Old July 22nd, 2011, 09:32   #1
Westro
Fuel Economy: 48.3 MPG lifetime
Default Need rear control arm bushing how to
At one point there was a "how to" on the rear control arm bushing replacement. About dropping the trailing arm and replacing the two bushings. Also are there "TT" bushings out there that are stiffer?
2002 Black Jetta TDI manual GL, 308K SOLD
2002 Black Jetta TDI manual GLS, 330K SOLD
2002 Blue Jetta TDI GLS, Auto SOLD
2003 Silver Jetta TDI manual GLS, 125K and a Whole Pile of other Diesels
Westro is offline   Reply With Quote
Old July 22nd, 2011, 10:24   #2
mk3
mk3's Avatar
Fuel Economy: 46.4 lifetime
This is what I had 'bookmarked' for this job. I just got new bushings this week and hope to put them in very soon. For tools I was thinking of starting with my harbor freight front wheel bearing kit and see what I can accomplish.
http://forums.tdiclub.com/showthread.php?t=254483
The above link takes you to a thread about tools but I think within it there is a link to or a list of instructions.
03 Jetta TDI 5-spd (297k mi) PP520 Nozzles, IQ 5.8 Plastic impeller-OEM Waterpump : O
13 Prius 105k mi
16 Civic 1.5L turbo (20k mi) ~ 37 mpg
mk3 is offline   Reply With Quote
Old July 22nd, 2011, 13:46   #3
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
Um, mk3 I think your thread is more on the rear axle bushings not the rear control arm bushings.
What we did was we had a 3/4 drive socket that fit the hole just right and we pressed the old bushing out in a press. You could get a pipe close to the outer diameter of the bushing and brace it up in a vise and it would likely work as well. Or you could cut the rubber out and then cut the metal out being sure to cut toward the most metal as you will have to cut into the outer cage some since it is rounded.
Install. I put in the vise and just rotated around a little bit at a time on the outsides. If it gets kinks a little you just do the side sticking out the most and even it back up. Really easy-did 4 this way.
If you are doing the rear axle bushing then using Dave-bugs tool is GREAT. Only way to go. You cut the rubber out again and then cut what is likely going to be plastic cage out (some were metal). Then use his tool. Well worth the money as the bushing is well oversized and needs to be aligned just right and forced just right or it won't go in. I didn't have to take the break likes nor the brackets off to get to them but it was a lot of tension on the brake lines to do this. Better just taking the brake lines off but then you need Vag Com to bleed the air from the ABS brake system.
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car 1.9aaz, 5 spd, 1981 Caddy VW truck diesel, 2004 Golf-2 inch lift, -fixing, 2005 Golf-2 inch lift - totaled twice and fixed twice, 2005 Jetta Wagon - 2 inch lift
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old July 22nd, 2011, 19:57   #4
Westro
So has anyone tried an upgraded (stiffer) bushing set like this one?http://shopping.boraparts.com/product_info.php?cPath=21_26_40_66&products_id=310
Old July 23rd, 2011, 05:21   #5
mk3
mk3's Avatar
Originally Posted by coalminer16 View Post
Um, mk3 I think your thread is more on the rear axle bushings not the rear control arm bushings. .
doh! Sorry. I guess I assumed the term 'control arm' had been loosely substituted for axle. So, we're talking about the rear-most bushings of the front control arm?
I'm doing that this weekend but I purchased a completed set of front control arms with bushings and other associated parts from blauparts to avoid the mess. I've replaced bushings in this type of control arm before. What I recall is cutting out the rubber somehow, then hacksaw or similar to remove the sleeve. I pressed the bushing in with a hydraulic press at work.
yes, the TT bushings I have seen do not have the voids in them and therefore would be stiffer.
13 Prius 105k mi
Old July 23rd, 2011, 05:56   #6
FlyTDI Guy
FlyTDI Guy's Avatar
Fuel Economy: 56.5/44/41
http://forums.tdiclub.com/showthread.php?t=154137
'01 Jetta GLS, 5 sp, Black on Black, Leather, Sun Roof, MFSW, Monsoon, Cold Weather Pkg., Full LED interior, always a work in progress
FlyTDI Guy is offline   Reply With Quote
Old July 23rd, 2011, 06:14   #7
Westro
yes I am working on the rear AXLE. So to use VW stock or aftermarket bushings?
Old July 23rd, 2011, 06:32   #8
FlyTDI Guy
FlyTDI Guy's Avatar
Oops, not enough coffee yet... Yep REAR I thought there was a how-to for that also. If not here, check out HERE
Old July 23rd, 2011, 08:58   #9
mk3
mk3's Avatar
One site that I checked listed the same part for Audi TT and VW Jetta for the bushing of the rear axle. Germanautoparts has the same price to the penny for both items. That doesn't totally prove they are the same, however. You would need to check ETKA to be more certain.
13 Prius 105k mi
control arm bushing?? rshelton TDI 101 6 February 25th, 2013 17:26
Rear control arm bushing shot after 12k miles?? Chris B VW MKIV-A4 TDIs (VE and PD) 16 February 6th, 2011 13:47
TT control arm rear bushing discontinued? Jeff Heyerman VW MKIV-A4 TDIs (VE and PD) 2 April 23rd, 2010 16:47
control arm bushing SEABEECM1 TDI 101 7 December 4th, 2009 13:11
Rear wheel bearing?? Rear control arm bushing?? craig01b Ontario 15 July 18th, 2008 15:36
Page generated in 0.14462 seconds with 10 queries
[Output: 95.15 Kb. compressed to 81.54 Kb. by saving 13.61 Kb. (14.30%)]
