Go Back   TDIClub Forums > Classifieds/For Sale/Wanted > Private TDI Items for Sale/Wanted
Private TDI Items for Sale/Wanted VW TDI/Diesel related items for wanted and for sale by private individuals. Group Buys and commercial posts should be in the "Vendor & GroupBuy" section.
Old July 25th, 2011, 20:07   #1
Kevin_McC
Fuel Economy: 49
Default ALH Engine for Sale - 178K Miles
This engine came out of a 2002 Jetta that was in a front end collision. The engine was running fine before the accident. The oil pan has a rubber patch on it but it was not leaking when I had the car in the garage. I did drain the oil and it was a normal amount that came out. I expect anyone that buys this will probably want to replace the oil pan. I originally wanted $1500 but given that the oil pan is bad, I am willing to sell for $1150. I will not ship - pickup only in Pinckney, Michigan 48169. Parts not included: Turbo/exhaust, intake, IP, oil filter housing, injectors, glow plugs. Please view pictures for what is still on engine here http://www.bluemelon.com/kmcclaff/alhengineforsale. Two injectors could not be removed and are still in engine. I am done messing with those and it is being sold as-is.
K. McClafferty
Pinckney, Michigan
2003 Jetta GLS TDI
Kevin_McC is offline   Reply With Quote
Old July 31st, 2011, 17:10   #2
bassmastrbw96
TDI(s): none yet
If I have a shipper pick it up would you do that
bassmastrbw96 is offline   Reply With Quote
Old October 8th, 2011, 14:08   #3
snobum13
snobum13's Avatar
Fuel Economy: 44.3
Is this engine still available?
snobum13 is offline   Reply With Quote
Old October 8th, 2011, 17:28   #4
AndyBees
AndyBees's Avatar
Did you set the engine timing on TDC before removing the IP? Can you assure (warranty) that the crankshaft has not been rotated since the IP was removed?
Do you have a photo of the other side of the engine? Without a Turbo/Intake, it is pretty easy to imagine what the back side looks like!
'84 Vanagon '02 ALH TDI engine(32 to 35+ MPGs consistently) Malone Stage 1 tune. Road trip to Nova Scotia 2013. Road trip to Alaska summer 2014 & 2016, 11k & 12k miles. 80k miles on install, Jetta Cluster odometer currently at 209k miles.
Old December 5th, 2011, 10:43   #5
Kevin_McC
Fuel Economy: 49
Engine still for sale
K. McClafferty
Pinckney, Michigan
2003 Jetta GLS TDI
feeler: 1.9 ALH Engine 194k miles rhinotalon Private TDI Items for Sale/Wanted 0 July 24th, 2011 08:53
ALH 10mm pump 140k miles for sale kooyajerms Private TDI Items for Sale/Wanted 8 December 15th, 2010 14:29
2003 Golf 4-Door GL, 178k miles (in Maine) brotha bran TDI Cars for Sale/Wanted 23 July 9th, 2010 04:06
FS: ALH engine for sale - low miles. rjr311 Private TDI Items for Sale/Wanted 10 August 6th, 2008 01:38
CV's, coolant, etc: 1996 passat 178K miles 96passatowner VW MKIII-A3/B4 TDIs 4 April 16th, 2006 15:07
Page generated in 0.12903 seconds with 10 queries
[Output: 67.45 Kb. compressed to 59.54 Kb. by saving 7.91 Kb. (11.73%)]
