Old August 10th, 2011, 12:18   #1
gorsuchmill
Default Replacing throttle body - 2005 Passat TDI
I'm fairly decent with a wrench, but by no means a skilled mechanic. Anyway, I've been told my throttle body is bad and needs to be replaced. How difficult is this as a job and what steps are involved?
Thanks in advance.
gorsuchmill is offline   Reply With Quote
Old August 10th, 2011, 14:57   #2
JFettig
JFettig's Avatar
Unless this is a gasser, you might want to get a second opinion.
Minnesota Malone Tuning dealer
1998 B5 Passat TDI Compound Turbos
2009 JSW Stage 3 196whp so far
DIY injector calibration http://forums.tdiclub.com/showthread.php?t=383324
JFettig is offline   Reply With Quote
Old August 10th, 2011, 15:58   #3
gorsuchmill
Not a gasser and the shop which diagnosed it seems to know what they're doing. Between the throttle body repair and others money will be real tight, so I'm trying to save where I can. Anyway, the shop told me there appears to be an internal electrical malfunction with the throttle body, which is causing it to lose communication with the whatever it is that it communicates with (I can't remember - ECM?)
Old August 10th, 2011, 16:20   #4
Alchemy
Alchemy's Avatar
Fuel Economy: N/A
There is no throttle body on a Passat TDI, engine speed is regulated by fuel amount. These engines suck as much air (well, air and exhaust gas) as possible at all times, so there is no traditional throttle plate.
What issue are you having? Did they read a DTC (Diagnostic Trouble Code) and if so, what code was it? If you post that information here, people might be able to help guide you a little more.
Past as of 12/9/2016 - 2012 Jetta Sportwagen TDI - Platinum Gray, Black, DSG, Panoramic Roof
Past: 2005 Passat GLS TDI Wagon - Silverstone w/ Anthracite Leather - Unchained
Past: 2000 Jetta GLS TDI 5 Speed - Galactic Blue w/ Tan Leather
Alchemy is offline   Reply With Quote
Old August 10th, 2011, 16:22   #5
Questor
Fuel Economy: Most impressive...
The reason we're all chuckling on this side is that there is no throttle body on a diesel car...
There is a kind of flap valve they might be referring to (Search 'EGR' or 'EGR Cleaning', but ANY competent mechanic should know the difference... RUN!
What are the symptoms you're trying to have repaired?
Edit: Alchemy beat me to the punch, but yeah, DO let us know what is wrong with the car and perhaps we can steer you the right direction.
Questor is offline   Reply With Quote
Old August 10th, 2011, 21:33   #6
gorsuchmill
I'm using the term throttle body because that is how it was communicated to me, not to mention that I have seen others on here comment that the newer diesels do have a version of throttle body. I understand it to be the same as the flap to which you are referring. Anyway, I don't recall the error code being thrown, but the car will suddenly go into limp mode with no warning. I can turn the car off and limp mode is gone, but returning more frequently to the point I can't drive the car.
Thanks for youe help.
Old August 10th, 2011, 21:46   #7
aja8888
aja8888's Avatar
Fuel Economy: About as good as it gets!
Pretty much the vast majority of limp mode cases with 2004-05 Passats discussed here have been the result of a split turbo/intercooler hose or a bad vacuum hose. I have experienced both types of failures.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
Bring the 1971 Beetle back to life thread:
http://forums.tdiclub.com/showthread.php?t=472400
aja8888 is online now   Reply With Quote
Old August 11th, 2011, 05:50   #8
owr084
You're in Baltimore? Contact "TDIRacing" He is one of the best TDI guys in your area.
RBB
2005 VW Passat GLS TDI (Chipped, BSM delete, and Manual ), 2007 VW Eos 2.0T, 2015 Toyota Sienna XLE, 2017 VW Jetta SEL 1.8T
owr084 is offline   Reply With Quote
Old August 11th, 2011, 07:32   #9
gorsuchmill
Thanks and I sent a PM to him yesterday, but I'm looking to replace the body myself to reduce the cost. The part number is 03G128063J, which is identified as a "flap" by 1stVW Parts.
Old August 11th, 2011, 08:01   #10
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
Take the air inlet pipe off of the EGR and look inside, then do what Questor recommended: search "EGR cleaning". Just clean it and save yourself $350.00!
-George Bernard Shaw
Old August 16th, 2011, 05:10   #11
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
The throttle bodies fail on these sometimes. The set a DTC, the gears strip out. Not sure what your mode of failure is, but it could indeed be bad. Not hard to replace, just three Allen screws and the electrical plug.
As for semantics: Volkswagen calls this an 'intake manifold control flap', Mercedes-Benz calls it an 'EGR throttle valve', BMW calls it a 'throttle body' (or 'throttle valves', where equipped), Bosch calls it a 'throttle control valve'. So whatever you choose to call it, the term 'throttle body' fits, as if you saw it laying on the bench next to one from a gas VAG product, the only way you could tell the difference is that the diesel one spring loads open and the gas one spring loads shut.
But for the record, ALL newer diesels do indeed have throttles, some have several, and many older diesels do as well. People should study diesel engines throughout history up to and including present day before they spout off nonsense about "diesels don't have throttles" because that simply is not true.
As far as the throttle's purpose, well that is a lessen for another day....
oilhammer
www.cardocautomotive.com
Replacing the antenna on a 2005 Passat TDI sedan tomg13 Upgrades (non TDI Engine related) 0 August 31st, 2010 19:33
throttle body delete? Golden Dub TDI Power Enhancements 56 August 5th, 2009 05:55
where is the throttle body?! petertf TDI 101 15 October 9th, 2007 08:42
2004 Passat TDI Throttle Body? jdshinn TDI 101 4 July 18th, 2006 09:23
A throttle body on a TDI (are you for real) antirice2 TDI Power Enhancements 3 May 13th, 2004 18:43
Page generated in 0.14893 seconds with 10 queries
[Output: 103.51 Kb. compressed to 87.34 Kb. by saving 16.17 Kb. (15.62%)]
