Old August 5th, 2011, 22:26   #1
4wd-n-archery
Default 1.9 tdi oil pressure?
My 2003 jetta has an oil pressure gauge installed. When I first start it cold it is at about. 40 psi. When I start driving for about 2 miles it is at 60 psi. Once it warms up it settles in at about 35 psi. These reading are cruising at 2000 rpm.
Anyone know why the predictable inconsistencies?
Also oil level is correct, and it runs great. Doesn't seem to be a problem but I really watch it for the first couple miles.
4wd-n-archery is offline   Reply With Quote
Old August 5th, 2011, 22:34   #2
rockwood
rockwood's Avatar
Fuel Economy: 46.2 Lifetime
Oil thins as it warms. Therefore, warmer oil = lower pressure. 10 psi per 1000rpm is the old school standard, but really just pay attention to what it usually is and watch for deltas.
MotoIQ Project Hyper-Miler TDI:
http://www.motoiq.com/projects/proje...jetta_tdi.aspx
rockwood is offline   Reply With Quote
Old August 5th, 2011, 23:51   #3
RacerTodd
RacerTodd's Avatar
Fuel Economy: about 50
I have an 80psi gauge on my 2001 TDI. When cold it pegs the gauge at idle, summer or winter. Once warm, idle pressure is around 20psi, at 2000rpm about 40, at 3000rpm closer to 50-60.
Todd
Seattle,WA
'86 GTI, Red of course. (exciting racey car) 274,000 miles
'01 Golf TDI, silver. (new work car) 558,000 miles!
'87 Golf, Polar Silver. (retired work car) 654,000 miles <- Gone to a new home
RacerTodd is offline   Reply With Quote
Old August 6th, 2011, 00:03   #4
fantomas
The only VW specs one can find:
min. 31psi at 2000rpm and
min. 47psi at 3000rpm
with warmed up engine.
fantomas is offline   Reply With Quote
Old August 6th, 2011, 05:50   #5
4wd-n-archery
Well that sums it up fairly well. My oil pressure seems to be spot on.
Thanks guys
Old August 6th, 2011, 05:51   #6
4wd-n-archery
Thanks guys
Old August 8th, 2011, 17:59   #7
Bran Diezel
Bran Diezel's Avatar
Fuel Economy: 50mpg
i was thinking of installing one on my car. are there any pods that don't mount in the place of the radio or on the "A" pillar? i haven't looked for the hook up on the block/sending unit yet either. where is yours installed?
Bran Diezel is offline   Reply With Quote
Old August 9th, 2011, 07:02   #8
Corsair
Corsair's Avatar
Fuel Economy: 52/48/??
Lightbulb gauges- what I did... (Jetta)
Not sure if the golf uses same steering column / instrument cluster clearance as the jetta ? I found a neat two-gauge pod that sits atop the steering column, perfect. Still gives visibility of the gauges and center cluster of "idiot lights". In my particular seating posture, I can directly still see the odo and trip odo, but have to move my head to the left a bit to get full view of the LCD clock (which is on left side). I'm perfectly willing to do that, for the presence of the easily mounted gauges. Now, if I could just remember where from did I get the gauge pod? Actually I think it might be a device marketed by auto-meter gauges, that I purchased through Summit racing. I'll do some digging and post back to this thread if I can find specifics (for the jetta, anyway- hope it may be same for Golf).
YES, I FOUND IT AT SUMMIT. SAYS GOLF AND JETTA, ~ $33, HERE's LINK
http://www.summitracing.com/parts/ATM-20020/
If your car has pillar air bags, then pillar mounted gauge is a no-no.
The oil pressure sending switch, where you can tap into engine oil pressure is mounted: Look under hood at the oil filter. Base of that housing, on passenger side, you'll see something screwed in with single wire sticking out. That is the oil pressure switch. A Tee is installed there, into which the stock pressure sending switch + the new oil pressure sending unit is installed. Running the wires is very easy with a TDI of these years, because there is a plugged knockout hole in the firewall that would otherwise take the cable from the accelerator pedal. (TDIs are drive by wire and the wire is routed elsewhere).
As for specific gauges, there are many choices. Here's what I did. Note it comes in two portions: The Good, and The Unresolved.
The Good
I stumbled across a company McNally Instruments located in Florida. Looks like this might be a small off-chute company of an avionics company. They have a neat web site (google). (I am not affiliated with them, nor am I a bird-dog.)
Their gauges, each gauge has a needle and digital display. That is, a single gauge can display two different quantities at the same time. So, you could have one gauge that displays oil pressure and boost at the same time- saves space etc. BTW all the gauges have a function by which they will display the vehicle system Voltage for a few seconds on press of a button.
They offer some gauges aimed specifically at the VW TDIs
They offer gauges in different (backlight + digital display) colors. (so, I was able to get gauges that have the same blue lighting as rest of my jetta dash)
Specifically for the VW oil pressure, they offer a small machined metal manifold that you screw in where the stock oil pressure sender switch goes. The manifold has 3 ports: Stock switch + new oil pressure sender + new oil temp sender if you choose to do all three, else plug the unused port.
Expect to pay around $250 for a typical gauge. Agreed, that's quite a sum of $ for a single gauge, but then again it's a highly integrated unit that takes the place of two gauges.
For the record, I bought 2 gauges:
Oil pressure on needle, oil temp on digital
Boost on needle, EGT on digital.
I also bought the oil pressure sending manifold.
Items are of high quality, installed as described. They do not have a separate wire for gauge backlighting. (no tapping into vehicle dimmer ckt etc.) They use a light sensor within the gauge, that dims the gauge at night. I was concerned that I would not like this, wanting to have control over it myself. Now that I have them, I'm content with the auto dim operation.
