Old July 22nd, 2011, 14:24   #1
Fuel Economy: 42
Default Weeping EGR
I just looked at my car today and my EGR has a small oil leak.
I have a 2004 Jetta TDI. It's not leaking profusivley, or enough for me to notice that the oil is missing whenever I check the dipstick.
Is there anything I can do to stop the EGR from leaking? I was thinking about cleaning up the intake hoses and just doing a complete all around inspection to see if that helps with anything.
Could buying a new EGR help my cause at all? I've read that it's normal for these kinds of cars to leak oil at the EGR, but I'm a worrywart and would like some help and advice.
Sarahvici0us is offline   Reply With Quote
Old July 22nd, 2011, 14:36   #2
Fuel Economy: 42
Oh yeah, my car is at 145k miles.
Old July 22nd, 2011, 17:31   #3
jettawreck's Avatar
My '01 EGR weeps some. I put a clean small rag under it and change to a new one when its oil change time. I don't worry about it, but a new one would fix it.
2004 Cadillac SLS (wife's)
Old July 22nd, 2011, 20:02   #4
Keith_J's Avatar
Fuel Economy: 38 MPG @ 80 MPH with 2 bikes on top. 52 MPG @ 60 MPH slick
Yes, cleaning the intake and intercooler will help. As will removing the EGR valve and cleaning it too.
Make sure the crankcase pressure isn't high, the ALH engines have an oil control baffle in the valve cover, I don't think yours can be taken apart to be cleaned. Make sure you don't have any vacuum leaks, these will raise crankcase pressure since the vacuum pump discharges air into the valve cover area, increasing the rate of flow of air through the crankcase ventilation system.
You could insert a small brass tube into the vent hole that is weeping oil, venting it to a small catch container. Remember, it needs to be open to atmospheric pressure since that is what pushes the EGR open. Plug it and the EGR will not function.
2k Jetta manual. PP520s. Ventectomy, Panzer Plate, DT hitch, 16"s w/ 205 55s. Short shifter. Boost gauge with blue LED backlight, same intensity as dash. Blistein struts and shocks. 0.658:1 5th gear swap and LOVING IT.
Keith_J is offline   Reply With Quote
Old July 23rd, 2011, 10:45   #5
PDJetta's Avatar
The EGR is completely different on the PDs, as opposed to the ALH engined TDIs. Its electrical on the '04 and there is no diaphragm or weep hole. I suppose it could be leaking from the o-ring that seals it to the intake manifold.
One thing that really leaks oil on the BEW is the joint between the throttle housing and the rubber boost elbow (this is normal from the mist in the intake charge from blowby and turbo seals). The throttle housing sits to the left of the EGR valve (when looking at it, standing in front of the car). Replacing its O-ring can help a lot. And installing this will prevent future leaks and also keep the joint from pulling apart:
Simple Weeping EGR Question RndmGuy06 TDI 101 12 June 29th, 2011 03:04
WTB: non-weeping ALH EGR Eudaemonic Private TDI Items for Sale/Wanted 8 May 24th, 2010 07:07
EGR Valve Oil Weeping with CCV Filter Mod - Where is the oil coming from? N_J TDI 101 8 May 10th, 2007 11:48
Fix for weeping EGR valve MOGolf VW MKIV-A4 TDIs (VE and PD) 23 February 21st, 2007 16:23
Fix for weeping EGR valve MOGolf VW MKIII-A3/B4 TDIs 21 February 9th, 2006 05:43
Page generated in 0.14771 seconds with 10 queries
[Output: 69.95 Kb. compressed to 61.98 Kb. by saving 7.97 Kb. (11.40%)]
