Old July 21st, 2011, 18:12   #1
Rain-Man-018
Default Cold air intake 2006 TDI
Want to get an AFE intake for my 2006 TDI but im pretty sure they dont make one, anyone have any recommendations
Rain-Man-018 is offline   Reply With Quote
Old July 21st, 2011, 18:14   #2
20IndigoBlue02
20IndigoBlue02's Avatar
the stock intake is a CAI.
2016 Tiguan SE 4Motion
20IndigoBlue02 is offline   Reply With Quote
Old July 21st, 2011, 18:16   #3
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
AEM makes one, Carbonio too I think. Just know you are paying for the sound, there's little to no performance benefit with an otherwise stock setup.
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old July 22nd, 2011, 09:19   #4
85_305
Banned
I would NOT drop money on a cai. They dont do anything on these cars. If you want more turbo noise and vnt blow off, install an open air intake and call it a day. Put the remaining $3xx into new injectors.
85_305 is offline   Reply With Quote
Old July 22nd, 2011, 09:21   #5
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
For his model-year (engine type) a tune would be first, then turbo/IC/exhaust, then injectors/nozzles.
Old July 22nd, 2011, 09:32   #6
85_305
Banned
Oh ya I wasn't paying attention to the year. Supposedly those stock injectors are pretty decent. Do what Bob said.
Old July 22nd, 2011, 09:58   #7
n1das
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Exclamation
Rain-Man-018,
Welcome to TDIclub!
What don't you like about the well designed ram-air CAI the car already came with from the FACTORY?
David Sterrett, N1DAS
2014 BMW (F10) 535d XDRIVE M-Sport, 255hp & 413 lb-ft of AWD stomp 'n go fun!
2012 BMW (E70) X5 XDRIVE35d, 265hp & 425 lb-ft of AWD stomp 'n go fun!
Member SSBMWO
Why DIESEL is better:
http://webpages.charter.net/lmarz/emissions.html
http://webpages.charter.net/lmarz/efficiency.html
http://webpages.charter.net/lmarz/performance.html
http://webpages.charter.net/lmarz/emissions2014.html
http://webpages.charter.net/lmarz/emissions2016.html
n1das is offline   Reply With Quote
Old July 30th, 2011, 16:56   #8
Rain-Man-018
Have exhaust and stage 2 running 18 pounds boost with increased fuel intake would be good and afe doesnt make one for my year
Old July 30th, 2011, 17:14   #9
PeterV
HO5G Doyen & Zen Master
PeterV's Avatar
CAI will not give ytou any bang for your dollar SPEND your hartd earned cash on You will get MORE for your dollar with Injectors and or tune.
PeterV 'BUG*pwr award 2005'
'00 Jetta TDI, RC, Shine, DG RPipe, 520PP, DG/SS LED Boost ASR. Home of HO5G ('96 Cummins CTD 3/4 ton now at 274 HP 670 ft Lbs TQ riprust) Ram 1500 hemi
Trusted TDI Mechanics Map || VCDS Locator ||
PeterV is offline   Reply With Quote
Old July 30th, 2011, 18:20   #10
Rain-Man-018
Stock cai is to restrictive diesels need air the more the air the better
Old July 30th, 2011, 18:25   #11
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
You have the stock turbo running [only] 18 PSI, you won't see any gains. LIMFAC isn't the airbox in that situation.
*Maybe* with a bigger turbo and 24 or more PSI there'd be some gains.
Old July 30th, 2011, 21:23   #12
n1das
n1das's Avatar
Exclamation
Stock CAI is too restrictive? OK, based on what? How do you know it's restrictive in a TDI application?
The stock airbox and OEM paper filter setup is already way over-sized by design to way outflow the engine. It is similar in size to what full size diesel pickup trucks use. It was purposely designed this way to not be restrictive while providing the necessary filtering and have a 40k mile change interval. IOW, your TDI engine is incapable of outflowing the stock airbox and filter setup, no matter how hard you try!
I agree diesels need air and the more air the better. However your TDI engine is already getting way more air than it needs.
If you believe an aftermarket CAI will add power over the stock setup, please post results from back to back dyno runs made before and after swapping the airbox setup and the swap is the only change made between dyno runs made on the same day on the same dyno.
Good luck.
Member SSBMWO
Old August 2nd, 2011, 06:44   #13
LNXGUY
LNXGUY's Avatar
You should probably listen to what everyone is telling you. The stock CAI is probably good to over 200WHP, which you aren't even close to making...
Bill
LNXGUY is offline   Reply With Quote
Old August 2nd, 2011, 06:56   #14
penclnck
http://www.youtube.com/watch?v=725gxEJkpXs
Pencilneck blah blah blah
penclnck is offline   Reply With Quote
Old August 7th, 2011, 07:46   #15
MkVer
Fuel Economy: Low/Mid 40's @ 7000ft MSL
+1 n1das
2005.5 Jetta. BRM. Panzer plate, Frostheater, Upsolute chip tune, Mufflerectomy, Colt II Cam, Lower Grille Block.
MkVer is offline   Reply With Quote
09 Jetta tdi Cold air Intake Krzysiuu VW MKV-A5 Golf/Jettas 17 October 8th, 2013 07:48
APR Carbonio Cold Air Intake for 2.0 TDI Reflex TDI TDI 101 6 November 28th, 2011 06:39
Golf 2.0 tdi cold air intake & exhaust? Adonis TDI Power Enhancements 4 May 31st, 2009 23:41
2005/ 6 Jetta TDI K & N Cold Air Intake beachkokopelli TDI Power Enhancements 44 October 25th, 2007 21:10
Cold Air Intake For Sale 01 Jetta TDI firemx220 Private TDI Items for Sale/Wanted 0 October 30th, 2002 10:14
Page generated in 0.16164 seconds with 10 queries
[Output: 129.04 Kb. compressed to 107.57 Kb. by saving 21.46 Kb. (16.63%)]
