Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old July 30th, 2011, 22:34   #1
cat bandit
TDI(s): 2011 jetta
Fuel Economy: the best ive seen is 46
Default fuel filter change on 2011 jetta
I'm coming up on my 20000 mile maintenance, and I'm wondering how you prime the fuel filter. I don't really have time to take the car to the dealer because of work, and I'm worried about changing it, and not being able to bleed the air out. Any thoughts? Thanks
cat bandit is offline   Reply With Quote
Old July 30th, 2011, 22:45   #2
JSWTDI09
JSWTDI09's Avatar
The only good way to prime (fill) the fuel system after opening it up is to use the dealer's scan tool or VCDS. Turning the key off and on does not do it properly. There are three fuel pumps you have to turn on at the same time. This is easy with VCDS, but very difficult without it. If you do not have VCDS, you will have to find someone nearby who does and have them do it before you try to start the engine. The procedure is not difficult and it takes less than 5 minutes, but there is no other way to do it.
Have Fun!
Don
JSWTDI09 is online now   Reply With Quote
Old July 31st, 2011, 08:27   #3
cat bandit
TDI(s): 2011 jetta
That's what I was afraid of... where can I get a scan tool, and what do they cost?
Old July 31st, 2011, 10:35   #4
JSWTDI09
JSWTDI09's Avatar
Ross-Tech makes the only full featured scan tool that will do what you want. The MicroCAN cable is your cheapest option that will work on your car. http://store.ross-tech.com/shop/cat/VCDS.html
This cable only works on 2005.5+ VWs. The cost is $249 and for an extra $100 you can get a HEX+CAN version that will work with almost any VW. The way this product works is you buy the interface cable. The cable includes a "dongle" which unlocks the full capability of the program. The actual program can be downloaded for free, so once you own the cable, you can upgrade the software for free every time the software is updated. If you plan on keeping your VW for a while, this is probably the best investment you could make. It will pay for itself in time, in more than one way.
Have Fun!
Don
Old July 31st, 2011, 10:41   #5
cat bandit
TDI(s): 2011 jetta
I did a search, and was looking at the Ross tech system, and I'll be buying one soon. Have you heard of any problems with them?
Old July 31st, 2011, 10:54   #6
JSWTDI09
JSWTDI09's Avatar
No, not one. Their after the sale support is second to none. I have asked questions and received email replies from the owner of the company on a Sunday afternoon. There are very few companies you can say that about. The software is excellent, beta versions of the latest version are often available and any "bugs" are fixed before the final version is released. This is one of the most thoroughly tested and best supported pieces of software I have ever seen. There is a slight "learning curve" figuring out how to best use it, but there are also on-line manuals and support forums available. Highly recommended.
Have Fun!
Don
Old July 31st, 2011, 11:02   #7
cat bandit
TDI(s): 2011 jetta
Ok, perfect. You really can't say that about many companies for sure! Now, should I go with the hex can? Or the k2 one? Their chart said both will work I think, but its confusing.
Old July 31st, 2011, 11:19   #8
JSWTDI09
JSWTDI09's Avatar
If all you care to work on is your own car - the MicroCAN will work fine. I bought the HEX+CAN model because I have friends with older VWs. Ross-Tech has models that only work with older cars (KII-USB) and they have models that only work with newer cars (microCAN) for $249. The $349 models (HEX+CAN) will work on both new and old VWs. Therefore, it really depends on whether or not it is worth an extra $100 to be able to help owners of pre-2006 Volkswagens (and Audis). All these interface cables are "full versions" and they will all do the same things. The only difference is which year cars they will work with.
You do not want the K2 one - it is for 2005.5 and earlier cars. It will not work with your 2011 model. For your car you want either the MicroCAN or one of the HEX+CAN ones.
Have Fun!
Don
Old July 31st, 2011, 11:26   #9
cat bandit
TDI(s): 2011 jetta
Ok, thanks a lot! The chart on the Ross website is a little confusing, so I'm glad to talk to someone with some experience!
Old July 31st, 2011, 14:26   #10
mo_focus
mo_focus's Avatar
TDI(s): 84 944
i replaced my fuel filter at 30kms and it was very simpell, there was no need to VCDS either. I have the kessy's as well.
Just cycled on/off about 5 times and started right up.
1984 Porsche 944- New Toy
2009 Acura RDX Turbo
mo_focus is offline   Reply With Quote
Old July 31st, 2011, 15:14   #11
deucelee
Fuel Economy: 45mpg @ 80% highway
interesting...has anyone else tried this?
where did you hear about doing it this way? thx
deucelee is offline   Reply With Quote
Old July 31st, 2011, 15:37   #12
mo_focus
mo_focus's Avatar
TDI(s): 84 944
mmmmm, i guess i was wrong. I have to talk to my mechanic. I dont think he did the VCDS method, in the link provded it says to use it. will have a talk with him next week when the golf is going in for oil change.
http://www.myturbodiesel.com/1000q/a...uel-filter.htm
Old July 31st, 2011, 17:30   #13
Highline Driver
Fuel Economy: Good=Better than Durango with HEMI
Just curious, why did you change your fuel filter after driving only 30 kms?
Highline Driver is offline   Reply With Quote
Old July 31st, 2011, 18:17   #14
JSWTDI09
JSWTDI09's Avatar
Read FAQ #24 in this post (and follow the link): http://forums.tdiclub.com/showpost.p...28&postcount=1
This FAQ says it is for 2009 -2010 cars, but the engine is the same in a 2011, so it applies equally to 2011 (and probably 2012) cars
My service manual says that any time the fuel system is opened, you should properly "fill" the system before starting. It might work without doing this, but I prefer to follow instructions to minimize damage.
Have Fun!
Don
Old July 31st, 2011, 19:28   #15
BarrieCommuter
he meant 30k kms
2015 Jetta TDI Highline 6MT, Stormtrooper
Barrie, Ontario, Canada
BarrieCommuter is offline   Reply With Quote
Fuel filter change?? 2009 Jetta TDI Chadmag VW MKV-A5 Golf/Jettas 9 February 4th, 2016 19:10
fuel filter change on 2006.5 jetta tdi msrtdi TDI 101 2 May 12th, 2008 20:10
2005.5 Jetta TDI, how to change the fuel filter??? Cherie TDI 101 8 October 23rd, 2005 15:58
Fuel Filter Change '03 Jetta GearJammer VW MKIV-A4 TDIs (VE and PD) 4 August 13th, 2004 07:27
2000 jetta tdi fuel filter change **DONOTDELETE** VW MKIV-A4 TDIs (VE and PD) 4 August 29th, 2001 18:46
Page generated in 0.17721 seconds with 10 queries
[Output: 129.88 Kb. compressed to 108.64 Kb. by saving 21.24 Kb. (16.35%)]
