested in this add on 6th gear. Surprised it took me so long to spot the thread. How much testing has been done with the first transmission?
john.jackson9213 is offline   Reply With Quote
FS- 02J 5 speed Manual Tranny conversion kit w/ LSD & 3.16 R&P for Modded car tothemax Private TDI Items for Sale/Wanted 15 January 31st, 2011 16:56
6 speed conversion kits. Labor costs?? Oil_Burner TDI 101 1 October 26th, 2010 09:58
Proper Valeo SMF Conversion/Clutch Kit for MKV TDI BRM on boraparts.com theinternot VW MKV-A5 Golf/Jettas 18 July 18th, 2010 15:20
Proper Valeo SMF Conversion/Clutch Kit for MKV TDI BRM on boraparts.com theinternot VW MKV-A5 Golf/Jettas 0 July 4th, 2010 17:42
Attention, all you speed freaks in Tampa Area >>>> LuvaDub Eastern USA 45 March 12th, 2004 11:39
© 1996 - 2020, All Rights Reserved
Page generated in 0.17789 seconds with 10 queries
[Output: 134.38 Kb. compressed to 112.50 Kb. by saving 21.87 Kb. (16.28%)]
