Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Mountain/Southwest States
Mountain/Southwest States Local discussions for those Idaho, Montana, Wyoming, Colorado, Nevada, Utah, Arizona, & New Mexico
Old July 24th, 2011, 00:31   #1
xTheChadx
TDI(s): 81 Dasher
Default Denver Emissions Testing...
Hello i am moving to Denver this sept, luckly my tags will be good untill Aug of 2012, but after that im worried about passing emissons with my TDI.. anyone from denver and had any problems? im lucky and KS has no emissions at all
81 Dasher mTDi
xTheChadx is offline   Reply With Quote
Old July 24th, 2011, 12:12   #2
TDI Stevestr
Default Colorado Diesel Emissions Testing
Honestly the "clean air" folks don't go into very much specifics for Diesels.
Also, just a heads up, you're supposed to get your license and tags within 90 days of becoming a "permanent" resident. I suppose if no one complains and you don't get stopped until Aug '12 you will be OK in that department.
Denver is in the "enhanced" inspection area.
Update: According to the Air Care site you have 15 days in which to register the vehicle and get the emissions test done. See http://aircarecolorado.com/consumer-...new-residents/
Originally Posted by http://www.cdphe.state.co.us/ap/mobile.html#Diesel Emissions Control Program
Small fleets and privately-owned diesel vehicles take part in the Diesel Opacity Inspection Program. This program is for all light-duty diesel vehicles as well as heavy-duty diesel vehicles not subject to the large fleet self-certification program. The Diesel Opacity Inspection Program requires that eligible vehicles be inspected on an annual basis by private, state-licensed diesel inspection stations. New light-duty diesel vehicles are exempt from testing for four years. The program applies only to the Automobile Inspection and Readjustment Program area and utilizes a loaded mode dynamometer-based test.
From the use of "opacity" sounds like they are just gunning it and seeing what color the smoke is out the back.
The inspection is not cheap, since it is run like California and some other states, in which the inspections for Diesels are not covered by the state emissions test centers. You have to go to an approved shop and pay whatever they want to charge for the test.
Here's a list of the shops:
http://aircarecolorado.com/locations...-test-centers/
Here's a list of the shops with the pricing that is updated frequently:
http://www.cdphe.state.co.us/ap/down...ationrates.pdf
Hope that helps somewhat.
5K149M 2011 Golf 4-DR 2.0L TDI Auto Exterior: A1A1 - Black / Interior: KA - Titan Black
Options: 9VE Dynaudio; 9W7 Bluetooth; GTM Rubber Mats and Chrome Exhaust (Port); P71 Navigation (310); P83 Xenon Headlamps; W79 Cold Weather Package
Mechatronics: 1 / Transmissions: 1 (14,200 Mi) ** VCDS/VAGCom Available **
TDI Stevestr is offline   Reply With Quote
Old July 26th, 2011, 22:29   #3
xTheChadx
TDI(s): 81 Dasher
yeah that does, thanks alot, just wondering if anyone has had any problems with mods on there car...
81 Dasher mTDi
Old August 1st, 2011, 10:25   #4
Behemecoatyl
Banned
Denver tests ONLY for opacity. There is no inspection. Unless your engine smokes like a steam engine then you will have no trouble passing. Diesels Only on Alameda is the cheapest and the least likely to fail somebody for modifications.
Behemecoatyl is offline   Reply With Quote
Old August 2nd, 2011, 00:14   #5
DrFaustus
DrFaustus's Avatar
Fuel Economy: ~40 MPG
I've used Diesel Testing Center on Havana. I had enough mods that I WAS smoking like a freight train. They worked with me while I got the emissions under control without any hassles at all.
Dr. Faustus
2006 Jetta TDI - PD140, SBC Endurance, Tuned
1970 Triumph Spitfire - Alternator conversion, Camber compensator, Dual SUs, Overdive, Custom dash
DrFaustus is offline   Reply With Quote
Old August 3rd, 2011, 11:43   #6
Conan
Conan's Avatar
TDI(s): 2003 GLS TDI
Fuel Economy: 32-48
In a bone stock '03 Jetta TDI that wasn't smoking visibly at all, I failed TWICE! (At fifty bucks a pop.) Opacity testing here is a complete joke. After my second failure, a guy with a similar car passed the test, smoking like a freight train. It's a racket. There is, however, a solution. PM sent.