The Unresolved
Two issues:
[1] I mentioned earlier that the gauges have the ability to display vehicle Voltage for a few seconds. (you press one of the small buttons on the gauge twice quickly). Well, one of the gauges seems to be calibrated wrong, as it displays about one Volt higher than what the system Voltage actually is (and what the other gauge, and my DMM indicate...) I suspect this is just a simple factory cal "human error" issue. I contacted McNally and they told me no problem, return the gauge and they'll address it.
[2] One or both of the gauges I installed, is causing significant radio interference with the stock (monsoon) radio in my jetta. FM reception is greatly decreased, and AM reception is also affected. I have narrowed the source down to the gauges, no question. I have not narrowed it any further to determine if it is one gauge in particular, or both etc. Ball is in my court, I simply have not had the time to diagnose further. (I'm an electrical engineer....) I did contact McNally and ask them about this, they say they have not had any complaint about interference from the gauges. So, at this point, I know that I will be returning one gauge to have the VDC recalibrated. I have not returned that gauge yet, because I want to first diagnose the interference and see if it is coming from one gauge etc. I have specific steps / tests in mind to do, but life is busy in other areas at the moment and I simply have not had the time. I'm confident that I can address the interference issue. Note it may not be the gauges themselves, but could be how the wiring is installed (by me) in the car. I'm writing this in the interest of disclosure, not to beat up the gauge company. Again, ball is presently in my court. I am very happy with operation of the gauges.
Why are Corsair's posts always so long??
Best Regards.... Corsair....
2002 Jetta GLS TDI 5-spd 325Kmi, 2014 JSW TDI 6M
2006 Audi A4 Quattro Avant 2.0T 6M
2004 Jetta GL wagon 2.0L (gas) 5-spd (sold)
[also had 03 TDI GLS 5spd wagon bought new, sorely missed]
Corsair is offline   Reply With Quote
Old August 9th, 2011, 17:16   #9
Bran Diezel
Fuel Economy: 50mpg
haha great follow up man. i appreciate it. I think i may check out the autometer cobalt gauges. i think they will match decent.
Old August 19th, 2011, 11:16   #10
smltwnguy30
Fuel Economy: Avg 42 mpg Max 52 mpg, before build
Corsair, I have dual McNally gauges in a new south pod on my steering column also. You should maybe switch your power wire location and check wherevyou put your ground. Under the steering column if you used the terminal strip for key on accessory power you shouldn't have an issue. Also it's easy to see one of the ringed safety ground points directly under the center of the steering column (if I remember right, but I'm 100% positive it's easy to see when you remove the paneling under the column) if I have to I could take some pics? Hope that you clear up the issue...
VNT-17, 2.5" exhaust, DLC 1019's, Kerma Tune, IDParts IC and intake piping, Colt Stage 2 Cam, SouthBend Stage 2 Endurance Clutch, Passenger Race Pipe, Custom ASV, EGR+cooler delete, DieselGeek short shifter, McNally Gauges, Royal Purple Synthetics, Custom Stainless Steel PS cooler, modified Megan Racing oil catch can, AFE CAI, Snow Performance MPG MAXX kit, Audi TT bushings, Ziza LED's throughout, 0.658, LSD, tons of custom mods!
smltwnguy30 is offline   Reply With Quote
Old August 19th, 2011, 12:38   #11
Corsair
Corsair's Avatar
Many thanks ! This is encouraging. Does your car with the McNallys happen to have the VW monsoon radio ? And I assume you're stating no issues with radio interference ? I really need to work on this, but have been so busy with other things...
Old August 19th, 2011, 21:13   #12
AndyBees
AndyBees's Avatar
I'd venture to guess that that the 4 spray oilers (for cooling purposes primarily) at the bottom of each cylinder and the oil feed to the Turbo have a tendacy to lower the pressure comparative to a similar engine without those characteristics.
Also, the pressure relief system (in the oil pump and/or filter housing) may vary from engine to engine as to how it operates!
'84 Vanagon '02 ALH TDI engine(32 to 35+ MPGs consistently) Malone Stage 1 tune. Road trip to Nova Scotia 2013. Road trip to Alaska summer 2014 & 2016, 11k & 12k miles. 80k miles on install, Jetta Cluster odometer currently at 209k miles.
AndyBees is online now   Reply With Quote
Old March 6th, 2014, 07:01   #13
drozia
Hello. My AFN engine measures higher than 5 bar (50 psi) at cold or hot any time stable at display. It doesn't change. what is the cause for this problem? or is it a problem?
drozia is offline   Reply With Quote
Old March 6th, 2014, 20:30   #14
AndyBees
AndyBees's Avatar
Could be a faulty gauge or sending unit.............
Old September 12th, 2015, 21:04   #15
joecitizennn
TDI(s): jetta
Hmm my oil is
29psi hot idle
52psi hot 2000rpm
75psi hot 3000 rpm
Guess thats a little high?
joecitizennn is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
98 TDI , no oil pressure thysmar VW MKIII-A3/B4 TDIs 10 February 11th, 2010 06:05
09 TDI where is the oil pressure light isa540 VW MKV-A5 Golf/Jettas 2 April 19th, 2009 08:56
Dual pole oil pressure sender for TDI? Fahrvergnuugen VW MKIV-A4 TDIs (VE and PD) 3 October 4th, 2004 11:29
TDI oil pressure at the cylinder head Brent Waldron TDI Power Enhancements 23 November 13th, 2000 10:51
Oil Pressure gauge, '98 TDI GregR VW MKIV-A4 TDIs (VE and PD) 6 November 6th, 2000 06:32
Page generated in 0.15982 seconds with 10 queries
[Output: 127.09 Kb. compressed to 106.24 Kb. by saving 20.85 Kb. (16.41%)]
