| TDI Power Enhancements Discussions about increasing the power of your TDI engine. i.e. chips, injectors, powerboxes, clutches, etc. Handling, suspensions, wheels, type discussion should be put into the "Upgrades (non TDI Engine related)" forum. Non TDI vehicle related postings will be moved or removed. Please note the Performance Disclaimer. |
August 2nd, 2011, 12:59
#1
Larger Turbo for 1.9TDI BLS engine
Is there a standard OEM turbo that I could swap out with the BLS version that I can use to increase power. Of course I would need different map etc, but is there a direct replacement or would I need to have one hybrided
August 4th, 2011, 01:22
#2
You can fit any turbo from a Mk4 golf if you also use the downpipe, a PD150 one will be the best choice for direct bolt on.
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
August 5th, 2011, 23:55
#3
I am not sure if the BLS engine has the turbo mounted upside down compared to typical PD TDI engines though. I think I have seen this on a VW Caddy 105HP PD TDI....
Mercedes Benz W210 E-Class 320CDI, lowered 2.5", 18" AMG wheels, Decat, GT2566XTV, AMG injectors, 400kpa MAP, MAF delete, EGR delete, tumble flaps delete....SW tweaked to 300+hp/800Nm
www.facebook.com/ZturboZwettl
August 8th, 2011, 03:14
#4
only the 140hp BMM caddy had DPF and top mounted turbo IIRC!!
August 8th, 2011, 15:12
#5
Yes the turbo is mounted upside down on my caddy! Top mount so to speak! No DBF mind! Its a 104bhp. Is there not a replacement. If I change to PD150, I would need different downpipe, intake is on the other side, boost out goes down over gearbox not down around by crank pulley,
August 10th, 2011, 10:58
#6
Nope, I took a look in our Caddy 1.9PD TDI with engine code BLS today, its upside down, well actually its only upside, without down
And yes, intake is on the other side, turbine outlet on the passengers side (Who would have thought that d'oh  )
So swapping over to a pd 150 turbo would need some more work.
Also the injectors are quite small on this engine, so a turbo upgrade is only half the rent....
Regards, Alex
