Old August 11th, 2011, 19:51   #1
mikeygstl
Default Whine in 5th and 6th gear, DSG
New JSW - Had an 06 with the DSG, and never heard a peep out of it.
This JSW, I can hear a hollow whine as the transmission spools up 1st through 4th between 1200 and 2k rpm, then when I get into 5th and 6th the 'whine' becomes somewhat erratic - seems to disappear when there is no load, either deceleration or acceleration produces the whine.
Kinda sounds muffled - imagine hearing a shop vac running through a brick wall by holding a plastic cup to the wall and putting your ear to it - I know, kinda odd, but that's the best thing I can think of to replicate it.
Any ideas? Really quite annoying. Of course, I'm also one of those guys that can tell when the bearings are just starting to go out on the neighbors pool pumps...
I also get a rather violent stutter at times when the motor and tranny are cold with a slight bit of accelerator - not sure if the two are related.
mikeygstl is offline   Reply With Quote
Old August 11th, 2011, 21:55   #2
PureDope
PureDope's Avatar
TDI(s): MKVI JSW
Sure it's not the effect of the summer heat? I'm in az where it's been 110+ a lot lately, and I've noticed the same thing, except it's in every gear, same rpm range as you. Given I do have a tune as well, so it might just be the turbo + dpf complaining. I've also noticed my car pulls much harder in the night time when it's in the 80's. God I can't wait for fall.
// 2011 GSW 2.5 5MT // H&R TOURING CUP KIT // DIESELGEEK SIGMA-5 // DEAUTOKEY.COM LED LIGHTING //
PureDope is offline   Reply With Quote
Old August 12th, 2011, 06:38   #3
mikeygstl
Well, the sound occurs when the motor and dsg are cold or hot.
Old January 24th, 2012, 14:45   #4
whiplash willy
whiplash willy's Avatar
I have the same noise in my DSG. It started after I had about 5000 miles on it, and seems to have gotten worse. Did you ever figure out what the problem was?
NCS & DSG Free Since 5/5/12!
whiplash willy is offline   Reply With Quote
Old January 24th, 2012, 16:13   #5
pknopp
Why not have the dealer look?
pknopp is offline   Reply With Quote
Old January 25th, 2012, 08:09   #6
mikeygstl
Default Still there
I took mine to the dealer as soon as I noticed it. They claim to not hear it. Seems worse when it is warmer outside.
Most noticeable between 1300 and 1600 RPM.
I am waiting for the weather to warm, and then I am taking it back in. There is definitely something 'off'. I thought it may have to do with the resonance in the fuel line, but I had that fixed and no joy. There was also a TSB about the cowling being loose on the drivers side, and causinga vibrating hum at certain RPM's, but that was not it either.
Anyone else heard anything?
Old January 25th, 2012, 11:51   #7
whiplash willy
It is difficult to hear unless you really listen for it, and even then, someone less anal then myself likely wouldn't hear it. I am also a little nervous about the dealer doing that kind of major work on my car!
I probley will be taking it in soon, and try to get a tech to ride along with me to hear it. I wish it was something minor that I could fix myself, but that is likely not the case!
Old January 25th, 2012, 12:53   #8
pknopp
If it's under warranty (and it might not still be for all I know) nobody else would fix it.
If it's not under warranty, I understand all attempts at an answer.
Old February 8th, 2012, 12:48   #9
whiplash willy
I only have 8k miles on it, so it is still under warranty. I took it into the dealer, and their master tech let me drive him around a bit. Of course, it was a little warmer out that day then usual, and I couldn't reproduce the sound....Now that it is colder, the sound is back again.... It seems to be worse when the weather is colder, and it doesn't happen above 50*F.
I will either have to take it in when it is cold out, and hope I can reproduce the sound and they hear it, or wait until it really gets bad (loud) and take it in then.
Once the 2013's come out that are less gimped, I may just have to trade it in for one with the 6MT.
Old May 14th, 2014, 17:36   #10
TQOOOO
TQOOOO's Avatar
I have exactly same problem with 2014 Jetta.
First noticed at 300km , now at 3000km it is getting worse.
mikeygstl, have you ever find what makes that noise?
TQOOOO is offline   Reply With Quote
Old May 15th, 2014, 00:07   #11
mikeygstl
Default whine
Honestly, no. I have had two DSG's, and this one is the only one I have heard it in. I am quite irritated with VW at this point, and don't think I will ever purchase another VW or Audi. I have had problems with the panoramic sunroof seal, a taillight, the whine, a rattle under the dash, as well as a new sound from the middle of the dash that sounds like a vacuum leak (isn't everything electronic now?). Oh, and if there are springs of some sort in the drivers seat, they are shot (we have less than 30k miles on the wagon, and I weigh a whopping 165 lbs).
Needless to say, my 2006 was a WHOLE lot better than this POS. Hopefully I can sell it for a diesel Durango here shortly.
Oh, and the fuel mileage has been horrid. In my '06 we would routinely get 42 mpg average. This one I see 31, 32 if we are lucky.
I did finally find tires that smooth out the ride and make it a bit more comfortable and predictable. Pirelli Cinturato P7. I totally recommend them for this car. completely.
Honestly - I think most of my problems could be resolved if I could simply trade this DSG for a manual - which is ironic because I first test drove a manual when I fell back in love with the TDI after my wife having the 06. VW - is there any way I could tak you into a tranny swap for customer satisfaction?!!?!
Did I mention the gear hunting that occurs at around 30 mph. 3-4-3-4-3-4-3-4-3-4-3-.... . yeah, and guess what the speed limit is around where I live....
Old May 15th, 2014, 06:39   #12
DRbillZ
DRbillZ's Avatar
Fuel Economy: NB-usual:41-42 max:47; Jetta:usual: 44highway
Put it in manual mode and hold a single gear.
-2000 New Beetle TDI GLS. 154,000 miles. TOTALED
-2005 Passat TDI. Stonhenge grey,TOTALED!
-2006 Jetta TDI Platinum grey, 126,000 miles
-2002 2.0L gasser Jetta 125,000
-2012 Jetta Sportwagen TDI 13,800 miles DSG
DRbillZ is offline   Reply With Quote
Old May 15th, 2014, 08:06   #13
mikeygstl
In this day and age, I don't think that continuously hunting for a gear is acceptable. My 69 camaro certainly didn't hunt.
Old May 15th, 2014, 09:15   #14
TQOOOO
TQOOOO's Avatar
So VW told you to put your ear plugs in and enjoy your new car? Did you complain to VWoA?
Old May 15th, 2014, 09:17   #15
BarnyardsTDI
Fuel Economy: Depends on my right foot
79,200mi on my DSG. No whine.
BarnyardsTDI is offline   Reply With Quote
Cruise Control Fix for 2004-2006 Golf/Jetta PD TDI with upgraded 5th gear or 6th gear Mark@MaloneTuning TDI Power Enhancements 14 February 28th, 2014 19:02
6th gear change for DSG ?? iboomalot TDI Fuel Economy 2 May 25th, 2009 15:24
DSG: Changing 5th/6th for better MPG? gary556 TDI Fuel Economy 14 July 11th, 2006 07:26
5th & 6th Gear economy Yebo1 TDI Fuel Economy 2 March 30th, 2005 23:41
VW 5th & 6th gear add on kit MacLeod TDI 101 4 December 6th, 2004 19:11
Page generated in 0.17685 seconds with 10 queries
[Output: 124.55 Kb. compressed to 103.54 Kb. by saving 21.02 Kb. (16.87%)]
