Old August 14th, 2011, 23:06   #1
TDIdragon
TDIdragon's Avatar
Fuel Economy: 32-City 36-Hwy 30-Towing
Question Fuel Door Actuator Solenoid Quest
Okay... I have been putting up with what I thought was a fuel door switch issues for several weeks now. Today I got the bug to fix it. So, I took the switch out and tested it. The switch works. It works really well.
Against my better judgement with only an hour before bedtime, I dove into the trunk of my Golf to test the wiring to the actuator. First a little background here: I did fix the actuator on my ALH Jetta by just cleaning it (and the rest of the car was worse). So, I was somewhat familiar with the process. I thought it would be just as "easy" as the Jetta. I was wrong. The fuel door actuator in the Golf is actually up C-pillar which requires removing the trunk carpeting, the deck lid track and part of the C-pillar covering. After loosing one of my sockets to the depths of the interior, I ended up taking out more of the molding than initially planned and cursing uncontrollably...
Okay, I digress. Long story short(ish), after testing the switch, the wiring, and the actuator; I have found the actuator to be faulty. My plan is to put in a manual release lever in the trunk area, but I would like the switch in the driver's door to still be operational. I have found plenty of used actuators for $30-$35, but I would really like to get a new one without visiting the stealership (dealership for those of you not familiar with VW TDI lingo). Does anyone have a vendor they can point me to while I still have the trunk torn apart?
BTW - the part number is 1J6810773C.
Cheers!
-Mark
1998 Jetta TDI 5-speed SOLD
2000 Jetta TDI GLS 5-speed SOLD
2004 Golf TDI-PD GL 5-speed
TDIdragon is offline   Reply With Quote
Old August 14th, 2011, 23:20   #2
AARodriguez Corp.
AARodriguez Corp.'s Avatar
Cheers!
That would be me (Vendor), how is this for a manual release, Fuel Door Remote
$45 for a used actuator, and a Fuel Door Remote Kit
http://www.aarodriguezcorp.com/fuel-...mote-kit1.html
AARodriguez Corp. is offline   Reply With Quote
Old August 16th, 2011, 09:40   #3
TDIdragon
TDIdragon's Avatar
That's a really nice setup. However, it still relies on that actuator to work. I was thinking of a T-handle in the trunk in case any of failure of the motor or the electrical circuit that powers it.
$45 for the actuator doesn't seem bad at all, and if it includes the remote kit - then that is a hell of a deal! I could have 3 ways to potentially get into my fuel tank (not including the credit card method I have been using).
Most importantly, though, I need that actuator.
-Mark
Old August 16th, 2011, 12:37   #4
TDIdragon
TDIdragon's Avatar
Question
In any case, you have a used actuator that you are willing to sell me for $45 + a fuel door remote kit? How much is shipping to 78258?
-Mark
Old August 17th, 2011, 16:59   #5
AARodriguez Corp.
$5.00 for USPS priority mail
Fuel Oil Industry Advice Needed / Quest Fuel 97pssat04golfTDIs Fuels & Lubricants 2 March 1st, 2011 20:09
LF :Fuel door solenoid Craig Doucette Ontario 0 May 28th, 2009 16:40
fuel filler door wont close/actuator not working waywardsmile TDI 101 4 February 24th, 2008 16:50
Fuel solenoid issue(n109). possibly related to my fuel quantity? claytski VW MKIII-A3/B4 TDIs 7 February 5th, 2008 13:47
Ventectomy- fuel door solenoid quit working? xsfmed TDI 101 2 May 10th, 2005 14:00
Page generated in 0.11080 seconds with 10 queries
[Output: 75.58 Kb. compressed to 67.16 Kb. by saving 8.42 Kb. (11.15%)]