Conan is offline   Reply With Quote
Old August 5th, 2011, 00:46   #7
milehighassassin
milehighassassin's Avatar
Fuel Economy: 43
Register the car on the Western slope!
http://www.hardeysmotorwerks.com/
http://www.20vturbo.com (R.I.P)
2005 Golf TDI PD, FM100, Frostheater, Hidden Hitch,
Clear-bra, Tint, VR6/G60 Clutch Combo, EuroJet SMIC, Custom Lower intercooler Pipe, VNT-17, Panzer Plate
Custom 3" turbo-back exhaust
milehighassassin is offline   Reply With Quote
Old August 5th, 2011, 06:38   #8
Conan
Conan's Avatar
Fuel Economy: 32-48
I think that is getting harder to do. I don't remember the exact details, but I think the address on your driver's license, registration, and other DMV records have to match. Too many people were playing that game.
Old August 9th, 2011, 20:26   #9
milehighassassin
Fuel Economy: 43
They don't have to match, I've done it. Just tell them it is your 2nd address. Usually the county you try and register in, does not want to lose out on the tax revenue so they don't even question it. Many communities on the Western slope do not have house postal delivery meaning you need a PO BOX. So you put down a physical address and also a mailing address.
Old August 12th, 2011, 11:52   #10
sdeck
sdeck's Avatar
Won't work. Diesel emissions are state-wide. opacity limit is 35%. They put it on a dyno and gun the crap out of it (sometimes literally). Anderson Foreign Auto on West Colfax has been good working with me.
"If you make it idiot proof, nature will build a better idiot"
Considering WVO? see these:
http://forums.tdiclub.com/showthread.php?t=213288
http://forums.tdiclub.com/showthread.php?t=249556
sdeck is offline   Reply With Quote
Old August 13th, 2011, 08:27   #11
Auslndr
I do not believe the testing is statewide. I live in Teller County and we are exempt (for now). According to the Colorado Department of Revenue, "The full counties of Boulder, Jefferson, Broomfield, Denver, and Douglas, and the partial counties of Adams and Arapahoe, Larimer, Weld, and El Paso" have required emission testing.
http://www.colorado.gov/cs/Satellite.../1186648384011
Now, I will say this. I've purchased a Golf TDI from the Denver area and a Ford F250 from south of Parker, and both titles indicated they were "gas" engines. I suspect the previous owner(s) somehow had the title changed so they could bypass emission testing. I don't know how, but I found it suspicious nonetheless.
2012 Golf TDI 6M Tech Package, Euro mirrors, Rear fog light, Tyrol Deadset Kit 2009 Golf Sportwagen TDI 6M, Euro mirrors, Golf ball shifter, Rear fog light
2009 Pontiac G8 GXP, #1560 of 1829 SRM 6M Onyx no sunroof 2000 Ford F-250 7.3L Diesel,Automatic
Auslndr is offline   Reply With Quote
Old August 15th, 2011, 13:23   #12
sdeck
sdeck's Avatar
You are correct. I am in Larimer and we got rid of mandatory testing a few years ago EXCEPT for diesels. I was told diesels were statewide. Of course mandatory testing of gas engines is back now in the northern front range because revenues are down.
Old August 15th, 2011, 14:39   #13
UFO
UFO's Avatar
TDI(s): 2001 Beetle
Fuel Economy: 50mpg on B100
Progressive Diesel in Englewood is pretty good, and is less than $60 for the test. Never had any issues passing the opacity.
2001 Beetle - EGR delete, 01M-ectomy, Atlas skidplate, vented, Frostheater.
I'm not coasting, I'm shifting slowly.
UFO is online now   Reply With Quote
Old August 16th, 2011, 12:40   #14
TDI Stevestr
I live in Adams and I think the DMV is just used to registering gas vehicles. My first copy said Gas and I had it changed to diesel. Gas cost slightly more to register here and I have a feeling it may cause trouble with Air Car Colorado later on down the road that will be a bigger headache. But judging the number of smoking diesels I have come across around here the testing requirements must only be for certain areas of Colorado as you said.
Old August 16th, 2011, 12:42   #15
TDI Stevestr
Pretty good find there. Thanks for the link. The testing schedule for gas vs diesel is about the same for new vehicles - exempt for 4 then every 2. The only thing is that diesels are not tested via the mobile stations parked along the freeway entrance ramps so there is no chance to pass there and skip a test.
Emission Testing places in Denver/Boulder linklemming Mountain/Southwest States 1 January 12th, 2010 23:56
Denver Emissions Test and Dyno? cartog Mountain/Southwest States 4 February 17th, 2006 21:58
KY emissions testing? MIA TDI 101 3 September 22nd, 2003 10:40
TEXAS and Emissions Testing??? Stealth TDI TDI (Diesel) Emissions 17 June 18th, 2002 23:49
Emissions Testing Bernie VW MKIV-A4 TDIs (VE and PD) 9 June 27th, 2000 00:18
Page generated in 0.19758 seconds with 10 queries
[Output: 136.83 Kb. compressed to 115.01 Kb. by saving 21.82 Kb. (15.95%)]
