Old August 7th, 2011, 13:52   #1
golforfiesta
TDI(s): 2011 Golf
Default History of the 2.0L TDI Engine?
Can anyone post a link or info about the history of the TDI 2.0L engine that is now standard in the USA? Also, is this the exact same motor that is in the diesel version of the Audi A3? Thanks
golforfiesta is offline   Reply With Quote
Old August 7th, 2011, 14:16   #2
JSWTDI09
JSWTDI09's Avatar
This link gives a pretty good history on VW diesel engines (including the newer common rail ones). http://www.myturbodiesel.com/1000q/pumpedusedesc.htm
The US version 2.0L CR diesel is almost identical, no matter what car it is installed in. From what I've been told (and I could be wrong) the only significant difference between the Audi A3 engine and the VW Golf/Jetta engine is that the Audi version has an oil level sensor in the oil pan. The VW and Audi engines are all CBEA (for 2009) and CJAA (2010+) engine codes. If you do a search you will find a nice "self-study guide" on these engines that goes into great detail on how they are made and how they work.
Have Fun!
Don
JSWTDI09 is online now   Reply With Quote
Old August 7th, 2011, 15:18   #3
GoFaster
Moderator at Large
What do you want to know about the "history"?
It is part of an engine family that traces its origins back to the first in-line liquid-cooled engines that VW began building in the early 1970's, although there have been so many evolutionary and revolutionary changes since then that there are no parts in common. There are some telling dimensions that have always stayed the same ... notably, the 88mm spacing between cylinder center-lines and the locations of the fasteners that bolt the head to the block.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
2.0L TDI Engine parts DougVirginia Private TDI Items for Sale/Wanted 3 January 10th, 2010 14:30
2.0L TDI (0 miles) Engine for sale AeroTDI Private TDI Items for Sale/Wanted 0 October 21st, 2007 20:13
2.0L TDI engine ideas Hasenwerk TDI Power Enhancements 22 September 14th, 2006 06:46
FS - oil pan for TDI or 2.0L engine penclnck Private TDI Items for Sale/Wanted 0 December 12th, 2005 10:01
A Little VW TDI Engine History for FL-Man SkyPup VW MKIV-A4 TDIs (VE and PD) 32 April 16th, 2001 14:26
Page generated in 0.11315 seconds with 10 queries
[Output: 58.12 Kb. compressed to 52.73 Kb. by saving 5.39 Kb. (9.27%)]
