Old August 4th, 2011, 19:23   #1
Frederick King
TDI(s): 03 golf tdi
Fuel Economy: 44 avg
Default snow screen
What is everybodys opinion of what to do with the snow screen in alh platforms. I just traded my 02 auto jetta with 173k in for a 03 golf 5 speed with 149k. In my old 02 I cut the screen out and got smoother pick up thru the rpm range. Tonight I changed the fuel filter and the air filter in the 03 golf. I noticed someone had drilled 2 5/8 holes in the air box. It had some nasty looking grit in it and the filter was dirty. I checked the snow screen and it looked like it had never been touched. I took a knife to it. The engine felt like it fell on its face at about 3200 rpm before I serviced it. After it was a hole lot quicker. I think I will tape up the big holes in tthe air box to help to keep it cleaner.
Frederick King is offline   Reply With Quote
Old August 4th, 2011, 20:15   #2
jcrews
jcrews's Avatar
TDI(s): 2003 Golf
The snow screen does contribute to vacuum formation in the induction system, which can increase control valve (n18, n75) release times under full load.
I prefer to remove this screen, and use the cold weather filter (add an A at the end of the filter element part #). 2004 and newer air filter boxes drop the screen entirely for the cold weather filter and a slightly different filter box that has an internal partition.
jcrews is offline   Reply With Quote
Old August 5th, 2011, 17:11   #3
Frederick King
TDI(s): 03 golf tdi
thanks for info
Old August 5th, 2011, 18:39   #4
boertje
boertje's Avatar
I concur with jcrews.
'01 and a 2nd '01 and a '03 NB TDI with 6 spd manual. '06 NB GLS TDI DSG.
All with Malone tuning of course.
Auto to 5/6 spd manual swap with wiring instructions for MKIV. Click here.
boertje is offline   Reply With Quote
Old August 6th, 2011, 06:25   #5
RamMan4x4
RamMan4x4's Avatar
Fuel Economy: 45-55
I just clean it when I change the screen every 20k miles when I change the air filter. It's not too much work, but its partially blocked with sand and grit every time so it may not be worth the hassle.
+1 on the cold weather filter
03 VW Jetta TDI - Silver, PP520, RC3, DG Racepipe, Ventectomy, Old Navy CCV, Koni STR.T, 1" Koni Coils, 4pt lift pads
Useful Links: Vac/Fuel Hose Vac Diagram Limp-Mode Timing Adj Low Power 5th Gear
RamMan4x4 is offline   Reply With Quote
Old August 6th, 2011, 08:57   #6
PDJetta
PDJetta's Avatar
"2004 and newer air filter boxes drop the screen entirely for the cold weather filter and a slightly different filter box that has an internal partition."
That's what I thought until two years after buying my 2004 PD Jetta I took a look and it HAD a snow screen in the intake snorkel. It was completely plugged too. I cut it out. The car also came from the factory with the cold weather air filter and the wording on the air filter box to replace the air filter with the "A" suffix, cold weather filter. I assume my air filter box is correct for a 2004 MY BEW engine.
The car was manufactured in October 2003. Its a very early 2004 (PD) model. I suspect that my car had a 2003 ALH engine left-over snorkel (with snow screen) installed.
--Nate
Snow screen vs. snorkel screen? spkerer VW MKIV-A4 TDIs (VE and PD) 10 August 13th, 2003 09:53
Snow Screen or Sunflower Seed Screen ??? Doodledog VW MKIV-A4 TDIs (VE and PD) 1 June 9th, 2002 10:47
Removed two MAF screen , but I can not find the snow screen arktiaxs VW MKIV-A4 TDIs (VE and PD) 5 April 3rd, 2001 10:51
Report- Snow with no Snow Screen- car54 VW MKIV-A4 TDIs (VE and PD) 2 March 16th, 2001 00:53
"snow screen" "pre-screen" air filter update GeWilli VW MKIV-A4 TDIs (VE and PD) 8 August 10th, 2000 06:23
Page generated in 0.12628 seconds with 10 queries
[Output: 75.08 Kb. compressed to 65.81 Kb. by saving 9.27 Kb. (12.34%)]
